Durabrand cdr 1902 set time. Press time and hour button but will not advance. keeps flashing.
4 Suggested Answers
SOURCE: How do I set the (time set) clock?
Hold down the TimeSet/Repeat button. it will say the day. Release that button and hold down the On/OFF button to set the day. Repeat the same procedure and it will set the Hour. Repeat it again to set the Minutes
Posted on Mar 27, 2007
  • 2501 Answers
SOURCE: I have an Armitron 40/8125 watch. I try to set the
You need to press button A to enter the time setting mode and then press C.
If you have lost your instructions, you can get instructions from the Amitron web site.
Copy "www.armitron.com/watch_instructions.asp" into your search engine and you will see a list of illustrations of watches and associated
instructions.
Choose the one that looks like yours and download the PDF file.
Posted on Mar 18, 2010
SOURCE: setting clock on durabrand cdr 1902
Hold down the time button on the top of your radio.
Use the forward and/or reverse buttons to scroll the time forwards or backwards on your clock.
Once complete, let go of the time button.
Posted on Nov 26, 2011
HOW DO I SET MONTH DAY AND TIME WITH BP3MW1-1W 800229
Below are the Date and Time setting instructions for a similar model: OMRON BP742
http://omronhealthcare.com/products/5-series-upper-arm-blood-pressure-monitor-bp742/
Set the monitor to the current date and time before taking a measurement for the first time. If the date and time are not set correctly, the measurement values stored in the memory and the average values may not be correct.
1. TO START THE SETTING
Press the Date/Time Setting button ( ) to adjust the date and time.
The year flashes on the display.
2. SETTING THE YEAR
The year can be set between 2010 and 2040. When the
display reaches 2040, it will return to 2010.
Press the Up button ( ) to advance by one year.
Press the Date/Time Setting button ( ) to set the current
year.
The month flashes on the display.
NOTES:
• Press the Down button ( ) to decrease the date and time values.
• Press and hold the button to increase or decrease the date and time values faster.
3. SETTING THE MONTH
Press the Up button ( ) to advance by one month.
Press the Date/Time Setting button ( ) to set the current month.
The day flashes on the display.
4. SETTING THE DAY
Press the Up button ( ) to advance by one day.
day.
The hour flashes on the display.
5. SETTING THE HOUR
The time is set using AM or PM.
Press the Up button ( ) to advance by one hour.
Press the Date/Time Setting button ( ) to set the current hour.
The minute flashes on the display.
6. SETTING THE MINUTE
Press the Up button ( ) to advance by one minute.
Press the Date/Time Setting button ( ) to set the minute setting.
7. TO TURN THE MONITOR OFF
Press the START/STOP button.
NOTE:
The monitor will automatically turn off five minutes after the minute has been set
SOURCE (PDF User Instruction Manual):
http://omronhealthcare.com/wp-content/uploads/BP742_IM.pdf
Jan 03, 2015 | Health & Beauty
How do I set the time on Timex T231 clock radio?
Setting The Time of T231
NOTE: The time can only be adjusted when the clock radio is in the OFF mode. If the radio is playing, press and hold the MODE/ALM RESET button until the display briefly shows 'OFF' and then reverts to the time.
1. If the display is flashing, press the HOUR / REV button to advance the display to the correct hour. If the display is not flashing press and hold the CLOCK button until the display begins to flash, then press the HOUR / REV button to advance the display to the correct hour. Observe the PM indicator to confirm that you have set the hour correctly. If the PM indicator is 'On' the hour on the display is PM. If the PM indicator does not appear the hour on the display is AM.
2. Press the MIN / FF button to advance the display to the correct minute.
3. When the correct time is flashing on the display press the CLOCK / PRESET button once more. The display stops flashing and the clock begins to run.
