Question about Sony Televison & Video
Sony kdl46w5150 still dead set after power supply replaced
    Top Expert:
  • Sony Master
  • 75,320 Answers
Fault at its main digital board. No startup signal from it to the power board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Posted on Dec 09, 2016
2 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: Dead set
Do what should have been done first: follow the voltage in and out of the power board and measure at turn on---too many people guess and buy a board and try it--dart game.
Posted on May 14, 2012
2002 36" Sony Trinitron XBR High Def TV. When you
Your power supply board is dead, do you know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem..
Aug 05, 2011 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
My sony bravia 46" it wont continues to turn
power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Take care in solving the problem....
Jun 21, 2011 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
Sony kv32v15 is dead with no sounds are lights. How difficult is it to replace the power supply / power management components?
since the problem is dead set all you need is open the back cover to trouble shoot, use digital tester. check blown fuse and then power on the unit check the output voltage at power supply panel board which supply the main CRT chassis board. if no output voltage check open fusible resistor its about .1 ohm, then check shorted rectifier diode and transistor sometimes cause by voltage fluctuation. just consider also the horizontal out put transistor it might be shorted cause by over current coming from power supply.
Apr 17, 2011 | Televison & Video
Sony tv won't turn on... When I hit the power it kicks in for seconds. the green light flashes four time then red flashes three times.
Tries unplug,replug tv back in an hour later,let the tv reset itself back to factory setting.The tv should work now.Not than the power supply board it dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sep 15, 2010 | Sony Televison & Video
Sony bravia goes into standby and flashes 13 times
Tries unplug,replug tv again an hour later.The tv now is resetting back to factory setting.Tv should work now.Not,than the power supply board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sep 09, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Stand by button flashes after turning on TV
Ur power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get ur tv power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Good luck...
Aug 08, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony kdl46w5150 with external antenna dropping signal on some channels
1. Check for any loose connections starting at your TV. (Coaxial cables unscrew themselves with vibration...) Check all outdoor connections for corrosion and cut off and replace any cable ends that show corrosion.
2. Check your alignment - (positioning or pointing)
http://www.wowvision.tv/OTAalignment.htm
3. Replace the balun a.k.a. 75 ohm matching transformer.
If these don't work, a larger antenna is needed...
with one exception:
That exception is if your signal is too high. If this is the case, change alignment to reduce signal a little.
Jun 11, 2010 | Sony Televison & Video
The screen goes blue and the set shuts off
hello,
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Power supply board have problems,just not dead yet.Replaced the power supply board,will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 25, 2010 | Sony KP-51HW40 51" Rear Projection...
Dead set no standby light power ok up to
Could be anything! From a main board to a power supply. I recommend getting service on it from a authorized sony service center. If standby light doesn't appear at all for any given time, then it maybe the power supply.
Jun 23, 2009 | Sony Bravia KDL-42V4100 42 in. LCD TV
Orion FTDV 2004 Dead Set
Question, when I clicked on this I clicked on a problem for a Sony KV27S10 but your text say's Orion, is it a Sony or a Orion?
Aug 18, 2007 | Sony KV-27S10 27" TV
Televison & Video Logo
24 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
