Question about Pioneer Car Audio & Video
What is the wire color and pin position for a pioneer deh-6
Need wire configuration for pioneer deh 2100 cant figure out what color wires are what?
red- accessory
yellow-constant power
black -ground
blue with white stripe-romote ''if any
blue- power antenna
speakers wires'''''''''''''''''''''''
white - postive
white with black stripe-negative]-left front
gray-positive
graywith black stripe-negative]right front
purple-positive
purple with black-negative]right rear
green-poditive
green with black-neegative]-left rear
white
Oct 13, 2009 | Pioneer DEH-2100 CD Player
IM w/out a wiring diagram for a sterio/cd player (pioneer)# deh-p7500mp. It has a 24 pin plug in and a 12 pin plug in port.Please identify pins...
red is accesory key switch yellow is battery constant power,black is common ground,blue is remote,green black is left rear negative and green is positive,violet black is right rear negative and violet is positive,white black is left front negative and white is positive,gray black is right front negative and gray is positive.
Sep 11, 2009 | Pioneer DEH-P2900MP CD Receiver...
The pioneer deh-1100 does not have a color code for the wiring. Does anyone know the color code?
Here is the breakdown of what wire does what:
+Red..............12v ignition
+Yellow...........12v battery
-Black............Ground
+Blue.............Power antenna
+Blue/white.......Remote turn on
Orange...........Dashlight/dimmer
Orange/white.....Dashlight/dimmer
Orange/black.....Dashlight/dimmer
+White............Front left positive
-White/black......Front left negative
+Grey.............Front right positive
-Grey/black.......Front right negative
+Green............Rear left positive
-Green/black......Rear left negative
+Purple...........Rear right positive
-Purple/black.....Rear right negative
Sep 05, 2009 | Pioneer DEH-1100 CD Player
I need wiring diagram for pioneer deh p56
Pioneer follows the universal after-market color code, so if your CD player was made in the last ten years or so, the wires should go like this: Yellow: Constant +12VDC (memory) Red: key-switched +12VDC (accessory) Black: Ground Blue/white: amp remote or power antenna output Speaker wires: The solid-color wire of each pair is positive; the black-striped wire is negative. Left front: white Right front: gray Left rear: green Right rear: violet
Jun 13, 2009 | Pioneer DEH-P56 CD Changer
Can not find a wireing diagram for a pioneer DEh-p2600
Black: Ground
Left front: white
Right front: gray
Left rear: green
Right rear: violet
Hope this helps!
May 30, 2009 | Pioneer DEH-P2000 CD Player
Problems with Metra METRA PR01-0001 PIONEER 16-PIN UNIVERSAL WIRING HARNESS?which wires are which
I don't know what pins are what on the METRA harness, but the wires coming from the back of the Pioneer unit should be:
black ground
red accessory (KEY)
yellow memory constant power,
blue is remote,
orange is for the dimmer,
green with black is left rear neg.and green is positive,
white is left front positive and white with black is negative,
If you don't have the pioneer harness (and so these wire colors dont' mean much to you) just message back here, and I'll map those wire colors to pin positions on the back of the unit.
May 21, 2009 | Pioneer DEH-1500 CD Player
Pioneer deh-p3500 memory wire color
12V Battery, Memory/Constant wire Yellow
FYI:
12V Accessory Wire Red
Ground/Chassis Wire Black
Left Front Speaker, Positive (+) White
Left Front Speaker, Negative (-) White w/Black Stripe
Right Front Speaker, Positive (+) Grey
Right Front Speaker, Negative (-) Grey w/Black Stripe
Left Rear Speaker, Positive (+) Green
Left Rear Speaker, Negative (-) Green w/Black Stripe
Right Rear Speaker, Positive (+) Purple
Right Rear Speaker, Negative (-) Purple w/Black Stripe
Remote Out, Power Antenna Blue
Remote Out, Power Amplifier Blue w/White Stripe
Apr 21, 2008 | Pioneer DEH-P3500 CD Player
Wiring schedule for 2002 new beetle volkswagen radio
Yellow - +12V Constant Power Red - +12V Switched (accessory) Power Blue - Power Antenna Blue/White - Amp Turn-on White - Left Front Positive Speaker Wire (LF+) White/Black - (LF-) Gray - Right Front Positive Speaker Wire (RF+) Gray/Black - (RF-) Green - Right Rear Positive Speaker Wire (RR+) Green/Black - (RR-) Purple - Left Rear Positive Speaker Wire (LR+) Purple/Black - (LR-)
Mar 22, 2007 | Pioneer DEH-1500 CD Player
Car Audio & Video Logo
42 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
