Question about Whirlpool Kitchen Ranges
My mom had bought accurate whirlpool stove, the stovetop seems to have the porcelain worn off, especially around the 2 front burners, is it a defect, what can we do to it.
    Top Expert:
  • Whirlpool Master
  • 12,761 Answers
How old is the unit --porcelain does wear down also spills such as sugar syrup causes stains --if new return and or replace under warranty
Posted on Dec 09, 2016
Where can I buy the stovetop burner gaskets?
  1. Gaggenau Range/Stove/Oven Parts - RepairClinic.com
    www.repairclinic.com/Shop-For.../Gaggenau-Range-Stove-Oven-Parts Huge selection of Gaggenau Range/Stove/Oven parts in stock. Same day shipping. Open 7 days a week. ... Door hinge, top/bottom. OEM Part - Manufacturer # ...
Jul 11, 2015 | Gaggenau Cooktops
What is the advantage of gas range than gas stove?
There is much confusion about those terms, especially when used by suppliers / online webshops. A great indepth article about the issue can be found here: http://www.ebay.com/gds/What-s-the-Difference-Between-a-Stove-and-Range-/10000000177628290/g.html
Below is - imho - the most related paragraph:
'Many people use the terms oven, stove, and range interchangeably. However, buyers that plan to purchase a stove or a range should understand the purported meanings of each of these common words. First, the term stove technically refers only to the stovetop, which includes a number of burners (typically four to six) and is used for surface cooking such as boiling, frying, pan-searing, and other methods. The oven is an enclosed device that is used for baking, broiling, roasting, and other cooking methods. It employs concentrated heat within the enclosed area, which is usually delivered via heated coils in the top and the bottom of the stove. The term "range," as defined in Webster's Dictionary, actually refers to the combination of stovetop and oven into one kitchen appliance.'
Hope this helps :)
Jun 27, 2014 | Whirlpool Kitchen Ranges
I have replacedsurface unti terminal block with kit supplied by whirlpool part dealer. Though all other burners work on stovetop, the large burner still won't heat up. I alsp bought brand new element from...
Good morning,if you've replaced the burner and block and it still isn't heating,you definitely have a bad burner switch. On an electric stove you have two lines of 115 volts going through the switch to the burner. If one of the lines through the switch has burnt out,you may still get the burner on light. Hope that helps.
Jun 05, 2017 | Whirlpool RF302 Electric Kitchen Range
Stove won't work. Stovetop burners are fine but
if this unit is equiped with a electronice control board then you need to check the power coming from the board to the ignitor.most cases replaceing this board will solve your problem
Mar 04, 2010 | Kitchen Ranges
I need to replace the glass cooktop on my Maytag electric stove
  1. Open oven door and remove two screws that secure top.
  2. Lift up front and slide forward about 8 inches so that you can disconnect two wire couplings.
  3. Place on table upside down(I put newspaper down to catch the broken shards of glass) and remove burner unit (1piece, 4 screws).
  4. Place old burners on new stovetop in the same position as original.
  5. Remove 4 white plastic shims (round) from old stovetop and put on new stovetop.
  6. Tighten all screws and then sit it back on stove (two front tabs fit into slots) and then insert screws into holes and tighten.
  7. Took about 20 minutes, including vacuuming broken glass from inside burners and cleaning grease form crevices between burners and old stovetop.
  8. Wrap old stovetop in the newspapers that are underneath it and place it all in a plastic garbage bag to avoid any broken glass from falling out.
Jan 21, 2010 | Maytag MER5775Q Electric Kitchen Range
The right front burner on my Mom's Frigidaire FEF316(I think, the # is 316232636) does not work. She heard a pop and saw a flash under the stove top near that burner when she turned it on. I switched the...
The recepticle that the burner ends plug into get worn and loose. This will cause arching and that may be what she saw. OR, there could be a wire loose under the stove top feeding the burner. Lift it up and give it a good inspection (with the breaker off). You may need to replace the burner recepticle.
Aug 01, 2009 | Frigidaire FEF316 Electric Kitchen Range
Want to clean under stovetop
Hello
welcome to Fixya,
This stove has sealed burners and there is no need to lift or clean under anything except the burner caps.
You can not get inside the top and you can not lift the top like the old pilot stoves!
When you clean the burners and around rings do not spray or saturate the are and or the igniter element that creates the spark.I'll be back in a moment with your user manual.
first what is the complete model number of your range as written on the sticker in the door jam of the storage compartment down below. left side!
Huuum
Dec 15, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Hello, I have a Frigidaire freestanding crown series gas range that has two problems. The most important being that the oven does not light. The stovetop lights, except one burner that you hav to light...
I figured it was the ignitor given the burners work fine and I could smell gas from the oven when I would try to turn it on. So I found a local parts store and bought the replacement ignitor. I cut the wires of the old ignitor close to the ceramic and spliced the new one on with porcelain nuts and voila my oven now works again!
Nov 18, 2008 | Frigidaire Kitchen Ranges
SMOOTH COOKTOP DISCOLORATION
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
This stuff really works!!
Aug 12, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Kitchen Ranges Logo
50 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
