Question about FH50150 Carpet Cleaner, Power Scrub Deluxe
Hoover Power Scrub Deluxe (SpinScrub 50) leak from bottom of unit.
As soon as the water/cleanser tank is clicked into place, water starts to stream from he bottom of the unit. It is not coming from the /nozzle/brushes. Rather, it is coming from the square hole on the underside of the unit. I've taken the unit apart, thinking that there would be a loose/disconnected hose, but the hoses are all tightly connected. It seems that the square hole is immediately below the cleanser pump. Does this mean that my cleanser pump is leaking? Ken
  • Anonymous Apr 25, 2018
    I had the same problem. I took apart the machine and discovered it was a cracked Pump Assembly With Quick Disconnect Turbine Assembly. I tested it by pouring water down the tubing through the reservoir assembly. Doing that ruled out that it was a tank issue or a seal issue where the tank connects to the tubing.
    Top Expert:
  • Hoover Master
  • 79,077 Answers
Check for a torn "O" ring seal.
Posted on Dec 09, 2016
How doI hook up furniture/stairs attachment
Hoover Steamvac Spinscrub - How To Attach Hose and ...
? 2:54
https://www.youtube.com/watch?v=XTgoEezUlRs
Mar 13, 2011 - Uploaded by Doug Weeks
... spin tool. Used for stairs and stains etc. hand held. ... Hoover Steamvac Spinscrub - How To Attach Hose and Spin Tool ...Every time I attach the upholstery and then turn the vacuum on, water begins to leak from the bottom.
Hoover SteamVac Connecting Hose & Tools F5915900 ...
? 1:41
https://www.youtube.com/watch?v=heAeez1YlFc
Nov 23, 2011 - Uploaded by HooverVideoGuides
How to properly connect the hose and tools ... Hoover VacuumVideo Guides ... I cant get the water to come out the water isnt coming out the spray part to scrub my furniture ... Get Best Price for Hoover SteamVac Carpet Cleaner here ... for the love of god when not using the hand tool where on the machine ...
Hoover SteamVac Connecting Hose & Tools F5912900 ...
? 1:41
https://www.youtube.com/watch?v=fPU9pXgNo98
How to properly connect the hose and tools ... Hoover SteamVac Connecting Hose & Tools F5912900 F5914900 F591... ... Hoover Vacuum Video Guides .... Hoover Steamvac Spinscrub - How ToAttach Hose and Spin Tool ...
Jan 09, 2016 | HOOVER COMPANY Steamvac Deluxe
Whenever I install the clean water tank the water releases without it even on or pluged in. How do i fix it? By myself
On the bottom of the water tank when lifted off the unit check to make shure the gasket is clean and seated properly into its saddle were it's sits in or if the needle valve is stuck open
Jan 10, 2015 | Hoover Power Scrub Deluxe Carpet Washer
Hi, how do I check my hoover floormate deluxe spinscrub's filter and motor?
Hi Mike! To check the filter on the Floormate deluxe, remove the dirty water tank and pull up on tank lid to separate from the base. Check foam filter for debris, if filter has debris, rinse it with water. To prevent internal damage make sure you are using only the Hoover Floormate detergent. If the machine is still noisy and smells bad we recommend taking it in to a Hoover authorized service center. Follow the link to find the nearest service center to you. Hope this helps! Service Center Locator
Oct 20, 2014 | Hoover Vacuums
Water tank leaks
If the tank is leaking, when removed from the cleaner, it is not user serviceable.
Oct 01, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
My Hoover steamvac w/spin scrub F5914-900 will not **** up water. I can not find my manual. How can I fix it?
Assure the ring gasket is in place under the hood. A round rubber gasket must be in place on the round tube under the hood where the recovery tank sits to connect the vacuum from the motor to the round tube on the bottom of the tank.
Aug 30, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steam vac spin scrub leaking cleaning solution
The hose leading from the tank to the sprayer head on the bottom of the unit, or the tank is not seated properly or the tank has a hole or crack
Feb 14, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Water keeps coming out of my hoover spin scrub
The bottom of the solution tank has a rubber stopper, if this tank is not installed just right that rubber can get caught, or damaged. Here is the manual for your machine.
http://www.hoover.com/pdfs/manuals/H3030.pdf
I hope this helps.
Jan 18, 2009 | Hoover H3030 FloorMate SpinScrub 500...
My Hoover will not turn on
there was probably a leak in the hose/piping near the pump in the vacuum that shorted out the motor. you will need a new motor for the vacuum. you will also need a new pump assembly. i strongly recommend that you also replace all the internal tubing and places where the pipes join.
Aug 24, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Model F7441980 Hoover Dual Action Spin Scrub Wide Path
You will have to replace the tank, and it will come with the soap dispenser attached.
Mar 30, 2008 | Hoover SteamVac F5914-900 SpinScrub...
FH50150 Carpet Cleaner, Power Scrub Deluxe Logo
775 people viewed this question
Top Hoover Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Hoover Vehicle Part and Accessory Expert? Answer questions, earn points and help others
