E4 code is on my heater - Heating & Cooling
E4 error code beautyrest electric blanket
beauty rest electric blanket error code - akaQA
www.akaqa.com > Uncategorized
beauty rest electric blanket error code. What does error code E4 mean? Answer this. 0 Views: 2487 Answers: 1 Posted: 3 years ago. Comment this question.
E4 error code beautyrest electric blanket - Fixya
www.fixya.com/support/t22178587-e4_error_code_beautyrest_electric
Dec 13, 2013 - E4 error code beautyrest electric blanket One side works the other returns an "E4" error code - Simmons Beautyrest Microfleece question.
Dec 13, 2013 | Simmons Beautyrest Microfleece Electric...
Dyson AM04 error code E4 any suggestions
E4 and E5 codes explained finally! E4 means motor is not spinning right, or reaching correct RPMs. E5 means heater in not working right. I will provide more detains next.
I had an AM05 which stopped working and it was showing E4 fault code and power light was blinking red. Occasionally as I turned it on motor would spin up for a second and then stop and fault code would display. Most of the time motor did not move. WARNING! I am an electrical engineer and have fixed countless things in my life, and I can say, taking this unit apart and putting it back together was very difficult. Do it at your own risk and of course, MAKE SURE POWER IS REMOVED WHEN WORKING ON IT.
First, remove the base ring and remove big screw in the middle. Next, disconnect the plastic white ring connected to the oscillating motor drive shaft. This requires removal of a C-Clip. (don't lose it, as it's likely to fly when being removed). Now pry apart the bottom section from the rest. Be careful as there are connecting wires all still there. Next, tilt the fan forward all the way and that will expose 4 screws in the rear, and when tilted the other was, two screws in the front. Remove them all. Now, disconnect connectors and start separating parts. Here are a couple of pictures I had taken.6da61f48-67d1-449b-a6d2-72e4af5aae9c.jpgdyson-am04-error-code-e4-any-suggestions-4e2m4lzwxx0at01yzka4mbe1-2-2.jpg
Of the two identical 6 or 7 pin connectors one has all red wires and the other is multicolor. When I disconnected the red one, the fault code went to E5. The red one goes to another board that has the heater circuit, so I deducted that E5 means either connections to the heater are bad, or heater is bad. I reconnected the red one and E4 came back. I disconnected the multicolor one and nothing happened, which told me the problem is there. I traced the wires and they were all going to the motor, which is further up the assembly. Getting to it was a real pain. To free the multicolor cable, you have to separate two rubber seals that allow the wires to move through an opening. If you can manage this, you can slowly get to the motor. When I turned the impeller I noticed that it was dragging, which explained the E4 code. When I turned it upside down motor spun freely and the fault code went away. So, I knew I had to fix the dragging problem, which was easy. Then putting it back together was a real pain. I recommend taking lots of pictures to remember what came from where. NOTE: There is thermal grease inter a metal heat sink. Make sure you don't wipe it off. It's essential, or heater semiconductors will overheat and fail. Also, MAKE SURE WIRES AT THE BOTTOM SECTION NEAR THE SWIVEL MECHANISM ARE DRESSED AS THEY WORE ORIGINALLY! Otherwise, they will rub and cam cause a fire. As you probably already know, there was a recall on these.
Anyway, hope this helps people. I have gotten so many great tips off the internet, I figured I had to contribute some as well.
God Bless.
May 01, 2013 | Dyson AM04 Hot Cool Heater/Table Fan -...
My Soleus Air HM2-15R-32 displays an E4 LED when turned on. How do I reset the code.
try unplugging it from the wall for 15 seconds and then plug it back in.this normally works for me.if it doesn't work then let me knoe
Jan 23, 2013 | Office Equipment & Supplies
The Thermal fuse of the defrost heater in my freezer is tripping.
what is your controller? replace fuse if needed,review your control parameter and find the e4 means.
Dec 05, 2012 | Refrigerators
E4 code on a bosch ghw 715 control unit
Before calling service technician, open following link for Bosch troubleshooting resources:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Error codes are starting point for troubleshooting, and solutions vary by model and unit.
E4 is Backflow temperature sensor over 309 degrees F. Appliance will close burner and lock.
Check combustion air and backflow vent piping for blockage.
Check if secondary fan connections are disconnected.
Check venting specifications are met. Long vent lengths, venting with more than three elbows, blocked vent or combination venting may cause this failure.
Check sensor resistance
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 29, 2011 | Bosch ProTankless GWH 715 ES LP Tankless...
We are trying to find out what an E4 on a Celiera
Does anyone know what does that means
Mar 30, 2010 | Heating & Cooling
Heayrt won't fire e4 can't hear fan runnung
I am not sure if you have gotten this issue corrected, or not, but the first thing I would try to do is to reset the heater computer system. This sometimes corrects and EO4 error code.
What you will do is open the right hand side door and find the POWER toggle switch, turn that off. Then find the CIRCUIT BREAKER for the heater and turn that off as well, then wait about 15 to 20 minutes. After waiting, you will turn the CIRCUIT BREAKER on first, then the heater. Try and start the heater up.
If the EO4 code comes back, there may be an issue with the heater. If the code does not come back and the heater starts, then the error code was what I call a "computer hic-cup".
Jul 04, 2009 | Pentair MINIMAX NT TSI IGNITER
Panasonic copier DP8530 has a E4-02 code.
hi i am working on panasonic copiers.E4-02 this code shows there is some problem in fuser unit
1.pull out side fuser unit from copier
2.check it is movig easily
3.check all gears
4.check thermostate and thermistor
5.bearings and seals
6.for to reset heater codes press function, orginal size,3.F1 will display press 9 ,06(ram initialize) sub code 04 start .fuser code will bi reset.
was it helpful .not forget to rate me .MIAN AKHLAQ
May 08, 2009 | Panasonic DP-8035 Grayscale Copier
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
