Question about Sanyo Televison & Video
How do I connect my PROSCAN sound bar to my Sanyo tv model number 42841
  • 10 Answers
SOURCE: when i turn the tv on i get sound but just a black screen
Try pressing the menu button on the remote to see if the menu comes up.
If it does it's possible the light and colour have been turned right down, find the option on the menu and turn it up.
Also check no cables are unplugged at the back of the tv, picture is usually yellow make sure it's in tight. Check other end as well so sky box or DVD player.
If you're using an AV port on your tv try using a different one, so switch form AV1 to AV2.
Posted on Jul 23, 2009
  • 6 Answers
SOURCE: pc to tv
You can also connect this TV to a computer using a DVI to HDMI cable (I have done it, but you must have a DVI monitor output on your computer). Something like this would probably work:
http://www.amazon.com/Belkin-HDMI-DVI-D-Cable-Cord/dp/B000653J1G
You can get the cable cheaper, but it is probably worth paying a bit extra for a higher quality one. If you want to go the dirt-cheap route, you can get one here:
http://www.amazon.com/gp/product/B0002CZHN6/ref=pd_lpo_k2_dp_sr_1?pf_rd_p=486539851&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B000653J1G&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=0X2YJYNJ7HWX9NEQ7XJT
Hope this helps.
Posted on Aug 07, 2010
iversonchris
SOURCE: I NEED THE SERIAL NUMBER
i need pass code
Posted on Jan 08, 2014
  • 992 Answers
SOURCE: Connect Sound Bar to TV (flatscreen - Proscan)
How about fiber optic cable or composite cables. I usually recommemd that people do either of these.
Posted on Jun 05, 2014
mike0862
  • 5659 Answers
SOURCE: How do you connect Samsung sound bar to my Sanyo dp52440A. TV has no receptacle which fits the audio aux which came with the sound bar
You don't have an optical digital connection on your TV but you do have a coaxial digital audio output that you can connect to the aux in on the soundbar!
Posted on Jan 01, 2015
How do I hook WiFi to my Sanyo model #42841 and will I need a special cable
ur tv is not wifi enabled device. in order to get wifi u have to add a wifi devide like and android device like amazon fire tv
Oct 04, 2017 | Sanyo Televison & Video
How to fit a sound bar to a proscan tv
1) Go the Sound Tab on the remote's Proscan menu
2) Set the system's "Digital Audio Output" to PCM (pulse code modulation)
3) Connect a coaxial cable from the Coaxial "jack" on the back of the TV to the Digital Input "jack" on the back of the sound bar.
It should work now!
Feb 05, 2015 | Proscan Televison & Video
How do you connect Samsung sound bar to my Sanyo dp52440A. TV has no no outlet which fits audio aux which came with my Sanyo TV
Hook your sound bar to your output device, Cable Box, DVD/Blu-Ray player. Or try the follow should your Sound Bar have HDMI.
Output Device>Sound Bar>TV
The Sound bar should have a HDMI in and out or at least most Samsung models do as well as Bluetooth support.
It is easier to answer when you list the model of each Item, there are many different version of Samsung sound bars.
Jan 01, 2015 | Sanyo Televison & Video
Jun 04, 2014 | Proscan Televison & Video
Connecting sound bar to proscan TV
Proscan has released hundreds of models of televisions over more than two decades, so I can't be specific without more information. There are also hundreds of different sound bars on the market. The answer given should apply to all situations:
Ideally, the sound bar should be connected to the television using one of the methods (in order of preference):
  • Optical cable output from the television into the optical cable input to the sound bar; (best)
  • SPD/IF coaxial output from the television into the SPD/IF coaxial input to the sound bar; (really just as good)
  • RCA R/L outputs into RCA R/L inputs to the sound bar. (not nearly as good as either of the above)
Jun 03, 2014 | Televison & Video
Does sound bar connect to AV-IN?
This is an old post, but I will answer just in case the owner has never gotten his answer.
This model TV has a 1/8th inch headphone jack. You will need a converter cable that converts from 1/8th inch stereo to dual left and right RCA connectors. Get one of sufficient length to reach from your TV to the soundbar and you should be good to go.
Feb 23, 2014 | RCA PLED2435A - Proscan 24 LED 1080p 60hz...
Proscan how to
I have a Proscan Flat Screen TV Model PLEDV2845A. I want to connect my Philips HTL2101A Sound Bar.
I have intially connected both via Coax cable as the soundbar does NOT have HDMI port. I then went into the setup on the TV to Sound, set sound to PCM
Initially it worked fine. 2nd day it will not won't work. Per instructions from Philips I have upgraded the firmware on the SoundBar.
Any ideas
Jan 06, 2014 | Proscan Televison & Video
Proscan 32LA25Q Audio output
Check the manuals and seen may be something.
Oct 02, 2008 | Proscan 32LA30Q Television
Televison & Video Logo
27 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
