Question about LG Cell Phones
My LG HBS80 headphones will not activate when I press the on button.
Have an LG Bluetooth headphone set that voice activation of calls has stopped working. Must use the iPhone to look up numbers and dial. Not safe. Please help
If you do not have Data, SIRI will not work, so change your phone to 'Voice Control.
  1. Go to Settings > General > Accessibility > Home Button.
  2. Under Press and Hold to Speak, select one of these options: Siri: Siri will respond when you press and hold the Home button. Voice Control: Classic Voice Control will respond when you press and hold the Home button. This will also turn off Siri.
Oct 28, 2017 | LG Cell Phones
Initially starting new phone,with the pressing LG activation, with constant BLINKING,is this part of downloading information? Does not stop blinking to proceed!
Initial Activation and Setup - LG GizmoPal - Apple iPhone ...
www.verizonwireless.com/.../knowledge-base-133929/
Verizon WirelessPhone # or Username .... Find device-specific support and online tools for your LGGizmoPal™. ..... Initial Activation and Setup - LG GizmoPal™ - Apple® iPhone® ...LED blinks green for 3 seconds and plays a voice message when activation is ...When instructed, press the Call button on the Gizmo to complete registration.
[PDF]LG G4 User Guide - Sprint
shop.sprint.com/global/pdf/user.../lg/lg.../lg_g4_ug.pd...
Sprint CorporationFlashes front notification LED when you receive notifications, .... The battery provides up to 23 hours of continuous digital talk time. ... To drag, press and hold your finger with some pressure before you start to move your finger. While ... If you received yourphone in the mail and you are activating a new phone for an existing ...
Jan 05, 2016 | LG Cell Phones
How do i pair with my cellphone
press the button on the headphones to activate them ..and after that look in the phone's menu and choose find device ..You will get a list with all devices active in the range ..and choose the one by name and connect ..
Or ..for some you have to activate the phone to be found and the button on the headphones will connect automatically to the device found..in this case you might be asked for pin code...usually 0000
Jan 07, 2011 | Jabra BT2080 Bluetooth Headset
How can i tell if its a fake
Look on the link below to learn how to tell if they are fake.
http://hubpages.com/hub/How-to-Spot-Fake-Oakley-Sunglasses
Good Luck
Dec 22, 2010 | Oakley Inmate Sunglasses
Insignia Bluetooh Headphone won't turn on. but can charge
put the charger in your headphones and hold both volume buttons
you should see a slight flash of blue light then press the multifunction to turn it on
Jun 19, 2009 | Insignia Bluetooth Wireless Headphones...
Loud Speker Not working in Radio FM in LG KU990 VIEWTY
unfortunately, this option is not available on viewtys, however - if you bring up your phones keypad and dial 3845#*990# (don't press the call button after) you'll be presented with test mode, use the cameras jog wheel to scroll down to FM Radio test. Now, if you're lucky - you'll find a VERY strong radio signal that the viewty can pick up without the headphones in, and it'll play it through the speaker. But otherwise, you have to have the headset in to get a good signal, and if you have the headset in, there's no option what so ever to divert the radio to the speaker. So Sorry, but the radio can only play through your headphones unless you're lucky with test mode. (press the "C" button when in test mode to return to the home screen)
May 19, 2009 | LG KU990 Viewty
How to route the sound of fm radio on LG ku990 to main speaker. Right now sound is available only for headphones.
to Activate the FM Radio through the handset speaker? Type 3845#*990# into your handset.
You’ll be presented with a menu called Test Mode
Use your camera wheel to select FM Radio Test
Use the Up/Down keys on screen
Press the C Key and then the Red Key to exit.
thanks to lg-phones.org for this :)
Apr 25, 2009 | LG KU990 Viewty
I have a wireless headphones the only number i can see is model f0461b on the trasmitter. The transmitter and headphone are not comunicating the lights are red not blue.How do i recalibrate them so they...
In rare cases, the FreePulse Headphones may loose synchronization with the receiver. If this occurs the following steps will re-establish the connection by putting both the headphones and the receiver in discoverable mode (actively searching for another bluetooth device it can connect to).
Putting the headphones in discoverable mode:
Press and hold the power button (located next to the charging port on the right earpiece) on the headphones. The LED on the button will go through three states in this order:
  • Blinking Red
  • Off (continue to hold. the LED will be off for several seconds)
  • Alternately blinking red and blue. (The headphones are now in discoverable mode and you can release the button at this point. The headphones will remain in this state for 30 seconds).
Putting the receiver in discoverable mode:
Press and hold the power button (located on the side of the receiver opposite the headphone jack).The LED on the button will go through three states in this order:
  • Blinking Red
  • Alternately blinking red and blue. (The reciever is now in discoverable mode and you can release the button at this point. The reciever will remain in this state for 30 seconds).
Re-establishing the connection:
To re-establish the connection between the headphones and the reciever, put the headphones and the receiver in discoverable mode at the same time. It will take a few seconds for the two devices to establish the connection. Once the connection has been established the LEDs on both the headphones and receiver will glow solid blue.
Nov 19, 2008 | Audio Players & Recorders
My logitech headphones dont turn on anymore.
Quote from LOGITECH official site:
  • Blinking Red
  • Blinking Red
Do this and Freepulse will be pleased.
Aug 15, 2008 | Logitech FreePulse Wireless Consumer...
Cell Phones Logo
26 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
