Mitzubishi rear projection tv error code 43.....what is this and can it be fixed
Shuttle83
  • 1139 Answers
SOURCE: Toshiba TN43V71 43 in rear projection
Hello WendyOreo,
It sounds like your switching power supply or you High Voltage power supply has malfunctioned. These sections control all power to the TV and can produce the situation you are describing. If you do not have a background in electronics, I would suggest that you have a TV repairperson come over and check your TV out.
I say this because there are voltages in a TV set that can kill, so caution is needed.
I hope this helps
Thank you,
Shuttle83
Posted on Oct 17, 2007
SOURCE: error code 43 on F& P washing machine
The micro switch or the lever that activates it seems to have been the cause of the Error Code 43. Have re-seated the switch in its holder and ensured the activating (out of balance) lever is moving freely. The switch appears to be OK and now it is all re-assembled, the Error Code 43 is gone. Machine is operating normally again.
Out of Balance Switch was located below the right hand side of the computer board (module).
Rgdz John T
Posted on Sep 20, 2008
  • 10406 Answers
SOURCE: My cruzer has an error code -43 and i don't know
Copy all the files from it to your computer that you can.
Then, take a hammer to it -- to kill it, to destroy all your "private-data" files.
Spend $15 to buy a new 4GB flash-drive.
Or, if it's still under warranty, exercise the warranty to get a replacement.
Posted on Apr 07, 2010
SOURCE: 43" samsung rear projection hdtv SP43W6HD 1080i
you have a bulb gone i have the same problem
Posted on Mar 02, 2011
SOURCE: error code "43"?????
Thanks Marty for the info on the sail switch. We experience the same error code 43 problem. Seemed like the sail switch was stuck in the back position and didn't come forward when the fan started. So I bent a metal coat hanger and used it to pull the switch foward to "unstick" it. I tested the oven turning it on and off a few times and made sure that the switch moves forward with the blower fan starting when the oven was on, and moved back when the oven was turned off. Should be obvious, but make sure the blower is not running and the oven is turned off before you stick the wire hanger back there. A pretty quick and easy thing to try before calling the repairman.
Posted on Dec 31, 2011
4 blinks on the on/off switch. Vertical output or buffer? How do I fix it. Do i need to order a part? thanks
Most of this error code, vertical output IC(IC1509) is the caused of the symptoms. You have to test also the vertical pulse buffer transistor (Q1505) if faulty using the multimeter.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Aug 08, 2011 | Sony KP-43T90 43" Rear Projection...
I have a Sony KP43HT20 TV that does not come on . The red light on the front of the tv keeps flashing. What could be the problem.
The blinking light is an error code. Count the number of blinks in between a slight pause and let me know the number of blinks and I will assist you.
Feb 17, 2011 | Sony KP-43HT20 43" Rear Projection...
My Mitzubishi TV model vs-55705 will not turn on. The timer light blinks on breifly but no sound or picture. When I push the menu & input buttons the code is blink pause blink blink. Is this an...
IF YOU GET A CODE 12 WHICH IS THE BLINK PAUSE BLINK BLINK THEN THE TV THINKS THERE IS NOTHING WRONG WITH ITSELF. ARE YOU SURE IT ISNT CODE 22 BLINK BLINK PAUSE BLINK BLINK? THAT WOULD BE A CONVERGENCE FAILURE COMMON FAILURE FOR CRT REAR PROJECTIONS.
Dec 17, 2010 | Televison & Video
Getting 3D effect in picture is there a way to adjust lamps to fix problem
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 25, 2010 | Sony KP-43HT20 43" Rear Projection...
Mitzubishi projection tv power shut down and won't power back up. green light comes on for a second then it shuts down immeditately
MOST Mitsubishi sets have a self check feature:
When power light goes off: On the front of the set press and hold MENU and INPUT (device) BOTH FOR 5 SECONDS OR LONGER AND RELEASE.
POWER light should blink a two digit code: for example:
2 blinks, a pause and 2 blinks----it will repeat the error code several times.
2,2 is the most common and the least expensive to fix.
LET ME KNOW EXACT MODEL NUMBER and the blink code and I will tell you what it means and if 2,2 how to fix it.
If this information helped you, rate this solution as I do this here for FREE.
SD TECH
Nov 14, 2009 | Televison & Video
Hitachi 43FDX Rear Projection TV
Yes, You will need to replace the 2 convergence IC's. Hitachi part # CZ01341. Generic part # STK394-160E These are the upgraded replacement parts. Also look for any burnt resistors near these IC's.
May 28, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Sony KP-43HT20 Projection TV
5 times blinks is error code for No Good White Balance and you said that picture is very green.
As you know TV is approx 7 years old so it needs RGB gain adjustments.
If you are TV tech person or know about TV repair, let me know to guide you further. Or contact local TV repair shop to fix it.
Oct 26, 2008 | Sony KP-43HT20 43" Rear Projection...
Wt 46809 Projection TV Mitzubishi
First check threads and do self diagnosis. Then live chat!
Oct 08, 2007 | Mitsubishi WT-46809 46" Rear Projection...
43 inch rear projection
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 22, 2006 | Toshiba 53H71 53 in. Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
