Question about Logitech LX 710 Keyboard/Mouse
How can I clean the rubber part of this keyboard? It's gotten sticky and dust collects to it.
The "rubber" is just a thin coating (at least on my diNovo Media keboard). It gets sticky over time and can be removed completely with isopropanol (2-propanol) and paper towels. The alcohol can be purchased at your local pharmacy.
You have to be patient, it takes some effort to fully remove it.
Posted on Oct 03, 2012
  • 118 Answers
3 parts water 1 part dish soap should do the try with out ruining the keyboard cloth should be damp not soaking wet.
Posted on Jul 21, 2009
In my laptop some keys are not working
Probably that is a result of sticky dust particles under the keys of your keyboard. Get your computer to a computer technician to open it up and blow and clean the dust off. The cleaning should be done using benzene
Dec 15, 2011 | Toshiba Satellite M45-S331 Notebook
The keys stick and/or skip
Use a small screwdriver to gently pop the sticky keys off of the keyboard. You do not need to use excessive force, as a bit of gentle pressure should allow the key to come loose easily. If you are cleaning the entire laptop keyboard, draw a keyboard map on a piece of paper so that you know exactly where each key goes. There may be a small piece of rubber connected to each key, depending on your make of laptop, so remove these as well and place them in a small container, as they are small and easily lost.
2 Clean the exposed area under the key well with a cotton swab slightly dampened with rubbing alcohol. Replace the cotton swabs often as they collect residues, but be sure that they are only very slightly damp, as excess liquid can damage the keyboard. You can roll the swab against the opening of the alcohol bottle to remove excess liquid making sure that alcohol does not drip from the swab.
3 Scrub the actual keys and their rubber components with cotton swabs and alcohol, removing all traces of grease and sticky residue. Spray the keys with standard household cleaner and allow them to set for at least five minutes before rinsing them thoroughly with hot water. Put the keys on a paper towel and allow them to dry completely.
4 Set the rubber components aside and place the laptop keys bottom side up on a paper bag. Coat the keys very lightly with film lubricant and allow them to dry. Make sure that the lubricant covers all of the small guide spaces inside of each key; however, you must be careful not to use too much lubricant, as the solvent can damage the plastic.
5 Apply a small amount of solvent to the tip of a cotton swab and lubricate the exposed key space on the keyboard, again being sure to cover all of the small spaces. Allow the keyboard to dry thoroughly.
6
Replace all of the rubber components into the keyboard and then install the keys. Make sure that the wire is placed into the guide slot next to the key and apply firm yet gentle pressure until the key snaps into place. Congratulations, no sticky keys!
May 20, 2011 | Toshiba Satellite L675-S7048 Notebook
My keyboard is not responding to all characters when I type and I have to continually press some keys to get a result
Sometimes you may find certain keys of your laptop keyboard not working properly. You type those keys but there is no output on the screen or you need to press these keys firmly to get a result. You face this problem if you accidentally spill any liquid substance on your keyboard, or due to dust accumulating on the inside of the keys, pressing certain keys really hard while playing games or even due to absence of lubrication. Therefore you are suppose to maintain your laptop keyboard by cleaning and lubricating it regularly.
INSTRUCTIONS
  1. To start with, take out each key out from the laptop keyboard. Use a small screwdriver to carefully pry each key by making it loose. As they become loose, keys will simply pop off. Also, take out the rubber piece present under every key. Keep the keys and rubber pieces in different containers.
  2. Once you have removed all keys from the keyboard, you will have to clean the keyboard from the inside. Use cotton swabs or ear bubs and slightly dip them in water. Avoid getting them too moist, as excess water can damage the keyboard. Meticulously clean the whole keyboard using moist cotton swabs, laying extra emphasis on key spaces.
  3. Now, start cleaning keys you had earlier removed and kept in the container. Use foam rubber and lighter fluid to clean each key alone. This will help in removing any sticky substance present on keys. Apply any household cleaner on these keys and let them stay for about 15 minutes. After this, wash all the keys properly using hot water and let the keys dry completely.
  4. The small rubber pieces which you took out earlier and kept in the container have to be thoroughly rinsed in warm water, after you have sprayed a household cleaner on them. Soak these rubber pieces up in paper napkins so that they dry quickly.
  5. To lubricate the keys, place all keys (facing top-down) on a flat surface. Apply mild lubricant from all sides, on all keys and leave them to dry. Avoid applying too much lubricant instead go for a light coat.
  6. Similar to the manner in which you lubricated the keys, apply mild lubricant on the keyboard surface and let it dry.
  7. Once you have cleaned and lubricated all the parts, carefully reassemble the laptop keyboard. Begin with placing all rubber components on the keyboard. Next, fix all keys in their respective positions cautiously securing the wire in these keys. Use your finger and press down all keys, one at a time, firmly so that they fit properly in the slots. That is it.
  8. goodluck
Mar 30, 2011 | Microsoft Multimedia Keyboard/Wireless...
Icant.press.the..space..bar
assume this is an acer laptop keyboard?
Sticky key: gently remove the space bar noting how the retaining clips fit. Clean under the bar and around the rubber buffer with isopropyl alcohol or similar, test before refitting the bar, if this does not resolve the problem, you may be looking at a partly damaged keyboard and will need to replace
Jan 27, 2011 | Acer NSK8458AN Keyboard
Whenever I press the NumLock button, it does a sticky key-type beep and the green LED comes on but I am unable to use the keypad still. The same thing happens with the CapsLock key but I am able to use...
Hello
In control panel/keybaords. Disable sticky keys.
Or clean the keyboard with some windex and a rag,try turning it upside down and lightly tapping it to remove dust and dirt.
