Question about JVC Car Audio & Video
How do I fix a JVC FS-GD7 Tray Errror
How difficult is it to access the drive mechanism for the JVC FS-GD7 5-DISC changer?
    Top Expert:
  • JVC Master
  • 77,499 Answers
Just pull the top cabinet cover off, it is all there.
Posted on Dec 09, 2016
I HAVE A 5 DISC CHANGER.......I PLUG IT IN, TURN ON POWER AND THEN PUSH OPEN. OPEN COMES UP ON THE SCREEN BUT THE TRAY DOES NOT OPEN. WILL NOT SKIP FROM ONE DISC TO ANOTHER EITHER???????? ANY...
The 5 disc carousel CD player has a belt driven mechanism in it. And after about 3-4 years the belt looses its tension and cannot push the tray in or out. If you keep your ears on the top cover and turn on the system you will hear a whirring sound coming from the inside which will prove my point.
There are two belts in the machine. One for the eject mechanism and the other for disc change mechanism. One has to seek professional help to replace both because there is timing sequence also involved like the cam shaft of an engine.
Mar 08, 2011 | JVC XL-F154BK 5-Disc CD Changer
Tip
HARMAN FL8385 CD CHANGER TRAY ALIGNMENT
We've all done it, or one of our youngsters do it for us... knock the multi disc tray out of sync with the drive gears.
With multi disc trays, the CD drive has to move out of the way during disc change and tray loading. Occasionally a disc jams, someone forces the tray movement, and you hear the GRIND, GRIND, GRIND of slipping gears.
Most designs have a switch-hit gear setup that's self correcting for small adjustments but occasionally the mechanism slips beyond self correcting.
Here's the process to open up and fix the tray alignment for Harman's FL8385 CD Changer.
http://www.keepandshare.com/doc/view.php?id=1660661&dn=y
3.7mb PDF.. (I'll try to shrink the filesize later)
on Jan 06, 2010 | Audio Players & Recorders
My jvc 5 disc player wont play cd nor dvd.says tray errr. wont open to eject dics or play
It is possible that the loading belt needs to be replaced, or the timing gears are out of sink, either way it must be taken apart to find the problem, sometimes I find the gears ware out causing the unit to lock up. When you hit the eject button do you hear a motor running? that should be the sound of the loading mechanism trying to eject the tray.
Dec 23, 2010 | JVC FS-GD7 Shelf System
(tray err) what does that mean?
The tray that holds the CD disc is malfunctioning.
Dec 05, 2010 | JVC FS-GD7 Shelf System
'P-ERROR' message on my JVC FS-GD7
Maybe the amplifier IC are damaged and need to be replaced
Aug 03, 2009 | JVC FS-GD7 Shelf System
JVC UX S77 my 5 disc cd says "tray err". It won't open or play.
it sounds like the tray has come off the guides a comon problem with kids pushing the tray in rather than pressing the button. if the teeth on the track are ok then it is just a case of opening it up and putting the tray back
May 16, 2009 | JVC FS-S77 Micro 5 Disc DVD Audio/Video...
It won't play DVD's but will play CD's and VCD's. Was exposed to smoke.
I think that a lens cleaning disk would fix the problem..
Apr 24, 2009 | JVC FS-GD7 Shelf System
The 200 disc cd changer, model JVC XL-MC334, gets the cds stuck when trying to spin the carosuel around.
this is most difficult cause if you are a technician you got to change or clean the optic sensors and put on time the mechanism changer......
Nov 17, 2008 | JVC Audio Players & Recorders
CD player ate a CD!!
I fixed the same issue by forcibly pulling individual trays to their open position.  I removed the casing to gain better access (tons of screws) but you can probably gain clear access to the shelfs without removing the casing if you have good needlenose plyers.  I found a stuck CD within one of shelfs, wedged WITHIN the moving components of the shelf.  It works perfectly now.
Aug 01, 2008 | JVC FS-S77 Micro 5 Disc DVD Audio/Video...
P-Error on JVC compact component system FS-GD7 when turned on
1. Unplug the JVC compact component power cord from the power outlet.
2. Unplug any connected devices.
3. Press and hold the JVC compact component power button for five seconds.
4. Plug the JVC compact component power cord back into the power outlet and turn on the JVC compact component
5. Open the menu to confirm that the JVC compact component is responding again.
6. Turn off the JVC compact componentand reconnect the devices.
7. Turn on the JVC compact component...
Jul 23, 2008 | Audio Players & Recorders
Car Audio & Video Logo
557 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
