Question about Vacuums
The carbon fiber tool rotating brush starts turning at first then stops and doesn't turn anymore
CompuGuy44
  • 432 Answers
SOURCE: Bissell Velocity Vacuum brushes stopped
The brush bearings wear out on these things. I know I replaced mine twice before buying new carpet. I've had it for 10 years,
You can order these parts on the Bissell website:
http://www.bissell.com/Products/p/CleanView+Brush/product.aspx
http://www.bissell.com/Products/ak/replacementparts/p/CVPT+II/product.aspx?%23=Detail#Detail
http://www.bissell.com/images/UserGuides/35934_804.pdf
Posted on Mar 30, 2008
  • 16 Answers
SOURCE: rotating brushes will not turn
remove the lift off and assure the plugs are clear.. reseat... no dice.
then motor... common issue is just not seated right..
Posted on Dec 19, 2008
SOURCE: rotating brush will not turn on my Dyson DC07
Yes I had the same problem on my animal Dysom. There is a button on the top of the dysom that turns the cacuum on. Right beside that button is another one that turns on and off the brush!!! Good luck!!! I accidently one day bumped that button and couldn't get my brush to work but after troubleshooting it, that was my solution.
Posted on Jan 24, 2009
ukvacfan
  • 328 Answers
SOURCE: The brush bar on my Dyson DC17 stopped turning.
If this model has a brush control - i.e a roller at the side of the model which controls brush to spin or not, then its a protected brush model - therefore even if the drive belt is intact the Dyson would have to be repaired by a service personnel or professional. The brush protection isn't able to be taken apart and sounds like it may well have slipped off due to tension.
Posted on Apr 02, 2009
  • 5 Answers
SOURCE: 6 rotating brushes
When you turn on the Vac with the brush strip NOT installed does the part that engages the brush strip turn at all? If so, when you install the brush strip see if the will turn when no pressure is applied to the brushes (tilt the Vac back). If none of this works, then the switch that engages the brushes when the unit is not fully upright may be broken. If the part that engages the brushes turns but won't turn when the brush strip is engaged then one of the parts that mate up it most likely stripped. Let us know what you discover!
Posted on Aug 23, 2009
Dc59 motorhead carbon fiber brush not moving.
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Dec 30, 2016 | Dyson DC59 Motorhead Bagless Cordless...
So I have a dyson dc35 multi floor and it was working great then i turned it off to empty it and the brush wouldn't spin anymore. I cleaned it charged it and still nothing.
https://www.thinkcrucial.com/search?type=product&q=dc35
Ava B.
Nov 04, 2016 | Dyson Vacuums
Hoover steamvac 50 stopped spinning
Hi! The brushes can stop spinning if something is obstructing them such as carpet fibers, hair, dirt or debris. Remove the brushes from the cleaner by grasping the plastic outer housing and pulling firmly away from the cleaner. Remove any debris and run it under running water to clean. On the back of the brush-block assembly there's a plastic drive pin that rotates all the brushes when turned. Turn the drive pin and ensure that all brushes are making a complete 360° degree turn. If the brushes are getting stuck or if a brush falls out then the brush-block will need to be replaced. Follow the link here to order a replacement brush-block for the Steamvac Search Results. Below is a list of models this brush will fit.
F5912-900, F5914-900F5915-100, F5915-900, F5915-905, F5917-900, F5918-900, FH50041, FH50042, FH50043, FH50044, FH50045, FH50046, FH50047, FH50048CA
Hope this helps!
Jun 20, 2014 | Hoover Vacuums
Brush bar doesn't rotate.
Either the bearing in the rotating brush is bad and isn't allowing the brush to turn, or in the majority of cases, the belt is broken.
May 20, 2012 | Vacuums
The big brush is not turning anymore.
All kids of brush are having same problem. They get stuck after a few times used. If you have a user manual, please check the section where it is explained how to maintain your product. Cleaning your brush can be done easily, depends on the model. Use a dusting brush & crevice tool to vacuum clean the brush and fan it well. Check for any material parts who can get under the rotative brush and untangle.
