I need to set my tv to hdmi - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 52,097 Answers
Use the remote and set input to HDMI
Posted on Dec 09, 2016
How to hook up a denon avr -1706 receiver To a lg smart tv
If you are tuning in TV stations with the TV set, you will need either an optical or a coaxial audio cable to go from the digital audio out of the TV to a digital audio in on the receiver. This setup should give you 5.1 Dolby digital sound. You can also use a pair of red and white rca cables, but you will only have 2 channel sound. You may need to set the TV to output the audio to external speakers. You will need to set the receiver to the input the TV audio is connected to.
If you want to watch Sat or Cable, you probably need a couple of HDMI cables. One HDMI cable will go from the output of the Sat/Cable box to the appropriate HDMI input on the receiver. The second HDMI cable will go from the Monitor Out on the receiver to an HDMI Input on the TV. You may need to set the receiver to output HDMI audio from the receiver, and not the TV. You will need to set the TV to the HDMI Input you connected to on the TV. You will also need to set the receiver to the input the Sat/Cable box is connected to.
Details of both of these setups should be covered in the receiver and the TV manuals. Refer to them for the detailed connections and settings you need to make.
Good Luck!
Mar 02, 2015 | Denon Audio Players & Recorders
My tv model magnavox26mf231d/37 shows hdmi is disabled and the hdcp authorization failure.
This could be a problem with the cable box or other set top box and not the TV. It's known to happen with Samsung cable boxes from Cablevision.
First try resetting the TV and set top box by unplugging both. Remove the HDMI cable from the TV and the set top box. Reconnect the HDMI cable. If you are using a Redmere or similar HDMI cable, make sure that the end labeled TV is connected to the TV's HDMI port. (These cables have additional electronics and are not reversible.) Connect the power cord to the set top box and wait 30 seconds to a minute. Then plug in the TV. To ensure the set top box does the correct handshake with the TV, turn on the TV first and set it to the HDMI input. Then turn on the set top box. See if this fixes the issue. (On some cable boxes, this can be a temporary fix. You may need to have the set top box replaced.)
If the above steps don't help, try a different HDMI cable. If that doesn't solve the problem, then the set top box is faulty.
I hope this helps.
Jan 10, 2015 | Televison & Video
How do i connect my Acer Aspire one D270 with TCL LED TV 40. When i connect my laptop through HDMI port screen blinks but nothing shows on LED TV .LED TV just says not supported.My laptop Graphic is I
Have you checked the settings on your TV Malik? You usually need to go to settings on there and bring up HDMI. For example, if you have TV selected on the settings, you need to change to HDMI to view stuff on your TV screen from the laptop.
Dec 10, 2014 | Acer Aspire One D270-1865
My sat box is connected to hdmi tv with hdmi cable and scart lead, but when i switch on in morning will not go to tv
You don't need the scart if you're using HDMI. However, the TV will not auto-switch with an HDMI connection.
If your TV does not switch on remembering its previous settings, you'll need to reselect HDMI each day.
Feb 27, 2014 | Televison & Video
HOW TO SET UP AND CONNECT TO TV
I need a little more info. on the setup .I believe you are saying the hdmi cable is connected to the tv and home theater? if so have you set your tv to hdmi mode? and the home theater to hdmi input?
Jan 04, 2012 | Samsung Audio Players & Recorders
Bought a soniq hdmi cable for lap top to tv & set up but can't get sound from tv, picture is perfect
You need to go to TV on screen HDMI sound set up, you can choose AUTO or select the sound to be through HDMI or through the audio ports, check your laptop HDMI sound set up also. I would set them to 'AUTO'
Dec 01, 2010 | LG Televison & Video
What cables do i need to connect my ps3 to my sony recevier.
do you wan the suround sound to play sound for what the tv is displaying or just the ps3
for just ps3
connect hdmi to ps3 and tv
connect optical to ps3 and suround sound
change video settings to hdmi
change sound settings to optical
it asks to set settings automatically you have tyo doo it manually
if you want to play every thing that tv displays then
connect ps3 to tv with hdmi
connect suround sound with hdmi to tv
(this might not work)
if it dont work then
and your tv should have sound out or something along those lines it should be two phono plugs in the back of the tv connect that to the suround sound
Dec 31, 2009 | Sony HT-DDWG700 Theater System
Just connected sky via hdmi through denon 3310 and no sound is coming through the tv. Also do i need to have amp on to view sky via hdmi?
ensure that HDMI is selected in your sky settings.
you would not need an amp at all just to view sky, only if you were routing sound to say a surround system.
Are you only getting no sound from the tv? or are you getting sound via the amp but not from the tv?
Nov 22, 2009 | Denon AVR-3805 Receiver
HDMI connection with Panasonic DMP-BD35K Blu-Ray Disc Player
Try hooking the Panasonic up straight to the tv without going through the receiver. If it displays a picture its obviously not the blu-ray player. May also be a problem with the HDMI cable itself. Hope this helps.
Jan 04, 2009 | Onkyo TX-SR506 Receiver
Getting the TV to play through the HDMI cord
First, you need to set the playstation to display on HDMI out.
Plug the HDMI cable into the TV and into the PS3.
Use the PS3 to setup the video settings to 720p which every HDTV can display. Then switch the TV-out to HDMI and it should display.
Also consult your televisions manual to set it up for HDMI input as well. Make sure that the TV allows sound through the HDMI port as some older HDTV's didn't have that ability.
If you still have a problem; please let me know! I hope it helps you out
Aug 08, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
