Question about Quad Cycling
I have 49cc quad and my flywheel will only half turn and then it's getting jammed can u help me please ?
3 Suggested Answers
Nickinfuts
  • 13 Answers
SOURCE: i cant get my kids 49cc quad to start from
Check for spark, there may be a "Kill Switch" or a key somewhere that needs to be turned in order for the motor to run. If you turn the motor over with a spare spark plug in the plug wire touching the tip of the spark plug that is in the motor it should show a spark. (It is best to do this in the dark to see the spark clearly)
Look for a fuel valve that shuts off the flow of gas typically located between the gas tank and the carburetor. Some carburetors have a float bowl drain at the bottom so you can drain the gas out for storage. If your carburetor has a drain bolt you can unscrew it and see if gas comes out.
Check for a choke lever or pull knob either on the carburetor or sometimes on the handlebars. I have also seen a primer bulb on the two stroke carburetors that act as a fuel enrichment for starting a cold motor.
Since it is new we can assume it has compression but it doesn't hurt to check it. Remove the spark plug, place your finger over the spark plug hole and turn the motor, if there is good compression your finger will pop off from the pressure.
If you have good spark, good compression and gas in the carburetor bowl chances are your carburetor jets are clogged. I would spray a small amount of starter fluid or a small squirt of gas into the back side of the carburetor after removing the air filter. If it runs for a few seconds then stops the problem is in the carburetor but most often the motor will continue to run and just needed priming. If it does not run on it's own there might be some debree in the float bowl obstructing the delivery of fuel but that is very rare for a new carburetor
Posted on Dec 29, 2009
SOURCE: i am not getting any spark on my 49cc mini quad and it would not start
check the spark plugs, the carb
Posted on Jun 29, 2012
How do I fix my 49cc 2 stroke pocket quad it has
If you have replaced the spark plug then the possibilities are the ignition coil is weak or the starter mechanism is faulty.
See this site for details of parts.
Mini Atv Quad Parts 47cc 49cc Stock Replacement
Sep 15, 2014 | Quad 47 cc / 49 cc Pocket Mini Bike...
My 49cc wont fire over
My 49cc 2 stroke pull start scooter wont turn over
Aug 19, 2012 | Quad 47 cc / 49 cc Pocket Mini Bike...
I have a 49cc mini quad and when it start it excelerate all by itself with out me giving it and trottle please help me
sounds as if your throtel cabel is snaged or damaged easy fix discoect from thum switch and try again good luck
Jul 25, 2012 | RTO Mini Quads
I have an 49cc ATV midi quad bike and it will not start at all. Have changed the flywheel and pull cord and carb, but still have no joy. Have used easy start too! please help, had it over a year never bin...
I had this same problem. I had a very hard time to start this quad untill i was told to make sure the fuel filter is half full with gas. Which it wasnt getting gas through the filter. So i went down to our local dealer and purchased another filter. The new filter was getting gas this time but the quad still did not start. So i was told to take the throttle cable off the engine and pur gas right in the hole, but the cable back on, Put the choke on full make sure the gas valve is turned on and fire it up. it started right away. But i had to repeat this a few times. But works now
Ed
Jan 09, 2011 | Razor Dirt Quad Bike
My 49cc quad bike is new wont start have changed the coil and plug but no spark tried diconnecting the kill switch
Maybe re-check the gap between the coil and the flywheel? x2 business cards is a good gap for those.
May 12, 2010 | RTO Mini Quads
2 stroke 49cc quad engine dies when i accelerate
well it is 2 stroke so if its rev'in slow thats not dunna help . my sister had one and its the kind of thing that u don't let it idle just keep it going. thats what i found best
Nov 01, 2009 | Razor Dirt Quad Bike
Midi 49cc bike will not start. owners haven't started it for 2 years. please help!!
If it is still turning over all you probably need to do is service the carb and drain and replace tank with new gas.
Aug 09, 2009 | Quad 47 cc / 49 cc Pocket Mini Bike...
49cc mini pocket quad wont start
if it has a kill switch make sure it is on, check that you are getting spark at the plug and have the right fuel in the motor.
Remove the air filter from the carbi and squirt some 2 stroke fuel directly into the throat of the carbi and try to start it.
hope this helps
May 19, 2009 | RTO Mini Quads
Changing the oil
you don't half to change the oil it takes a oil fuel mixture like a chainsaw or a weed-eater
May 08, 2009 | RTO Mini Quads
Cycling Logo
113 people viewed this question
Top Quad Cycling Experts
shaun taylor
Charles T Nevin
Charles T Nevin
Are you a Quad Cycling Expert? Answer questions, earn points and help others
