Question about Sony DAV-DZ175 DVD Home Theater System
Will sony DAV-DZ175 have sound if i dont have any original speakers ? Couldnt it play through tv like regular dvd player
  • Sony Master
  • 5,455 Answers
If it has an HDMI out socket on it it should connect to the TV that has an in socket.
Posted on Dec 10, 2016
  • 28 Answers
SOURCE: Sony DAV SA30 dvd player
Hi From the symptoms, you mentioned, ie playing CD's ok., Mpeg decoder chip is faulty. The new one supplied is a modified type. IC207, part no.6-707-406-01. Good luck. Capital98
Posted on Feb 14, 2007
Doodad
  • 64 Answers
SOURCE: How to get sound through speakers with tv and not just dvds
Just wire your TV audio out to one of the receivers (DVD player) audio in and select AUX when you want the TV sound to play through the surround sound. You also might want to turn the volume down or off on your TV to get the full surround sound feeling, but that's your call.
Posted on Jan 06, 2008
  • 16 Answers
SOURCE: sound not loud Sony DAV-IS10
I think its the fact that the speakers are pretty tiny, even tho BOSE has proved that size doesnt matter. i will agree i have a descent size home and i have to max it out all the time to watch a movie
just a design flaw IMHO.
Posted on May 09, 2008
petraman7
  • 1175 Answers
SOURCE: how to make sony dav-s300 dvd player multi region
Do you have the manual?
I'd check there first. You'll probably need the remote as well.
Posted on Jul 07, 2008
  • 4 Answers
SOURCE: sony compact AV SYSTEM DAV-S400
Hi Joey - I had exactly the same problem.
In my case, I followed the advice of others and took the thing apart. On the main amp board there is a large brown capacitor. Mine had come completely loose, so I soldered it back in place with a good amount of solder to make sure the contacts were ok. I also dabbed some solder on the headphone connectors on the same board (just follow the wire from the headphone socket to the board). Well, when I put it back together and tried it again everything worked perfectly, and it has so far remained free from the error. Hope that helps !
Posted on Nov 27, 2008
Hook up new blueray thru old home theater system
Yes you can. If you have more than 1 HDMI sources and your old system only has 1 HDMI in, you may want to invest in an HDMI switch. They are inexpensive (under $20 on Amazon) and let you choose 4 HDMI sources to feed your system. The audio is embedded in HDMI and you may have to select the choices (surround versus stereo) when you play the disc.
Dec 25, 2012 | Sony DAV-DZ175 DVD Home Theater System
My Sony dav-dz175 restarted and only blinks please wait for hours never anything else
Try a cold reset as described here:
http://www.manualowl.com/m/Sony/DAV-DZ175/Manual/116362?page=64
Nov 19, 2012 | Televison & Video
55HDX99 TV with Sony DAV-HDX500
Connect RCA Red-White audio cable to INPUT of DAV-HDX500 and hook it to TV AUDIO OUT pins at back of TV.
Now select INPUT in DAV-HDX500 to get TV sound in Sony system speakers.
Apr 19, 2009 | Televison & Video
Cannot hear regular tv through speakers
you need to purchase either rca cables or optical cable
Jan 18, 2009 | Sony BRAVIA® DAV-HDX279W Theater System...
Sony Model DAV ? SB 500W Home Theatre System
Please check at rear of TV for Digital Optical IN port as home theater should have optical out port at rear. If you got any optical in port in TV, just connect optical wire between TV and home theater.
2nd option is check Line Out pins at rear of home theater system, if found, hook red-white RCA cable there and put it to same input in TV where you hooked Video (composite or component) cable.
Let me know the results to help you more.
Jan 07, 2009 | Sony DAV-SB500W System
Panasonic 50? Plazma TV TH 50PZ 800A + Sony Model DAV ? SB 500W
that is possible
the home theater has so many in puts on your dvd and out puts.
there is a way
1 you can buy a vedio/audio converted to rf signals, this will mean both signals entering tv using rf.
2 get your vedio out from dvd and audio out, feed that to a converter, vedio in and audio in okey
How do you get DVD player SOUND to play through the TV speakers
plug the stereo headphone jack to your dvd headphone output then connect it to your tv audio/video in and press the tv/video switch in your tv remote control.
Volume Problem with my TV and Home Theater system
I had the same problem with mine.The solution I found was to use an optical audio cable rather than the red and white RCA audio jacks. Hope this helped.
Dec 23, 2008 | Sony BRAVIA® DAV-HDX576WF Theater System...
Component Video Connection
what you have done is you are sending a component video signal from your system to your tv and the sound i assume comes through the 5.1 surrond speakers. The DVD's you play the sound would naturally come from the 5.1 surround speakers, unless your instruct the dvd player to send the sound to the tv in which case will only be played as stereo. you will need inputs on your dav system to take sound from your tv outputs or digital box by way of red and white phono leads or a digital/optical input if you have them; so as to play the sound from cable tv or sattelite tv through your 5.1 surround speakers.
Sep 04, 2007 | Sony DAV-SC5 System
Sony DAV-DZ175 DVD Home Theater System Logo
96 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
