Pendo pad 7 - safe mode enabled....have rebooted, even did a factory reset....still in safe mode when turned on...please help
shakeelm
  • 224 Answers
SOURCE: Dell inspirion 6000 is in a continuous reboot mode
I believe you can fix this problem without having to lose your files and also without having to reinstall your operating system.
In order to fix this issue you will need your windows XP cd.
Place the Windows XP cd into the optical drive and restart your machine. You need to boot from your Windows XP CD and at the prompt, press "R" for repair to get inot the Windows Console.
At that prompt, select 1 for your windows instalatin directory.
type "FIXMBR" at the prompt and restart your machine.
If this does not work, repeat the above process and instead of typing "FIXMBR", type "CHKDSK /R" and let it run to fix problems. It may take some time but once done, restart your machine and you should be back in action. Good luck...
Posted on Mar 08, 2009
  • 3 Answers
SOURCE: freezing in 'safe mode'
Have you tried accessing the bios to set boot order? It may be trying to load from the hdd before the optical/usb drive.
During the flash screen, press F2 (though it can vary by maker) and change your boot order to load the USB drive first.
Hope this helps!
Posted on Apr 29, 2009
  • 71 Answers
SOURCE: Set my Toshiba Satellite Laptop PSA60U-01W015 to it Factory Sett?
some of these systems have the factory restore option on post boot before the OS kicks in. From a cold boot look for the hit DEL or Fx key and do that - you may have to boot a few times to catch it, and possibly hold the defined key down in anticipation of the option to appear on what looks like a DOS screen. You may need the recovery discs that came wit the system if the image is not in a hidden partition of your drive. Good luck.
Posted on Jul 25, 2009
  • 214 Answers
SOURCE: Hi I have a fujitsu amilo pi 1536 laptop and wish
OK
You have Vista
EASY
In CONTROL PANEL select RECOVERY
Then "Advanced Recovery Settings"
Then "Return your computer to factory settings".
Be AWARE you will loose all of your files and after market downloads.
May want to BACK-UP!
Posted on Aug 03, 2011
  • 52166 Answers
SOURCE: Upon receiving an Pendo Pad 7, my son being very excited in getting one....proceded to by pass everything to due with setting up google play and accessing internet for pad....now I can't do an
contact the manufacturer thru tech support then keep the kid away from it .
Posted on Jan 05, 2015
How to reset a pendo pad when its not on
Bear in mind that this restores to factory defaults. In short, it is like you went out and bought a new one and just opened the box.
Pendo Pad Factory Reset Hard Reset Remove Pendo Pad Password Passkey
Oct 11, 2017 | Cars & Trucks
How do i reset pendo pad with no interna reset
Factory reset:
1. Turn the power off and pull the battery out and reinsert it.
2. Hold the Volume Down button.
3. Then press and release the Power button.
4. Wait a minute,the menu appears that allows for Fastbook, Recovery, Clear Storage, and Simlock.
5. Ok,press the Volume Down button to choose Clear Storage.
6. Next,press and release the Power button,Wait for the DoDo Pendo Pad to restart.
7. You will see the two options: Volume Up for YES and Volume Down for NO.
8. If you choose YES, all data will be deleted from your DoDo Pendo Pad and including third-party applications.
9. The DoDo Pendo Pad will reboot to its original data.
Dec 07, 2015 | Cell Phones
Hi my son has forgotten his password on his pendo pad 7 PNDPP44QC7(blk).I don't known how to reset it plz help.
Turn the tablet off completely. Then when you turn it back on, press and hold the power and volume up buttons as it turns on. This should get you to a factory reset that will allow you to change the password.
Mar 08, 2015 | Miscellaneous
How to turn of SAFE MODE on a PENDO Pad 10
Reset the machine. Hold power button down for about 10 seconds until it powers off. Then turn back on by holding power button for about 5 seconds,.
Jan 31, 2015 | Computers & Internet
How do I get my pendo pad 7 to accept google as it's search engine
Two different issues from what I see. An NVRAM error could very well mean you have an issue with the built in RAM memory on the unit -or- the code is erroring when making a call to the memory. Pendos use Linux as their operating system so you might consider resetting the Pendo to factory settings if this continues and considering the cost of a Pendo 7, picking up another one if the reset does not work.
Nov 24, 2014 | Computers & Internet
How to reset pendo pad
Go to settings and scroll till you find reboot your device to factory settings. Or "backup and reset" Under "Accounts" in your settings. Then click on "backup and reset." Every tablet and cell are somewhat different. Be sure to read your manual, very easy to do when you are familiar with your device.
May 13, 2014 | Tablets & eReaders
Restore factory settings for a pendopad
I have resolved the pendo pad hard reset lack of procedure and can factory reset a pendo pad that is locked with a passkey or and password full factory reset
First download you pendo pad firmware from here
http://shop.pendo.com.au/index.php/su...
I used the generic firmware 1 download and it worked fine for the TPC7SlV
Then Extract the . img file to you computer
Then you will need the firmware update too called rktools found here
http://download1942.mediafire.com/le9...
extract the zip file to your computer
Now your ready to flash the firmware
1. Power off your tablet with the switch
2. Turn the power switch Back the the on Position
3. Press & hold Side Button with the home picture also called the back/esc key
4. While holding, connect PC and tablet with USB cable (if tablet boot normally, try again)
5. Install the driver for your computer included in the RKtools Folder
6. Tablet should be recognized as "RK281X Device" in Windows
7. Start RKAndroidBatchUpgrade from rktools folder
8. In the bottom of the batch RKAndroidBatchUpgrade programme there should be a green light in the device upgrade area. * if there is no light in the upgrade area and all the numbers are grey then repeat the previous steps
9. Under the setting heading click and select the image file you downloaded from pendo ( will be a .img file if its a .zip file you need to extract it)
10.Click the upgrade button
11. wait till operation is completed
BAM Your pendo is password free, i hope i have created the best and easiest way to do this
***Please note if your wireless or Mobile network do not turn on then you have chosen one of the wrong firmware types from the pendo download site !!! the wireless and mobile network hardware are the only distinguishing features between the firmwares apparently******
Mar 08, 2013 | Tablets & eReaders
On my pendo pad THE process android.process.acore has stopped working
Hi you will probaslly have to flash the pendo pad, its not too hard to do here are my instructions, - unfortunatly a pendo pad does not have a recovery menu to access on device boot
note - this solution also unlock the pendo pad and restores it to factory settings even if it wont boot the android os
2. Turn the power switch Back to the on Position
Dec 20, 2012 | Cell Phones
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
