Question about Exercise & Fitness
I have a proform 1250 treadmill that won't start. Panel lights are on, no messages apart from " JUST PRESS START TO BEGIN", but none of the buttons seem to be doing anything. Please help ?
  • 6,694 Answers
If you wish to get some details treadmill repair and service ; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Posted on Dec 29, 2016
  • 16 Answers
SOURCE: Proform 515s treadmill motor won't start
If the colse buttons make a chirping noise when you push them the console should be Ok. If there is no chirping noise with the push it is a bad console. If everything but the speed works it will probably be your motor controller that is bad.
Posted on Apr 14, 2009
  • 64 Answers
SOURCE: Proform 450 X treadmill powers on, but trips current when started
There could be a combination of problems. I would first start with disconecting the motor leads and see if it trips the breaker. Then elevation motor would be next if no change from disconecting motor. More than likely it's a motor issue.
Posted on Jun 08, 2009
SOURCE: Proform 730i powers on but will not move when I input speed.
I have the same treadmill with the same problem statement. Here is how I fixed it:....Open the lower shroud that covers the motor. You must remove 4 or 5 screws. Taped to the inside of the shroud should be a document with a calibration procedure on one side and electrical specifications on the other. It will tell you how to run the calibrations. You need to hold the stop button and the + speed button as you insert the safety key. This will put you into calibration mode. My treadmill started working again after I ran the incline calibration routine. Hope this helps.
Posted on Oct 31, 2009
SOURCE: Proform 550xp Treadmill in continuous incline/decline mode!!!
i just called the manufacturer on this and found out i have a faulty control panel, but these are the steps they told me to go through to reset. If it works, then you are good, if not, you may also have a control panel issue.
1. plug in and turn on treadmill, keep red key out
2. press and hold the stop button and speed up button at the same time and hold them while you insert the red key
3. after red key is inserted, let go of both buttons
**CAUTION - be sure to stand on side bars of treadmill, clear of the belt for this next part bc it will go VERY FAST***
4. press stop button once
5. press speed up button until it reads 85 (see what i mean?!)
6. press stop button once
7. press incline down or up one time and it should get back into normal mode. mine just started a series of flashing lights and "8"s in all the "windows" so my panel needs to be replaced. here is the number i called - 1-877-993-7999. Good Luck!
Posted on Jan 06, 2010
SOURCE: On a Proform 760 EKG treadmill, this machine will
sounds like the speed sensor needs adjusting
Posted on Feb 03, 2010
Incline problem
All icon models are the same. The easiest way to incline calibration is to start the treadmill, push the incline up button and then after you release the button, remove the safety key. Replace the safety key and the treadmill should calibrate.
If that doesn't work, press the stop and speed up buttons and hold, then place the safety key in place. This will bring you to the speed/incline calibration. Press stop again. now press incline up. This will run the incline calibration.
You may need to remove the hood and manually with a drill lower the motor. Using a slot screwdriver bit, lower the motor a bout 50 turns and then try the procedure above again if necessary.
Mar 05, 2014 | Proform Exercise & Fitness
Repco rp300tm
1) reset the treadmil.2) adjust the speed sensor, see the diagram attached. 3) Run the software calibration for easy diagnostic and fix it. God bless you
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button 31d332da-cd1c-4885-8ae4-393941ca1930.gif
Oct 18, 2013 | Proform Perspective Es Treadmill PFTL99806
Control panel lights up but not responsive on any function
The proform console sometimes freezes up and refuses to take the input from the user. Replace the console. The manufacturer do not sell parts for this console.
May 19, 2013 | Proform Pro Form 785ss 785 Ss Treadmill,...
Console lights up but when I press any of the buttons it won't start
I am having same problem. The console lights up but none of the button works, including TV and the fan.
I actually took everything apart, unplugged and re-plugged the connectors on the PCBs of both side of the console, it still didn't help. Looking at the electronic configuration, TV, fan, left and right panels are relatively independent. I believe the driver/motor module is still working, the most likely cause of this is the controller CPU.
Jun 05, 2012 | Reebok Vista Treadmill - RBTL13305
Beeps when buttons pushed, but won't start
Dear Sir:
Try it with some little Inyection of 50% of Oxigened Water +50% ethilic Alcohol(100%) for to clean the contacts or pad for the buttons.
Wait for 15 minutes.
An try it again.
Now if doesnot work go to the 2 Step.
2) You must open the cover, and look for the rely for to clean it contacts, in the same ways.The rely is the element for to swith off -and on the motor for Theadmill.
Respond it if you get solution.
sincerely.
E.Cuadra
Sep 05, 2011 | ProForm 980 CS Treadmill
Treadmill keeps inclining and declining . It won't stop!
I have a Proform ZT5 model - had the same incline/decline problem. It needed calibrated.
- unplug, turn off, and take the key out
- plug machine in
- turn switch on
- Pres and hold the STOP and SPEED UP button at the same time, while holding them insert the RED KEY
- let go of both buttons
- press STOP 1 time
- pres INCLINE UP 1 time
- this should reset it.
The tech on the phone mentioned the importance of turning the maching off, taking the key out, and unplugging after each use. Leaving it plugged in there is still an electrical current running and this can cause more seriouc problems that require a new control panel.
May 08, 2011 | Proform ZT5 Treadmill
Dec 30, 2009 | Exercise & Fitness
I plugged in my Pro-Form 730cs treadmill and it won't start.
My i FIT treadmill won't turn on. Is there a reset button somewhere?
Aug 28, 2009 | Proform Quick Burn Pro Treadmill with 12...
Exercise & Fitness Logo
89 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
