Question about Miscellaneous
Hi.. what dose p1589 code means for toyota axio? anyone can help?
How would i remedise
Option toyota axio
Do you mean computer box? What do you want to reset exactly? Its always best to hook up a scan tool or odb scan tool and fix the faults before resetting
Mar 21, 2014 | Computers & Internet
P1589 toyota
P1589 means TCU unable to control desired throttle angle, SO, it will not work right only erase the DTC with scanner, you should repair the throttle angle or related component. any other questions, you can ask the 24 hrs live technical support http://www.diyobd2.fr/, they will like to help you, good luck
Jul 03, 2013 | Cars & Trucks
Ask to insert correct map CD to Toyota Axio car video player
Hi i have a TOYOTA AXIO and i get the error "Please insert correct map cd"..... please send me the link to download the software..
thank you.
Dec 12, 2012 | Eclipse Car Audio & Video
P1589
The P1589 means Autolamp Delay Increase Circuit Short To Battery. you can erase the fault code with your obd2 scanner first, after then, if the check engine light comes on again, you should take it to be fixed.
Nov 14, 2012 | 2007 Toyota Yaris
HOW TO FIX P1589 ACCELERATION SENSOR LEARNING VALUE PROBLEM
2005 Toyota vitz engine light comes on when u shift onto drive,scan code is P1589 acceleration sensor learning value
Mar 13, 2012 | Toyota Yaris Cars & Trucks
Hi, i bought a toyota axio 2007 without an owners ...
Want to get a copy of the toyota axio (x) 2007 model.
May 21, 2010 | 2007 Toyota Corolla
Toyota corolla axio 2007 car manual in english
how do you activate the phone or bluetooth system in the axio
May 05, 2010 | 2007 Toyota Corolla
VITZ 2006 AUTO WITH CODE P1589
p1589 acceleration sensor learning value how fix problems
Apr 11, 2009 | 2007 Toyota Yaris
Miscellaneous Logo
16 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
