I need a manual for a ruud furnace model ugra-10ezajs
  • 582 Answers
SOURCE: I have a Ruud 90 Plus Model UGRA furnace and blower starts immedi
NO BECAUSE THE BOARD IS TELLING THE FANS TO STARTARE THE CONTACTS FUSED TOGETHER OR STUCK IN THE CLOSED POSISTION CHECK THIS FIRST
Posted on Aug 10, 2009
  • 1416 Answers
SOURCE: ruud M# ugra-06emaes won't start,
A common question on on our site is about different fan sound that happen and the causes. These noises are often fairly easy to fix and some are the result of other problems.
If you are hearing a rattling sound or a squeaking, high pitched squeal coming from the bottom or back or the refrigerator then the condenser fan motor is probably going bad. Sometimes the bearing in the fan motor will even get so bad that the fan blade will start to hit anything that is close to it down there. This can create a very loud noise. This fan normally will be running when ever the compressor is running also.
As with any other problems you will want to get these things fixed promptly. If the problem is just a squeal a bit of light motor oil will do wonderful things for you. Many times though, you will have to order the parts needed to fix the problem. When repairing the problem make sure to remove all power the the unit and to wear gloves is possible, as there are many sharp edges in close quarters that will butcher you hands in no time.
The other fan that can cause sound is the evaporator fan. While this fan too can get worn and become noisy, it also can sometimes start to hit ice that is building up because of a problem with the defrost system of the refrigerator. Checkout my tips about defrost problems if you find a build up of ice and the fan is hitting the ice and making noise. This fan can also be oiled if needed, and it will also wear out and need to be replace occasionally. This fan usually will go off when the door is opened, so sometimes it makes it difficult to figure out exactly what is happening. By holding the door switch in manually, you can get the fan to run and troubleshoot it more easily. Make sure to remove all power before trying to service the fan. Spinning fan blades do not play nice with your hands!
For many refrigerators you will have to remove some covers or even the whole bottom of the freezer to get to this fan for replacement. Checking the exploded views at appliance parts websites can give you an idea of where the fan is located and what must be removed to get to it for replacement.
Both of these fans and the associated parts are available for most refrigerators online. Look for them at the appropriate spots in the exploded views of the units.
Good luck and thanks for using fixya.
Posted on Jan 19, 2011
  • 94 Answers
SOURCE: NEED INSTALLATION MANUAL FOR RUUD
What do you need to know about the unit?
Posted on May 02, 2011
  • 127 Answers
SOURCE: what is the efficiency rating of a ruud ugra
80 percent furnace
Posted on Oct 21, 2011
turftamersll
SOURCE: Ruud 90+ Model UGRA 10EZAJS Trips Out
Check for condensation buildup in the Induction Blower housing. The condensate tubes or canister may be blocked and causing the diaphragm switch to trip the unit out causing the burners to shut down.
Posted on Nov 09, 2012
I need a Ruud 80 plus gas furnace manual
Request the manual directly from Ruud.
Mar 25, 2017 | Ruud Heating & Cooling
Ruud furnace, model UGRA I need to trouble shoot the fan control board.
Does it have the flashing light you can view thru the peephole and count the flashes? They will give you an idea.
Is the fan coming on? Describe the problem. don-ohio
Dec 12, 2016 | Heating & Cooling
Can Rudd Model # UGRA-10EZAJS be converted from natural gas to LP gas?
all gas units can be converted between gas types
the main changes are the jets and the air shroud positions
it is a job for an accredited gas fitter and not for amateurs
Nov 10, 2015 | Kitchen Ranges
Is a 8 yr old furnace never out of the box the same as a new 2012 furnace same model?
Its not the same but the manufacturer should honor the warranty if you are the registered owner
Jan 28, 2013 | Heating & Cooling
Feb 11, 2012 | Ruud Heating & Cooling
Rudd Furnace Model UGRA-04EMAES Gas valve will not open
If the Igniter is not glowing, then the gas valve would not open to push out the gas. This indicates a Weak Igniter and you need to replace that.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Feb 20, 2010 | Ruud Heating & Cooling
Flame sensor oxidation problem?????
make sure you have good contact at ignition control module. if wire comes off easy crimp wire terminal with pliers until its hard to pull off. also make sure green ground wire is tight. make sure sensor is with in 1/8 in of flame. If unit is being used alot your doing the correct thing by cleaning.
Jan 24, 2010 | Heating & Cooling
Aug 10, 2009 | Heating & Cooling
Heating & Cooling Logo
65 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
