Question about Schlage Locks & Locksmithing
Need a lost code for my schlage digital #365
    Top Expert:
  • 14,355 Answers
FIXYA DOESNT HAVE ACCESS TO YOUR PRIVATE CODES OR CODE S FROM ANOTHER COMPANY EITHER CAN NOTIFY A LOCKSMITH OR MANUFACTURER
Posted on Dec 09, 2016
5 Suggested Answers
VtToolMan
  • 704 Answers
SOURCE: need info to change code
Here's a link to the Schlage web site with pdf's and videos showing how to operate and program your lockset.
Just select which info you need from the list on the page.
http://consumer.schlage.com/customerservice/FE575_install_inst.asp
Hope you find this Very Helpful - Best regards!
Posted on Aug 20, 2009
SOURCE: Schlage FE365v keyless entry lock.. Lost manual. Forgot 6 digit programming code. Need instructions to restore and set all new codes.
look on the sticker located inside the outer panelo on the lock. you are going to need to disassemble the unit but it is in there.
Posted on Aug 08, 2010
SOURCE: how do I unlock my
You have to push the key set in while turning boltset. I was fooled too.
Posted on Dec 14, 2010
  • 963 Answers
SOURCE: i have a schlage camelot leverset and i need to
No problem!
A quick note: The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.
This link will take you to the page that you need to get started:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Then scroll down to this heading on that page:
Electronic Security-Keypad Entry Flex-Lock FE595/Keypad Entry Auto-Lock FE575 Documents
There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This is useful because there should be a sticker to be found on the backside of the keypad, with the code number that you need to reprogram the lock, which i noted above. This installation video (fourth item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery!
The eighth item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that programming code that you found on the backside of the keypad.
Also, you will find "Keypad Programming Guide", etc. links which are PDF type files, giving you a "picture" of the print instructions.
A note about the PDF files: If you cannot view a given file, you need to first install Adobe reader. You can get the free download from here:
http://get.adobe.com/reader/
Good luck,and please provide feedback if this helps!
Posted on Aug 17, 2011
Shlage keypad dead bolt unlocks when you press the
Does my Schlage BE365-CAM BE365CAM505 have a feature that allows it to automatically lock the deadbolt without having to enter code and turn the dial?
Sort of. The lock has what is called the "turnlock" feature. When enabled, you have to only push the Schlage button, then manually turn the dial. When disabled, you have to enter the user code, then turn the dial.
To enable/disable this feature, enter your Programming Code--press the Schlage button--Press 7.
Each time you do this, you toggle between enabled and disabled.
Videos for installing and programming can be found on this page:
Scroll down and find them under the heading Electronic Security--Keypad deadbolt 365
Aug 31, 2012 | Schlage Camelot Deadbolt Keypad, Satin...
Need to change the 4 digit code be365-cam lost manual
Reprogramming BE 365:
Electronic Security-Keypad Deadbolt BE365
There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This is useful because there should be a sticker to be found on the backside of the keypad, with the code number that you need to reprogram the lock. This installation video (second item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery!
The seventh item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that programming code that you found on the backside of the keypad.
Aug 09, 2011 | Schlage BE365-CAM BE365CAM505 Lifetime...
I can't put in the 6-digit PC to my new BE365 Schlage. When the lock is idle, I put in the 6-digit code and the lock thinks I'm putting in the 4-digit UC, so it errors out. My 2 default UC codes...
I don't have a direct answer, but here is the contact info you need for customer service:
Schlage Lock Company
Customer Service Department
2119 E Kansas City Rd
Olathe, KS 66061
United States Customer Support
Warranty & Technical Information: 1.888.805.9837
http://consumer.schlage.com/Service-Support/Pages/ContactUs.aspx
Schlage FAQ: http://consumer.schlage.com/Service-Support/Pages/InstallationTroubleshooting.aspx
http://consumer.schlage.com/Service-Support/Pages/FAQ.aspx
Instructions & Manuals: http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
BE-365 installation & programming PDF: http://consumer.schlage.com/Project%20Documents/P515-858.pdf
Jun 03, 2011 | Schlage BE365-PLY BE365PLY626 Satin...
I need to change my code. I know PC# UC1 # and UC2#
Here's a link for installation & programming of the BE 365:
Feb 05, 2011 | Schlage BE365-PLY BE365PLY626 Satin...
I lost the manual and i need to reprogram the codes
How can I program my electronic keypad lock when the instructions with the programming code have been lost?The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.
This link will give you instructions for various models of Schlage locks:
There is a video on this page, showing how to change codes.
Jan 22, 2011 | Schlage Electronic Lock FE595 Plymouth or...
Lost 6-digit programming code and need to restore lock to put in another
Jan 13, 2011 | Schlage BE365-CAM BE365CAM505 Lifetime...
How do I set the key pad to my on code on my schlage electronic keyless lock
This link will give you instructions for various models of Schlage locks, including the BE 365:
Jan 13, 2011 | Schlage Lock BE365VCAM716 Electronic...
I need to programming instructions for this lock. it has a keypad on it and I do not have the instructions for it.
This number is the programming code referenced in the information for changing the entry code.
Complete installation & programming instructions can be found here:
Notice that the above is a .pdf filetype. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:
Good luck--and please provide feedback if this helps!
Nov 01, 2010 | Schlage BE365-CAM BE365CAM619 Satin...
May 16, 2009 | Schlage Locks & Locksmithing
Locks & Locksmithing Logo
255 people viewed this question
Top Schlage Locks & Locksmithing Experts
JOHN LAPIER
Are you a Schlage Lock and Locksmithing Expert? Answer questions, earn points and help others
