Question about Hifonics Car Audio & Video
Brutus hifonics amp 1200 watt works for 20 min then goes in protect mode wired to 2ohms and all wires good cut off and works for a few then samthing again ?
  • Ronald hodge Dec 09, 2016
    Goes into protect mode then cut key off and turn back on will Work for a lil bit then same thing again was going to put a small fan in front of it to see if that works
    Sergeant:
  • 305 Answers
Shuts off or sound goes out???
Posted on Dec 09, 2016
  • 13 Answers
SOURCE: hifonics brutus bxi 2008 amp. no power output
MAKE SURE SUBWOOFER OUTPUT ON YOUR RADIO IS ON IF NOT THAT COULD BE BAD INPUTS ON YOUR AMP
Posted on Aug 08, 2009
etirbynnor
  • 655 Answers
SOURCE: !!!red protect light is on!!!
Hello beaugarcia26,
Unless the amp itself is defective, there's a short or ground somewhere.
First disconnect the speaker wires and RCA (or high level) inputs, leaving just ground, remote turn-on and power leads connected. Then see if the amp powers up normally. If it doesn't check the ground with a multimeter and make sure it is good. If the amp powers up normally, check the speaker, speaker wires and inputs for shorts or grounds.
Hope this helps.
Posted on Sep 03, 2009
  • 396 Answers
SOURCE: i have a hifonics brutus 1206d and recently bought
there might be a losse hair in where the amp connects to all the wireing just take them all off and make shorter connectionts and screw it in tight
Posted on Oct 28, 2009
oldmanewtoys
  • 414 Answers
SOURCE: amp blows fuses
fuses blow to save the amp. Are your speakers too big for the amp? If this amp is rated RMS @ 16olms it will only power around 600 to 800 @ 8olm and less as you drop down. better to have too much amp then too little so if you are trying to push 1000 watts per speaker @ 8 olms you are way under powered. Also check to make sure your wires are correct inside your speaker cables
Posted on Mar 09, 2010
  • 16 Answers
SOURCE: how to bridge a amp brutus hifonics 1200 watt
use the first - and the last + should run at 2 ohm then
Posted on Mar 10, 2010
I have a brand new Hifonics amp 1500 watt Brutus the only thing that powers up is the logo the power light and protection light stay off the amp brand new out the box what can be the problem
Some amps will not power up internally if u donot have remote wire. Also if u connect power then remote wire it will not power up until u reconnect in correct order. But if all that is ok. Than u have a bad amp
Mar 11, 2017 | Hifonics Car Audio & Video
I have 2 Pioneer TS-W3002D4 12 In and a Hifonics Brutus BRZ1200.1D D-Class Mono Block what's the best wiring
you need to wire each sub down to 2ohms then wire them together like the one in this pic http://m.seimg.net/product/img/subwoofer_wiring/2_subs_DVC_4_ohm_mono_variation2.jpg witch will give you 1ohm so you will be getting every bit of power that amp has but you should get a bigger amp for thos speakers
Mar 24, 2013 | Car Audio & Video
I have a brutus bxi 1206d 1200 watts, and the amp is coming on fine not protected. But there is no sound output. u can hear a small feedback rumble when connecting the input rca's. But thats it. My...
i would check the speaker cables to see if something came disconnected first maybe wire i touching other terminal shorted out the channels output .
run a new set of rca cable to see if one use are bad . check to see if rca cables pluged into right output of radio . check to see if your remote wire is powering up the amp to turn on the amp ..
will still light up with battery power but will never put output to the speakers with out the remote turn from the radio ... how to check this is to disconnect the cable at the amp and take a short 18 gauge wire and strip both ends and touch the battery terminal at the amp terminal one end the other end where the remote wire is mounted on the amp if do this for a few seconds to see what happens or better yet buy a digital volt meter and check for 12volt a the remote wire when you turn on your radio
Dec 23, 2010 | Hifonics Brutus BXi 1206D Car Audio...
Amp not working
sounds like the amp is going into protection mode. maybe a sub is shorted (blown). Or, the only other possibility is the mosfet transistors on the inside of the amp are blown.
Feb 01, 2010 | Hifonics Brutus BX 1205D Car Audio...
Hello beaugarcia26,
Hope this helps.
Sep 02, 2009 | Hifonics Brutus BX 1205D Car Audio...
HELP CAR AUDIO PROB.
If it cuts completely out then your amp is going into protect mode which means the subs are probably not wired for the right impedance (Ohms). Check your sub wiring and make sure it at whatever your amp's stable ohm rate is.
Mar 23, 2009 | Car Audio & Video
Okay i have a problem hifonics brutus 1500 mono d class amp
well your amplifier is obviously going into protect mode,(i used to have this amp and it is awesome) anyway i would go through just to be sure and check all the power connections with a test light, remote wire, positive, and ground. and check the fuse to see if it is still good. you can buy a test light at wal-mart and any automotive store. if you stil have a problem then i would check to see if your running below 1 ohm on this amp. that would cause it to go into protect mode. if all this fails i would just go buy a new one.
Oct 07, 2007 | Hifonics Brutus BX 1505D Car Audio...
Car Audio & Video Logo
75 people viewed this question
Top Hifonics Car Audio & Video Experts
Professor_V
Professor_V
Matthew Spark
Matthew Spark
Radames Pagan
Radames Pagan
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
