While in ac if we have an electric blink the unit defaults to heat and i have to go though setup
  • Darwin Strouse
    Darwin Strouse Dec 09, 2016
    bryant evolution control systxbbuid01 b
    Top Expert:
  • 12,804 Answers
What is your question --if that is the design default after power failure then that is set by the company for a reason
Posted on Dec 09, 2016
Lights are blinking
What is the make / model of your air conditioner. With out that information i cant help you with your ac repair problem. If you need any other AC Advice. Check us out online. WPB AC Repair Company .
May 14, 2016 | Heating & Cooling
My Honeywell Themostat is no longer controlling the systems after a battery change, but otherwise looks fine. Help!
The replacement batteries could be defective or installed incorrectly. Also, if the thermostat has to be removed from its mounting base for installation of replacement batteries, it may have been reinstalled incorrectly.
Nov 07, 2015 | Honeywell Heat/Cool Thermostat
True air heat tries to start then goes to gas.It worked fine in the fall but it is now -5F
Do you have a heat pump and gas furnace setup? Or is it electric and gas setup.
To me it sounds like either configuration issue its electric and gas, but if its heat pump/gas the furnace is defaulting to gas more then likely on the outside air temperature, usually most heat pumps only heat good down to 10 degrees F.
Nov 18, 2013 | Coleman Heating & Cooling
There is a red light in the AC i cant get rid of, its blinking!! and thats makes the air HOT how can i fix it???
Ah the blinking thing. Is the Ac in heating mode? Is it a heat pump? I ask because often if it is classified as a heat pump it may default to a heat mode, not a cool mode. The reversing valve may be faulty, the flashing light is telling you that there is a fault, or maybe it is saying the machine is in standby mode. More detail will help. A process of elimination is needed
Feb 24, 2011 | Heating & Cooling
I woukd like to have my heat electric, right now its gas and the AC is electric. I have added heat strips to an AC unit before but am not sure if i can with this one. They both one on one thermastat. Am i...
Depending on the unit it might be possible but the 1st thing you have to do is change the wire to your unit probably to # 6 depending on the KVA rating of the heat strips. Your unit because it's gas it is wired only for 20 or 30 amps & most electric strips are 60 amps.
Oct 04, 2010 | Heating & Cooling
A/c heating unit- blower works with no ac or heat
You did not say if this is a standard htr/ac or automatic temp control. Sounds like the temperature motor is failing ( automatic Temp Control) You can get to this through the glove compartment, though it is hard. The motor sits on top the plenum (4 8mm screws). remove and replace. You will need to break the case to remove one of the screws. It will not hurt anything just be sure to break small pieces ,just enough to remove the screws.
Apr 26, 2010 | 1997 Mercury Grand Marquis
When we turn on our split AC, outside unit is not turning ON
The blinking light is because the unit is waiting for the outdoor unit to come on. If in heating mode, the indoor fan will not run before enough pressure and therefore heat has built up. You should check that the indoor air return sensor is not faulty and therefore preventing the outdoor unit from coming on.
Nov 15, 2009 | Amcor NanoMax A12000E Portable Air...
I just had new vents run in the basement and even though they are closed, it will not cool the upstairs. It is 80 degrees upstairs. What is the problem?
First when you add new vents make sure your unit is big enough to handle the extra load. If you have shut off your vents to the basement. and it does not cool you may have AC problem. Sounds like you need to get it checked. Ask for a free estimate before you commit anything. Remember if they add gas you have a leak and it should be found. Rus When your ac does not cool properly check filters float switch in unit. Breaker on outside unit. Take a thermometer and take a reading from the reurn to the closest vent you should have between 17 and 21 degrees diference across the coil. If you have electric heat or heat pump you may need have a heat sequencer stuckmkeeping part of the heat on during cool.
Jun 26, 2009 | Carrier 38CKC042 Air Conditioner
Goodman PC060-1B Package AC...Need Wiring Help
Depending on the size of your Electric heat you can use one set of wires because your unit does not run with the heat like the heat pump. The large set of wires going to the electric heat should be used. You may have to jumper a new set to the contactor. On Goodman unit come in L1 and L2 jumper to contactor. Very simple good luck. Rus
Jun 21, 2009 | Goodman Heating & Cooling
Unit will not turn onto AC
Heating element is burned out
Oct 20, 2008 | Dometic NDR 1292 Refrigerator
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