If this is not helping, plese find an authorised service center, depends on the producer it might cost or not for serviceing accesories.
Apr 11, 2011 | Vacuums
The brush will not rotate. I thought this was a direct drive system.
Note: The brush will not rotate when the machine is locked in the upright position, because an internal micro-switch turns the brush motor off.
- Check the belt through the clear brush cover. If this appears damaged or broken, please take your machine to a local BISSELL Authorized Service Center to have this replaced. If the belt is intact, please continue checking the following:
- Ensure both power switches are turned on when you check for brush rotation.
- Unplug the power cord and remove the handle completely. Slide handle back into the lower section of handle, ensuring the screw is in tight. If the handle is not aligned properly, this will affect the power of the brush motor.
- Look for debris wrapped around the brush (i.e. string, hair, fibers, etc.). When the machine is unplugged, cut away any visible hair, fibers or debris from the brush roller. This brush is NOT removable from the machine.
- If something has become lodged in the foot and the brush shuts off, turn off the vacuum and unplug this from the outlet. You can now remove the obstruction. The brush will automatically reset when the vacuum is plugged in and turned back on.
If you continue to experience difficulty with this, please take your machine to the following Service Center in your area. The warranty on this machine is five years.
Aug 12, 2010 | Bissell Healthy Home HEPA Bagless Upright...
Beater brush
- Make sure brush switch on the handle is on.
- Check the belt through the clear brush cover. If this appears damaged or broken, take your machine to a local BISSELL Authorized Service Center to have it replaced. If the belt is intact, please continue checking the following:
Jun 15, 2010 | Bissell Healthy Home HEPA Bagless Upright...
I have a similar problem as many do with this model, "clean Roomba's brushes".. We took it apart last night, cleaned out all of the dust we saw. we removed the cover, the housing for the brushes and...
The machine is trying to tell you that there is something still restricting the brushes being able to rotate. The brushes are spinning on an axile that might have some hair or carpet fibers caught in it still. Look on the outer edges of the brush assembly and see if any of these things are rapped around those ends. Cleaned that off and put a little WD-40 in there and that should get you going.
Dec 03, 2009 | iRobot Roomba 530 Robotic Vacuum
Intemitant power
DO NOT TURN ON THE KIRBY ANYMORE UNTIL YOU GET THIS FIXED!!! (not even to show someone what it sounds like)
Your carbon brushes are worn out and will cause damage to the armature if you run the machine before they are replaced..
You can use my guide for replacing the power switch to break the Kirby down and allow you to get to the carbon brushes to replace them.
http://reviews.ebay.com/REPLACING-THE-POWER-SWITCH-ON-ANY-KIRBY-G-SERIES-VACUUM_W0QQugidZ10000000003752018
Hope this helps,
Marci
Jun 16, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Carbon Brushes wearing out quickly on Kirby Heritage II
4 possible reasons.
1 – one or both bearings are worn so armature (rotating part) wobbles as it is spinning and cause motor brushes to wear fast. Solution – change bearings too.
2 – Whoever replaced brushes – did not use some brush seating sticks to make cmutator smother and contour brushes to the shape of the comutator (not likely). Solution – appropriately install new set of brushes.
3 – Comutator is so warped that seating sticks do not help anymore – solution – new armature or turn the old armature.
4 – The fact that ONLY ONE brush was worn may mean that there is something wrong with the brush or housing. Maybe it could not move freely within the housing? I think this may be most likely cause it it may be a combination of all 4.Is it worth to fix? Hmm depends how much will it be. If this is 100+ - I’d say get newer Kirby for 300 ad enjoy the tech drive (Heritage does not have tech drive so it is much harder to vacuum with than the newer models)
Nov 05, 2008 | Kirby Heritage II Vacuum
Vacuums Logo
26 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
