How can I get to my Queue? - Office Equipment & Supplies
How to remove need for printer queue
no need to remove the printer queue as it will select the next job automatically
so if you have set it printing something and the want to print another document , it will finish the first then start the second
the queue is need as it stops the printer printer printing any page from any where at any time so removing the queue will cause you lots of pain
Aug 30, 2017 | PRINTER Office Equipment & Supplies
How do I delete a print job?
turn off the printer and remove power to the printer. Job will be stored in printers memory. Go to p.c you printed from and check printer queue see if job is in printer queue on p.c as well and then delete from queue. If it does not delete from the queue go to if windows p.c the services under control panel and stop and restart the spooler service.if print job is stuck in the printer queue.
Mar 10, 2015 | HP Envy 4500 e-All-In-One Printer, Copier,...
Has stopped printing has 3 jobs in queue
Hi There
HP often does this. You have to delete or cancel all the jobs in the queue, becausthe first job in the queue failed. Sometimes you gave to tell the computer many to cancel all jobs. Sometimes it is needed to restart your computer before the queue is empty. Only then will you be able to print again
Regards
Andre
Aug 29, 2011 | HP Office Equipment & Supplies
My Lexmark 3400 is STUCK in a deleting status of 12 pgs. in Queue
In what queue? In either case, I would suggest turn off the device with the queue and unplugging, then restarting. This usually clears a stuck queue.
Best of luck, Jim
Mar 05, 2011 | Office Equipment & Supplies
Printing blocked by a document showing being deleted
Sounds like a stuck document is in the print queue. Try to clear the print queue first before sending another print job otherwise it will just accumulate in the queue. The steps below will help you clear the queue.
Feb 21, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
How to i clear the queue with jobs waiting to print when the printer says printing but is not printing
Try pressing cancel on the printer first. Then, open the print queue by opening the printers folder, and double-clicking the printer icon for your printer. Try to select the jobs there and cancel them. If that doesn't work, turn off the printer, and wait for the title bar of the print queue to say "use printer offline". If it doesn't change on the title bar of the queue, then select "use printer offline" from the file menu of the print queue. Then try to delete the print job. If this still doesn't work, leave the printer off and reboot the computer, then try to delete the print job again if it is still in the queue. If none of these work, remove and then reinstall the printer as a last resort.
Sep 30, 2010 | HP Officejet 5510 All-In-One Thermal...
HP P1005 PRINT JOB SITS IN QUE, WO'T PRINT
Does it show "Printing" or "Spooling" in the job queue window?
Open the Job queue window, then highlight and cancel the print job. Send a small print job to the printer and make sure that the PC and the printer are communicating.
If the failure re-occurs, then clear the queue again and close it and restart i=the queue.
Don
Dec 14, 2009 | HP Hewlett Packard LaserJet P1005 Printer
Printer keeps printing page after page of meaningless symbols.
Did you have document in queue?If you have delete all documents in queue and restart the computer.Then restart printer.Wait to document in queue deleting.If you haven't documents in queue reinstall the drivers.First delete old, reset computer and install new.
Nov 04, 2009 | HP DeskJet 940c InkJet Printer
Hp-ux print queue on a m305 mfp printer
Unplug the power cord for 10 seconds, or scroll through the menus for RESETS
Jan 05, 2009 | HP LaserJet M3035xs MFP All-In-One Printer
Unable to clear printer queue
I had a related problem. Couldn't delete a job from the queue nohow. I wound up deleting various processes (CTRL ALT DEL PROCESSES tab) and it cleared it.
Mar 01, 2008 | Canon PIXMA MP780 All-In-One InkJet...
23 people viewed this question
jasbo
jasbo
