Question about Dyson V8 Absolute Bagless Cordless Stick Vacuum
Dyson v8 doesn't seem to be holding a charge. When we turn it on after charging the motor just "chugs" it sounds like it is running then goes off and keeps doing that.
SOURCE: Not holding charge
Ok, folks.. I just posted my own problem with the battery not holding it's charge..but, we fixed it ourselves.. take the motor loose from the canister , remove the filter and in the back are two contacts.they are two screws at the bottom one on each side... get out your pencil with a GOOD eraser and clean those contacts!..clean around them both and the contact (silver spot at the bottom) and you're good to go!!
Posted on Oct 23, 2009
Dysonteam
  • 167 Answers
SOURCE: my dyson dc16 is not holding a charge
Hi its Darran at Dyson.
If you call our Helpline they will be able to run through some simple checks to detemine the cause of this issue.
Please call 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
Posted on Apr 15, 2010
promo7uk
  • 19 Answers
SOURCE: I have a dyson hand held that shuts off after just
yeap..... i just found a fix for this ,, its mad how easy it is to fix as well...and it works 100%,,,
now dyson implemented a filter magnetic switch if u take your filter off you will see a small magnet in the corner,, u will notice where the magnet is behind it is rased platic,, now,,that the problem on the main board the transistor that picks up magentic signal from the filter is dud,!
dont ask me why it happens,, its a pain i know.,.
now take off collection pot for dust now take battery off.
now where the serial number is theres 2 hex screws that need taking out..
now u will see a small pcb board.. remove with one tiny security screw holding it in,, once removed pull both red plug off thats the digital motor plug.. and white plug which is vcc..to battery,, once u have done this pull the board down and back gently. as there is a long bit of board that goes up the back of the dyson plastic be very carefull pull this out.. now the long and thin pcb board that is hidden is what we need there is a tiny transistor,,, we need to remove this carefully..once removed,, we solder a thin wire from 2 point A+C need to be soldered together with a thin piece of wire, it will not harm the motor.. as long as u keep it clean,,
these points corolate to the transistor,,
A
B C
SOLDER AND A+C WITH A FINE PIECE OF WIRE NOW,, AND WALLAH... fixed put it all back together again,,, charge the battery,, and your away,,, working again,, if not u have other faults.. but 99% fix this with flashing red led,,,!!
Posted on Jun 24, 2010
missydenbo
  • 3 Answers
SOURCE: Hello, what is the significance
yes the reason the green and red light were flashing the way they are is because its a warning to you that the battery is either no longer good or there is problems with your wireing. Also those vaccumes were designed to not charge when there to cold or to hot as a saftey issue.
Posted on Aug 06, 2011
askdyson
  • 2572 Answers
Official advice and support for Dyson technology
    Verified Fixya Pro
    SOURCE: We push the trigger, and the light comes on but no suction/ motor not working
    I'm sorry to hear you're having difficulties with your DC35. From what you've described, it sounds there may be a fault with one of the components of your machine. If you give our Helpline a call, we should be able to help - you can reach us on 0800 298 0298 (UK), or 1-866-693-9766 (US). Please have the machine to hand when you call so we can run through some troubleshooting over the phone with you.
    We'll look forward to helping you resolve this issue.
    Best wishes,
    Jack
    Dyson Online Customer Support
    http://www.dyson.com
    Posted on Mar 15, 2012
    I have a new Dyson V8 Absolute When I try to charge it nothing happens. When I pull the trigger I have one flashing blue light. HELP
    not trying to be a smart a** but which of the two do you have?
    1. A flashing blue light indicates that the battery is running low on charge.
    2. A fast flashing blue light indicates no power or a temporary fault (e.g. check filter or for blockages).
    FYI....A solid blue light indicates that the battery is charging. No light indicates the battery is fully charged. A solid amber light indicates that the battery is not charging due to a temporary fault (e.g. too hot/cold). A flashing red light indicates that there is a fault, call the Dyson Helpline.
    Best to you.
    Feb 20, 2018 | Dyson Vacuums
    My dyson v8 vacuum fell from the charging station, now it does not run?
    There could be a lot of things that are causing this. I don't see where the battery is removable. It is a lithium ion battery and it may be suffering from broken connections or broken regulator. It could also be that the wire connections to the switch or the motor came loose. The brushes in the motor might be damaged. You may have to send it back for service. It would not be covered by warranty due to physical damage.
    Dec 22, 2017 | Dyson Vacuums
    I bought an Dyson V8 a week ago. I used it 2 times. it does not seem to be charging.
    takes 6 hours or more to recharge
    take it back under warranty if taking longer
    Dec 14, 2017 | Dyson Vacuums
    The brushes on my Dyson V6 sweeper attachment won't turn although it is fully charged.
    Your battery may indicate fully charged but if dead it will do that and not work for squat. If charged the motor should run and turn the sweeper with power. If motor runs but sweeper does not check for a stretched belt or one that may have fallen off the pulley.
    Sep 06, 2017 | Dyson Vacuums
    What is the main difference between the basic dyson v6 and v8 vacuum?
    Hello, this is Ava with Think Crucial.
    The main difference between the V6 and V8 Dyson models is the mprovements in power and run time of the unit. The Dyson V6 has the V6 motor that pumps out 24 air watts in normal mode. In max mode that number goes up to 100 air watts. While the Dyson V8 comes equipped with the latest V8 digital motor that produces almost 20% more power than the V6 motor. It has the same 2-tier radial cyclones that capture fine dust and allergens. A post-motor HEPA filter keeps those allergens inside the bin. There is also the Bin improvement as Dyson was able to increase the capacity to 0.14 gallons for Dyson V8. This is around 0.03 gallons bigger than the V6.
    You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
    https://www.thinkcrucial.com/search?type=product&q=dyson
    I hope this was helpful.
    Ava B.
    Think Crucial Customer Care
    http://www.thinkcrucial.com/
    Oct 22, 2016 | Dyson Vacuums
    Dyson dc44 making a stop start chugging noise
    You should take it to your local vacuum repair shop and have them listen to it. It sounds like it could be your motor burning up.
    Aug 28, 2014 | Dyson DC44 Animal Cordless Vacuum
    Dyson dc16 battery not hold full charge, all three lights stay on indicating a full charge.
    If you're concerned that your DC16's battery doesn't seem to be working correctly, please get in touch with us directly. One of our experts will be happy to run some troubleshooting over the phone with you to determine whether the battery needs replacement.
    You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
    Kind regards,
    Jack
    Sep 25, 2011 | Dyson DC16 Root 6 Bagless Handheld...
    Dyson V8 Absolute Bagless Cordless Stick Vacuum Logo
    315 people viewed this question
    Top Dyson Vacuums Experts
    AskDyson
    AskDyson
    Samyfam
    Samyfam
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