Oct 01, 2014 | Timex Audio Players & Recorders
Setting clock on durabrand cdr 1902
Aug 31, 2011 | 2001 Mercury Sable
How do you set the time and date on blood pressure monitor model DS-1902
Use memory M1 button to increase the flashing year and memory M2 to decrease the year. Press START button to confirm and go to the next step. Day flashes. Press M1 or M2 to adjust and then START to confirm. Month flashes. Adjust with M1 and M2 buttons and then press START to confirm. Hour flashes (the clock operates in 24hour mode). Adjust with M1 and M2 buttons and then press START to confirm. Minute flashes. Adjust with M1 and M2 buttons and then press START to confirm.
The clock is set and the unit is turned off.
Please rate if this helped. Thank you
Jan 15, 2011 | Mark Of Fitness DS 1902 Blood Pressure...
Need instructions for setting my armitron wr165 , 45/6967 watch.
This model is not available on Armitron's website, but after working through a similar digital watch, I came up with the procedure.
Basically, hold the MODE button for 2 seconds until the alarm flashes then press SET to get to the minutes. Press ADJ to change the numbers. Press SET again to change the hour.
Here's the full date/time set:
SETTING THE TIME AND CALENDAR 1. Press and hold 'MODE' for two seconds. Alarm Modeappears. Release 'MODE', then press 'MODE' again. Seconds and the TuesdayIndicator flash. Press 'EL' to zero out the Seconds. 2. Press 'SET'. Minutes flash. Press 'ADJ' to advance the Minute. 3. Press 'SET'. Hours flash. Press 'ADJ' to advance the Hour. 4. Press 'SET'. The Months flash. Press 'ADJ' to advance the Month. 5. Press 'SET'. The Date flashes. Press 'ADJ' to advance the Date. 6. Press 'SET'. The Day of the Week flashes. Press'ADJ' to advance the Day of the Week. 7. Press 'MODE' to end set sequence and return to thetime.
Nov 07, 2010 | Microwave Ovens
How I change the time Armitron WR165
Thank you for contacting FixYa.
Light = A - lower left button
Mode = B - Upper left button
Date = C - Upper right button
Alarm = D - lower right button
Set time time / date
Press and hold B (Mode) untill alarm hours flash
Press D (Alarm) to advance these
Press B (Mode) again, seconds will flash,
press D (Alarm) to advance these
Press C (Date), minutes flash, press D to advance these
Press C again, hours flash, press D to advance these
Best regards. Jewel
Sep 18, 2010 | Armitron Watches
Setting Armitron Watch model WR330
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all ARMITRON watch manuals. Rate me, please.
Mar 14, 2010 | Watches
Keeps flashing 12:00
Hi jippers - try this :
1. Setting the Clock
When the coffeemaker is plugged in, 12:00 willappear until you set the time.
Entering “Time Set” Mode:
To set the time, hold down either the “Hours” or“Minutes” button until the clock begins flashing (about 2 seconds). You are now in the “Time Set” mode and can operate either button to achieve the desired setting. The buttons can be held down to scroll through the digits, or
pressed and released lightly to advance one
digit at a time.
When scrolling, the numbers will advance
slowly at first and then speed up to the rate of about three per second. When the number displayed approaches the desired setting,release the button and press repeatedly to advance one digit at a time. Be careful to make sure that the PM indicator is on if a PM time is desired.
Exiting “Time Set” Mode:
The “Time Set” mode can be exited in
one of two ways:
1. Press any button besides the “Hours” or
“Minutes” button. This will exit the “Time Set”
and activate the selected function.
2. Do nothing. If neither the “Hours” nor
“Minutes” button is pressed for a period
of five seconds, the “Time Set” mode will
be exited.
If this solves your problem PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks and have a nice day.
Jeff
May 08, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Setting time/date on Ironman Triathlon 8 lap
Press & hold set button the seconds will flash.
Press split/reset to set seconds to zero
Press mode to select hours
Press split reset to advance hour digits go through 12 hours to get to AM/PM
Press mode to select minutes
Press split reset to advance minutes
Keep repeatin the above steps to set month date day and 12/24 hour diplay
Press set when done.
Mar 09, 2008 | Timex Sports Ironman Triathlon 50-Lap...
49 people viewed this question
 Grubhead
Grubhead
