Question about Kitchen Appliances - Others
Got a deep fryer honeywell valve pilot lite lites when turned on it flames up then imeaditly dies out to only pilot lite
  • 125 Answers
SOURCE: lie up deep fryer
Hello. Could be three things, from what you describe, it sounds like your pilot is dirty, and not heating the thermopile enougher, and pilot off to energize the pilot portion of the valve. You could also have a bad thermopile, and no matter how long you hold it, or if your pilot is good, will it energize the valve. The last thing is that your hi limit has failed, and is preventing your gas valve from getting any voltage at all on purpose, as it is a temperature actuated switch that will shut the fryer off it it gets too hot, it could have failed and is now keeping the pilot from coming on, some of these have a reset button you can push ( usually red ) that will reset it, but then why did it trip? either your thermostat is out of calibration, the bulb may be broken in the tank somewhere, or it may just be tripping too early, like 375, instead of 425 to 460 depending on spec.
Hope this helped, and thank you.
Posted on Feb 28, 2009
  • 234 Answers
SOURCE: deep fryer burners will not lite
Does this fryer plug up to power of not?If it don't ,then thehi limit is out,need to reset it and try lightning it back.You will need to hold if for a minute.At this time if it don't stay lite,then replace the pilot thremcouplen.
Posted on Mar 13, 2009
  • 110 Answers
SOURCE: hobart deep fryer, light pilot heats to temp then all goes out?
it probibly a millivolt system, would reccomend replacing thermocouple, that should take care of the problem
Posted on Jan 13, 2010
  • 3238 Answers
SOURCE: ef4 deep fryer
if it has a power phile was this replaced
Posted on Jan 21, 2010
  • 77 Answers
SOURCE: pilot won't lite
When you turned on the thermostat you required more millivolts from the system and it failed. Low millivolts. That would tell you the pilot generator needs replacing. Make sure you have a good pilot flame hitting the pilot generator.
Tom
Posted on Aug 17, 2010
My pilot light won't stay lite,replace thermopile and still doesn't stay lite.
Hi there.
Check for wiring errors, fix and tighten all wiring connections. Make sure that the gas pressure is correct.
Check the hi limit and gas valve, one of those component may be bad.
Regards.
Apr 18, 2013 | Cecilware FMP40 Deep Fryer
Fryer wont stay lit, only two burners will lite, and will only stay lit for about 5 min. will then go out and must start over
Check the gas pressure, it must meet the standard gas pressure written on the nameplate. Check also the quality of pilot flame, poor pilot flame quality will not properly heat up the thermopile which in turn will result in poor fryer operation.
Jun 15, 2011 | Pitco Frialator E24 Deep Fryer
Pilot lite does not have a full flame
Check if the fryer receives sufficient gas pressure as specified on nameplate, if so, your pilot orifice may be clogged.You can clean this by removing 2pcs pilot screw (+) then dismantling the pilot assembly using a vise grip and an adjustable wrench. Once the pilot hood is removed, you will see the pilot orifice. Make sure that the hole will not get large when cleaning.
Apr 28, 2011 | Pitco Frialator 35CS Deep Fryer
We changed the thermostat in our unit and now the pilot lite won't stay lit!
You have to check the following:
1. Does the pilot flame has the ability to heat up the thermopile? Themopile must be properly heated in order to generate voltage to open the pilot valve as well as main valve.
2. When the thermolpile is heated, does it generates 500 millivolts? If not, your thermopile needs replacement. If it does and still the pilot flame wont stay lit, your gas valve needs replacement.
3. Does the hi limit device has continuity on its terminals? If there is no continuity on hi limit terminals, you have to replace it. One of the thermopile wire passes on this hi limit terminal to cut the voltage supply on pilot valve in case the oil temperature reaches 450F.
4. Check and tighten all wiring connections, millivolts generated by thermopile will not pass on loosely terminated wiring.
Jan 12, 2011 | Pitco Frialator 35CS Deep Fryer
Pilot will lite,but burners will not lite when you turn the thermo. up
Make sure gas valve is in the ON position after lighting the pilot. Try jumping the thermostat terminals together to see if burner comes on. Three things could cause this problem 1. bad operator on gas valve 2.low millivolts 3. thermostat not functioning
Tom
Aug 03, 2010 | Frymaster Dean SR42G Deep Fryer
Pilot won't lite. fryer is 6 months old. Did get pilot to lite once and as soon as we turned thermostat pilot went out.
Tom
Jul 07, 2010 | Vulcan EF3 Deep Fryer
My pitco 28lb countertop gas deepfryer conv to propane it will l
Check if the flame quality of the pilot is good. Small amount of voltage generated by thermopile used in energizing pilot main valve coil during fryer operation relies on the quality of pilot flame, also, the thermopile itself should be free of soot or any form of dirt in order for it to absorb the heat from pilot flame.
Check also the gas pressure, it should meet the gas pressure required on the nameplate.
May 24, 2010 | Pitco Frialator SG14 Deep Fryer
Pilot is off.
Most fryers have pilot lighting instructions on the inside of the door. If yours doesn't then find the gas valve, turn the knob to the pilot position, push in on the knob and light the pilot. Keep the knob pushed in after you lite the pilot for at least another 30 seconds. The pilot should stay lit.
Feb 22, 2010 | Pitco Frialator SG14 Deep Fryer
Lie up deep fryer
Dec 02, 2008 | Imperial IFS40 Deep Fryer
Kitchen Appliances - Others Logo
87 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
