Question about Comfort Glow Heating & Cooling
I have a NY116 Comfort glow and I need to know if I can set it up on a thermostat it did have one at one time but no longer can I use a replacement thermostat?
2 Suggested Answers
  • 24 Answers
SOURCE: T87 thermostat heat doesn't stay on long
is this truly a T-87 round mechanical or is it the new electronic version? If it is gold in color it's the old tried and true, if it's white it could be either. Pull the outside ring straight out. If it is a t-87 mechanical you will see a mecury bulb setting on a spring on top. On the lower righ (4 to 5 o'clock) is a heat anticipater adjustment. Take the brass poiter and slide it to the left as far as it will go this should increase the duration of cyles and make them less frequent. This is if the problem is truly thermostat related. If it is the electronic version of the T-87 and it displays this behavior only when it is very cold out, it is a programming glitch that they were informed of 2 weeks after it came out, because I told them. If this is what you have purchase a new thermostat and replace that junk that is defacing your wall.
Posted on Dec 18, 2008
Blower on a comfort glow heater
Most of those switched is non adjustable but some are .if that's where the switch was all along and everything was working then I don't think it's the switch location .
Check to see if you miswired or got loose connection .
Dec 12, 2017 | Comfort Glow Heating & Cooling
I have a comfort glow wall mountable natural gas heater. After being on for a while it shuts off. The model number is CGR18N. What cause's this
Either insufficient fresh air ventilation causing oxygen starvation or the safety thermocouple needs adjustment or replacement. Could be a bit of both...
Dec 04, 2016 | Comfort Glow Heating & Cooling
How do you replace the wick in a comfort glow model gr9a kerosene heater?
Post your question on this page , and you shall find the answer .
http://www.searspartsdirect.com/partsdirect/part-model/Comfort-glow-Parts/Heater-Parts/Repair-Maintenance/Questions-Answers/Model-GR9A/0218/0912160?mmlLandingSearch=GR9A&modelNumber=GR9A&diagramPageId=&documentId=
Sep 05, 2015 | Comfort Glow Heating & Cooling
My propane gas wall heater does not turn off when it reaches its set temperature whats the problem
It has a thermostat that should shut it down, locate and clean if you can, try again , if it still is doing that have the temp sensor replaced
Jan 08, 2015 | Desa International Comfort Glow Infrared...
I need replacement logs for a Desa Model CGFB32CA. No one lists the log numbers, including the manual. Where can I get the item number?
As you probably already know, DESA International is no longer in business. However, depending on the age of your unit, some parts are still available, as is the Owners Manual. The parts for Comfort Glow gas logs (which is what you have. And probably purchased them from Lowe's some years ago) are interchangeable with DESA's Vanguard line.
You can find what you're looking for at www.desatech.com. However, don't be shocked by the price of the replacement logs.
Feb 05, 2011 | Desa International Wall/Window Air...
I have a NY116 (DESA/Comfort Glow) heater w/ remote control. The remote control doesn't appear to show the room temperature while in Progrom Mode... preventing the heater from turning on. It works fine in...
The remote control was made by Skytech. You should get the information off of the remote and the valve and contact them for parts.
email
support@skytechsystem.com
fax
888-672-8024
phone
888-672-8929
address
9230 Conservation Way
Fort Wayne, Indiana 46809
Jan 05, 2010 | Desa International HRC201-4 Remote Control
Thermostat seems ok, but gas won't flow from oven burner.
Hi, Even tho the ignitor is glowing, it is getting weak and will need replaced. The ignitor is not pulling enough amps to open the gas valve.
This is very common problem with the gas ovens.
If I can assist you further, please let me know.
Vic
May 29, 2009 | Garland H283 Gas Kitchen Range
Thermostat T87
how old is unit? Sounds like it may be short cycling which could be do to it going off on limit.
Sep 15, 2017 | Honeywell CT87B ROUND HEATING&COOLING...
Heating & Cooling Logo
27 people viewed this question
Top Comfort Glow Heating & Cooling Experts
Vernon Taylor
richie46
Are you a Comfort Glow Heating and Cooling Expert? Answer questions, earn points and help others
