Question about Dryers
No heat Kenmore series 90 dryer, 76902. Drum spins, timer turns doesn't heat up.
    President:
  • 1,776 Answers
The problem is probably a faulty thermal fuse or heating element. The thermal fuse should be just inside the back of the dryer, close to or on the exhaust duct. It is about one inch long. Both components can be easily tested with an ohm meter or multimeter. They should have continuity, if either one doesn't, that component will have to be replaced. Sure hope this helps you and good luck.
Posted on Jul 20, 2009
No heat
Posted on Aug 21, 2009
I have a Kenmore 90 Series gas dryer model num 11074902200 that won't heat up. the drum spins and the heat will turn on for a few minutes then it stops heating up. I replaced the glow igniter but the...
The flame sensor is fine because it is powering up the ignitor. The dryer does heat a little. It can be only one thing: The solenoids are aged and weak. They work at first then the heat up and quit.
How to video
Service manual and more HERE
Sep 08, 2011 | Dryers
I khave a Kenmore gas dryer 110-90 series. It no longer clicks off when the timer is set. Now, there is no heat coming from the dryer. The drum turns with air drying but no heat from any of the cycles.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 19, 2011 | Dryers
Kenmore series 90 electric dryer won't start. checked thermal fuse and timer runs but drum won't turn
The motor of drum is not work . Just check the motor and power feeds to it
Jan 14, 2011 | Kenmore Dryers
Kenmore 90 Plus Series Gas Dryer that will not heat
It could be several other things thermal fuse, thermal cut out, hi limit thermostat, dryer coils, heat sensor,or igniter. All of these parts are inexpensive and easy to test and replace.There is a video at t http://appliancehelponline.com/gdryertroublevideo.html his will walk you thru the troubleshooting of these components. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Jul 01, 2010 | Dryers
Kenmore 70 Series Dryer not heating and not cutting off
I had an identical problem to yours this weekend with my Kenmore dryer. There were 2 problems.
1. Timer was broken. Does not advance to "OFF" position on timed dry, however it still works for auto-dry.
2. Thermal fuse was blown. Upon replacing, dryer heated up normally.
I believe when the timer broke, the dryer had kept running and blew the thermal fuse. On Sears' website, thermal fuse is $5.30, timer is roughly $80.
Kenmore 70 Series gas dryer, M# 110.76752500
Jan 01, 2010 | Dryers
Kenmore Heavy Duty 80 Series Gas Dryer won't cycle/won't heat.
if you ran this unit awhile without timer advancing,,now you blew the thermal fuse,,,re place thermal fuse and timer..
Nov 27, 2008 | Kenmore 73952 Gas Dryer
Drum won't turn
sounds like a broken belt, common kenmoore belt number 341241.
Nov 03, 2008 | Dryers
Dryers Logo
237 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