Jan 08, 2011 | IOGear GKM502 Keyboard and Mouse
Beer spilled on my keyboard so they feel really sticky. How can I clean it?
This will require about 2 hours time once you have collected the proper cleaning materials.
  • Cleaning materials:
  • Cotton swabs
  • Cosmetic foam rubber cleaning pads ( use only with naptha (lighter fluid), NOT alcohol)
  • Paper towels
  • Rubbing alcohol
  • Water
  • Lighter fluid (naptha)
  • Fine tipped tweezers
  • Scissors
  • Kitchen strainer
  • Household cleaner, Windex or equivalent
  • Super Lube Dry Film spray (critical - DO NOT SUBSTUTUTE !) K-Mart automotive.
  • This is a PTFE (teflon) based lubricant which dries perfectly DRY and is ideally suited for this application.
Proceed as follows: DISASSEMBLE
IMPORTANT: Make a keyboard map so you know where each key goes.
Carefully pry each key loose with a small screwdriver and place in a container. They pop off. DO NOT use excessive force. There may be a small rubber piece for each key. Remove all of these and place in a separate container. CAREFUL, these are small and like to jump away.
CLEAN KEYBOARD
Clean the keyboard with cotton swabs SLIGHTLY DAMPENED with water. Replace these often and BE SURE they are only slightly damp. If they are too wet the excess water will contaminate the keyboard through capillary action. This will clean all water soluble contaminants like Coca-Cola, coffee, and sugar residue. For the very small places, cut the foam rubber into small pieces and use the tweezers, again SLIGHTLY DAMPENED, for cleaning. You must clean each and every key space, inside and out, this is critical since this is where the key touches and moves.
Repeat this procedure again using rubbing alcohol and cotton swabs but NOT the foam rubber as it disintegrates when used with alcohol.
Finally repeat this procedure using naptha (lighter fluid) and foam rubber. You can clean even the smallest key guides with small pieces of foam rubber and tweezers. This action will remove any petroleum based contaminants as well as the grease that is sometimes used on the wider keys which may have guide wires, for example, the SCACE BAR.
CLEAN KEYS
Some keys may have wires attached and some grease on them, clean these first with cotton swabs and naptha (lighter fluid). Remove all traces of the grease.
Place all keys in a kitchen strainer. Spray with household cleaner and let stand for 5 minutes. Rinse thoroughly with hot water and place keys on paper towels to dry. Let dry completely.
CLEAN RUBBER COMPONENTS
Place all rubber components in a kitchen strainer. Spray with household cleaner and let stand for 5 minutes. Use stopper in the sink so that you don?t lose these if they jump out of the strainer. Rinse these thoroughly with hot water and place on paper towels. Fold the towels over and press to squeeze most of the water out of the pieces. Let dry completely.
LUBRICATE KEYS
Place all keys bottom-up on a paper bag. Lightly coat the keys, at a 45 degree angle with Super Lube Dry Film lubricant. Do this from all 4 sides to assure penetration and coverage into the small and critical guide spaces inside each key. Let dry ( this happens nearly instantly). DO NOT overdue this step as the carrier solvent may affect the plastic.
LUBRICATE KEYBOARD
Mask off the laptop with paper and scotch tape. Apply lubricant (as above in LUBRICATE KEYS) to the keyboard and let dry.
All right, you now have perfectly cleaned and lubricated keys, keyboard, and rubber components.
REASSEMBLE
Place all rubber components into the keyboard.
Install keys with wires. Make sure wire is secured in the key, usually snapped into place. Place ends of wire in the guide slots adjacent to the key location as you align the key. Firmly press down to snap the key into place.
Install the rest of the keys by aligning and firmly pressing down.
Oct 30, 2010 | Dell Studio 17 Laptop
I have ASUS EEEPC 1005 HA Yesterday the character that comes after "A" stopped working . I have tried to open it, tried to get rid of the dust even put some WD 40 on the key too , its not jammed,...
Carefully pry up they A key.
You will see a little rubber thingy under the key, pop it up and you will see a little circuit board under where the A key was located.
Very gently clean SOME of the gunk off the circuit board contact, while keeping the circuit board undamaged (I usually find a nice new rubber pencil eraser works fine for this task).
Then gently wipe the bottom of the little rubber thingy off with a piece of printer paper (you are going for keeping the black on the rubber thingy but the sticky gunk off)
Then replace the rubber thingy and the A key and give it a go,
If that does not help then yes you will need a new keyboard. You can also disconnect the ribbon cable that goes to the keyboard and connect an external usb keyboard and try that to get you by.
Sep 02, 2010 | ASUS Eee PC 1005HA-PU1X-BK Netbook
How do I clean Kens. orbit 6221 inside so will move cursor reliably again?
I use q-tips and rubbing alcohol along the rubber rollers.  you have to be pretty diligent in keeping this clean...as ALL the gunk and oils from your fingers go on the orbit ball and collect up on the rollers.  You can use a can of air to spray out the inside from dust.  For random stuck bits of hair etc in the rollers, use tweezers but if you tweeze something off the rubber roller you MUSTTTTTTTT be super careful NOT to gouge the rubber.
Jan 04, 2010 | Kensington Orbit 64226 Trackball
Microsoft mouse wheel sticky
yes it is possible but be careful doing so. There are some very tiny springs and some very delicate metal wheels and such inside that can be very easily bent. I would suggest a can of compressed air blown in and around the wheel to try and dislodge any dirt or dust that has gotten in there. You can usually find a can at staples or even home depot.
Dec 20, 2008 | Microsoft MOUSE Wheel INTELI EXPL OEM TIL...
Logitech LX 710 Keyboard/Mouse Logo
2,162 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
