Question about Mitsubishi WD-73640
WD 73640 blinking yellow light - Mitsubishi WD-73640
    Top Expert:
  • Mitsubishi Master
  • 75,452 Answers
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Dec 09, 2016
SOURCE: Mitsubishi WD-62525 yellow blinking status light
Check that the lamp door is closed all the way. There is a saftey switch that closes from the door being on all the way. If not the status light will keep blinking. There is also a switch on the air filter door.
Posted on Jul 16, 2009
salt56
  • 373 Answers
SOURCE: I replaced lamp on mitisubishi
Are you sure you installed the lamp properly and put the door back so the interlock switch is functioning. Sometimes installing the lamp will get slightly displaced and is not plugged up properly and will indicate a lamp blinking light.
Posted on May 20, 2011
SD Tech
  • 14553 Answers
SOURCE: wd-60737 mitsubishi blinking yellow status light ?
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Posted on Oct 26, 2012
  • 38 Answers
SOURCE: black screen
Sounds like you need to replace the lamp. An original Mitsubishi lamp will last 7 to 10000 hours. It's a no brainer to replace. Buy the lamp from Mitsubishi or a dealer. Do not buy one over the internet. Those are awful...
Posted on Jan 01, 2014
gopakumarg43
  • 75452 Answers
SOURCE: WD-73640 , no picture or sound, green power on,light blinks green really fast then turns off 83 blinks bulbin1peice doesn't look blown inside wire not burned in two ,but black at base of filiment help
Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on May 18, 2015
Mitsubishi tv WD-73640 wont turn on. 4 red light then 8 yellow lights
Hi, if you power your TV on and see a black or grey screen, it may be on the incorrect input. Inputs get changed when switching the TV input for dvds or video game consoles. Look for a Source or TV Video button on your TV remote, not the cable remote. Before doing this, please make sure all connections are secure. I hope this helps or reply with more questions.
Jul 26, 2016 | Mitsubishi WD Televison & Video
I have a WD-73642 tv has no picture but has sound
I had this problem with a laptop of mine it's the led just replace the screen
Mar 21, 2016 | Mitsubishi Digital Television Mitsubishi...
I HAVE MITSUBISHI WD-73640 AND ITS SHOW THE GEEN LIGHT BUT DOESN'T HAVE PICTURE OR SOUND
The first thing to replace is the lamp. Google your model number and "lamp" and you'll find several sites that sell them. It isn't difficult to replace yourself and isn't very expensive. Good luck.
Sep 25, 2014 | Mitsubishi WD-73640 73-Inch 1080p...
Looking what i can do to fix. Have a Mitsubishi TV 3D DLP WD-73640, Replaced bulb, and still have the red LED flashing 6 times to the Yellow led flashing 1.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Check the lamp ballast too.
Aug 14, 2014 | Mitsubishi Cinema WD-73640 73" 3D DLP...
Blinking yellow light on Mitsubishi wd 57731
Based on the service manual:
Blinking yellow= Lamp cover is open.
It could be something else!
www.aaatvservice.com
Aug 09, 2014 | Mitsubishi WD-57731 57" Projection HDTV
Why is tv blinking 4 red lights and 8 yellow lights
An error code of 48 indicates a main power board failure. There is a short down the 3.3v or 5v switched supply.
recommend replace main power board.
part# 934C409001
see the following website:
http://www.shopjimmy.com/mitsubishi/wd-73c11?cat=59&q=WD-73C11&tv_models=Mitsubishi+WD-73C11
Jul 01, 2014 | Mitsubishi WD-73640 73-Inch 1080p...
White lines that are constantly on will go away for a few seconds then pop back up.. Mitsubishi 73" model number WD-73640
You need to replace the 4719-001997 DLP Chip. this should solve the issue.
This chip can be expensive so look around before you purchase. This is a common problem with these TVs, both white lines and white dots. You can find out how to replace the chip by going to this website: http://www.fixyourdlp.com/2012/09/04/solve-the-mitsubishi-wd-73640-white-dot-problem-with-a-new-4719-001997-dlp-chip/.Hope this helps
Feb 27, 2013 | Televison & Video
Mitsubishi WD-73640 Logo
63 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
