My SyncMaster XL2270 screen does not turn on. The Power light then the Auto light will blink every half second. What is causing this?
When I play and jiggle the power cord in the rear of the screen where it connects, the blinking will either delay or stop for a moment. Seems like a possible power connection issue. Has anyone seen this before?
    Top Expert:
  • Computers & ... Master
  • 25,330 Answers
Power supply has problems, probably capacitor related. Replacement monitor is very inexpensive.
Posted on Dec 09, 2016
  • 72 Answers
SOURCE: the power on my laptop won't stay on
The jack or AC power pin can be fixed yourself if you're up to it. The part is usually under $10. I've done three (2 Fujitsu' and a Sony. Take your time when you take it apart and take pictures of the disassembly. They will com in very handy when you start to put it all back together again. When you get it fixed invest in a proper cable retention device so the AC power pin doesn't get damaged again. This short Chris Pirillo Video talks about CRDs on laptops.
Posted on Jun 10, 2008
SOURCE: HP Pavillion power link blinks
I have a DV1130us and I'm having the same problem. I've already replaced 2 blown SMD capacitor on the motherboard, originally would only short out and obviously not boot or charge.
But I think it may be the MAX1907a chip, basically the actual power supply controller for the laptop, though it may also just be another bad cap somewhere. If/when I get mine working I will post what I did to get it to charge.
Posted on Sep 12, 2008
Kaisolo
  • 43 Answers
SOURCE: power button pushed battery light blinks twice won't turn on
I have the same problem for my dell note book
This is how i solve it
Unplug your note book from any power source
then remove the battery from the Notebook for
30 minutes after 30 minutes put back the battery and reconnect your adapter to power source turn on the power
Posted on Feb 19, 2009
SOURCE: HP Compaq 6735s battery light orange blinking
hp 6735s when power on not display
Posted on Feb 11, 2010
  • 3 Answers
SOURCE: Hello, I have a problem
Unplug the computer and take out the battery.
Hold the power button for ten seconds.
Leave the battery out and plug in the power cord.
Press the power button.
If the computer turns on, put the battery and everything should now work.
This has solved every "laptop not turning on problem" for me and my friends.
sublimedjg
Posted on Jun 23, 2011
I have SyncMaster 2233BW with a screen problem. Once I turned it on it will flashes display then in a second or two the screen will turns black. Press power button again it will comes on then turns black...
did you check the output dc voltage at the power supply board if stable. if ok tried to disconnect first the supply going to the power inverter board of screen back light just to ensure if not the cause of shut down.
Oct 15, 2012 | Samsung SyncMaster 2233BW 22" LCD Monitor
SyncMaster 940N - screen has gone dark when turned on and computer booted up. If I get close to the screen I can just about see something on the screen. I have brought up the service menu and all the...
Your problem is usually caused by a bad power supply. You should be able to do the repair yourself, if just requires replacing 6 capacitors on the power supply board. Here is a link to a repair guide that shows how to disassemble the monitor and repair the power supply board.
http://www.ccl-la.com/blog/index.php/repairing-a-samsung-940n-with-a-blinking-power-light/
And here is the a picture of the power supply board.
I hope this helps, if so please rate my solution.
BuddyMc
Apr 16, 2010 | Samsung SyncMaster 940N Flat panel Monitor
Monitor goes blank after 3 seconds -Samsung SyncMaster 920NW
Could be a power issue. If it doesn't show anything at all then that may be the case. It may also be the display itself. It would be a costly repair so you might be better off finding a new monitor.
Sep 16, 2009 | Samsung SyncMaster 920NW Monitor
SyncMaster 932B blinks, then screen goes black
Check all the connections and if they are all right and tight then the monitor is probably shot. The good news is that it can be repaired. It's usually around $50.00 to $80.00 to fix. Good luck!
Aug 29, 2009 | Samsung SyncMaster 932B LCD Monitor
Samsung Syncmaster 205BW power button lights up image will appear
Hold down the power button and the auto button. if that doesn't work try the power button and the source button.
Jun 24, 2017 | Samsung SyncMaster 213T 21.3" LCD Monitor
Samsung SyncMaster 17" LCD Blacks out
If you have a second monitor, you could use your computer until the monitor goes black... then plug in a replacement monitor. My guess is that one will display black too...
My gut feeling is that your VGA card is on the fritz... I'm not convinced it's your monitor. Do you have a replacement VGA card you can try? I'll bet that'll take care of the problem.
Apr 22, 2008 | Samsung SyncMaster 17" LCD Monitor
Dell monitor
Monitor Help CH000315, Black borders on side of screen. CH000316, Dead or black pixels. CH000403, Macintosh and/or PC monitor compatibility.
Black borders on side of screen. Additional information about what causes black borders on computer displays.
Good Luck, Please dont for get to Vote/Thank You.
Dec 19, 2007 | Samsung SyncMaster 712N 17" Flat Panel LCD...
Computers & Internet Logo
David Payne
David Payne
