We changed the paper size and used M drawer and we cannot change it back to original paper size. Do you know how to do it?
  • kakima Dec 09, 2016
    Hi Bev Hoffmeister, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and model? What program(s) are you using to print?
  • 214 Answers
SOURCE: How do you change the paper selection?!?
if you have a different size/type paper in trays, just choose auto tray from printing preference, you only have to put right paper type /plain/thick ..... and the printer find it self the right tray
Posted on Nov 12, 2008
SOURCE: Ricoh Aficio 1075 - Change paper size on TRAY 1
you need to set the dial on the back of the paper tray
Posted on May 21, 2009
M2Tech1
  • 313 Answers
SOURCE: Imagerunner 1023if How do I change paper size on printer
you need to change the paper size on the copier or the paper tray dial.you can also select a paper tray from the printer menu..Alt set the printer properties to a paper tray with legal paper and it should overide the setting
Posted on Aug 11, 2009
SOURCE: have canon mf5700 says check paper size and only prints one page of several page job
Press that button "status monitor" on the left and you'll be able to cancel the current print/copy/scan jobs. Just press that button then you can navigate with the "-" "+" buttons from the right to select the job you want to cancel. Then press button "ok"
After cancelling the print job, open the cover and close the cover.
the printer resets and the error message goes away.
Posted on Jul 04, 2010
Joed911
  • 4338 Answers
SOURCE: I have HP Laptop HPG60-445DX PC Windows 7. I need
Display in Windows 7 allows you to make the text and other items, such as icons, on your screen easier to see by making them larger. You can do this without changing the screen resolution of your display. This allows you to increase or decrease the size of text and other items on your screen while keeping your display set to its optimal resolution.
Let's see how to change Display in Windows 7:
1. Click the Start and then choose the Control Panel option.
2. Control Panel window opens up. Click Display.
3. Choose one of the following:
Smaller - 100%. This keeps text and other items at normal size.
Medium - 125%. This sets text and other items to 125% of normal size.
Larger - 150%. This sets text and other items to 150% of normal size. This option appears only if your monitor supports a resolution of at least 1200 x 900 pixels.
Make your choice and Click Apply.
To see the change, Click Log off now and then Login again.
See this link:
http://www.techtalkz.com/windows-7/516049-how-change-font-size-icon-size-windows-7-a.html
Posted on May 17, 2011
I have a Panasonic Workio 1820 photocopier and I can't get it to copy A3 size documents. I have set the copy size to A3 but it will only copy and print an A4 portion of the document.
from where are u using the A3 paper . if ur using the drawer then simply select the original size and copy size as per ur requirement and first change the tray paper size to A3 in operator settings. if ur using by pass tray then be sure to pull the entire tray out as there is a sensor in the last end of the tray that senses A3 and legal paper
Aug 23, 2011 | Panasonic Office Equipment & Supplies
Don't know how to change paper size on LED screen
what is the model
but at model **3 **6
you can try this:
1- press key drawer & copy together for more 5 seconds
2- when all lamps flashing press {drawer} till the drawer you want to setup
3- then press {copy} till the {other} lamp flashing - "the last one" see the number on the LED screen
4- change the LED screen number "13" to "20" for LT size
Jun 28, 2011 | Toshiba Office Equipment & Supplies
How can I change the paper size( from A3 to A4) without changing the drawer
on the drawer you need to set the paper wide sensor ( blue handle ) must be on A4, also you need to put back rails and stopper in A4 position.
Hope that helps!
Jun 09, 2011 | Canon imageRUNNER 2000 Copier
The copier is flashing at the "error" light and the screen reads "change reccomended size, common settings" I don't know how to change it
To change paper size on Drawer 1, Go to Additional Functions > Common Settings > Reg Paper Size > Drawer 1 > Paper Size > (Select the correct paper size) > Press Ok
To change paper size on Stack By-Pass, Go to Additional Functions > Common Settings > By-Pass Std Set > (Select ON) > Paper Size > (Select correct paper size) > Press Ok
Oct 24, 2010 | Canon imageRUNNER 1023iF Black and White...
My e-Studio 3500c copier has 4 paper drawers, and one is set as LD (supposedly), but when we try to print to that drawer, it changes the paper size to 8-1/2x11 instead of legal size. We had a tech come in...
Once u setup the drawer paper size, make sure u tick the update automatically on the printer driver properties. Otherwise the printer driver wouldn't detect the correct paper size.
Dec 28, 2009 | Toshiba E-Studio 3511 Color Copier
I have an old Canon 1150 color copier. The bottom drawer #2 dropped and can't feed paper properly. So I put 11x17 paper in drawer #1 which had 8x10 paper originally. Now the panel still shows drawer #1...
Is there a paper selection wheel or bar in the tray?
Some of the older Canon models have a dial (usually in the lower right hand corner of the tray) or a slider bar (usually on the left hand side of the tray) when you open it. That has to be set properly or the machine has no idea what size paper is there.
Dec 03, 2009 | Canon CLC 1150 Color Copier
My photocopier has 3 drawers - First is universal and 2 & 3 are both set at letter. I would like to set drawer 3 to legal. how do I get the copier to recognize the change?
Please specify the models.Also the Minolta copiers paper tray change:Press utility key-User choice-paper set or
Utility-Meter count-Stop-0-Stop-0-0-1 Paper size input :set the paper size used in each paper source.Touch the key of paper sorce for wich the paper size setting is to be changed to show the paper size input screen.Touch the desired paper size keys.Touch END to validate the paper size setting.
Please look the mechanical setting in the trays.If so need,change.
Aug 13, 2009 | Konica Minolta Office Equipment & Supplies
My e-Studio 3510c doesn't have an ''original'' setting for printing on 9x 15.5 printer paper. How do I set a custom paper size setting
originals are what you scan using this copier, if you are printing on to 9 X 15.5 paper you must set the drawer (or bypass) size using the user function button then selecting drawer on the touch screen, I believe you will have to input it as a custom size but it should show X,Y coordinates on the screen to assist you in this. let me know if this helps or I can assist you further.
Aug 03, 2009 | Toshiba E-Studio 3511 Color Copier
When I change to legal size, the paper tray can't
You might have to remove it or lift from the back, you shouldn't use the drawer to force it open.
Aug 03, 2009 | HP LaserJet P3005dn Printer
HPS Copy Machine; paper size settings not adjusting correctly, malfunction, misfeed in copier, repeat, repeat, repeat
there are user mode settings and also some have settings on the actual trays the little windw that shows the paper size on the tray open tray ther is a slot that a cut out plate with the paper sizes make sure the correct size is showing thru the window if not reach in and pull out the cut out and put back in with the correct size displaying thru the window 81/2 x 11 and R if your copying the long way hope this helps
Apr 28, 2009 | Toshiba Estudio 200L Copier
k24674
jasbo
jasbo
