I ned to set my tv to hdmi - Televison & Video
My tv model magnavox26mf231d/37 shows hdmi is disabled and the hdcp authorization failure.
This could be a problem with the cable box or other set top box and not the TV. It's known to happen with Samsung cable boxes from Cablevision.
First try resetting the TV and set top box by unplugging both. Remove the HDMI cable from the TV and the set top box. Reconnect the HDMI cable. If you are using a Redmere or similar HDMI cable, make sure that the end labeled TV is connected to the TV's HDMI port. (These cables have additional electronics and are not reversible.) Connect the power cord to the set top box and wait 30 seconds to a minute. Then plug in the TV. To ensure the set top box does the correct handshake with the TV, turn on the TV first and set it to the HDMI input. Then turn on the set top box. See if this fixes the issue. (On some cable boxes, this can be a temporary fix. You may need to have the set top box replaced.)
If the above steps don't help, try a different HDMI cable. If that doesn't solve the problem, then the set top box is faulty.
I hope this helps.
Jan 10, 2015 | Televison & Video
Im trying to hook up a HD A/V combo cable to my led jvc and the tvs missing one connect part. Im only gettinf black and white but the guy insisted that it was the right cord. What cord do I need?
You don't need a ikonvert box if you tv has a AV out (monitor out on picture) then all you need is an AV cord sorry if this is not helpful
May 25, 2012 | JVC Televison & Video
I have a Polaroid TV model FLM-2601, it shows HDTV on the front and I recently upgraded my Cable to HD Service. I have the HDMI cable and see the connection on the Cable Box, however, I can not locate a...
Unfortunatly Poleroid is a very economic set and Since there is no built-in ASTC tuner you will have to connect HD sources via the component or DVI jacks. You will ned a plug that is HDMI to component or DVI to get your service.
Jun 09, 2011 | Televison & Video
TV was working fine. Plays DVD's fine. Can't find HDMI from the cable, hence to TV reception. TV set works fine however on DVD's so it is not the set itself. Can't find the HDMI 1 hook up only the HDMI...
Tries tv and cable or satalite boxes unplug,replug it back for like about an hour later.By letting tv resetting itself back to the factory setting and those pay boxes upgrading it softwares.The tv HDMI signal for the tv incomming broadcasting signal should be back,if not, tv might have a dead HDMI cable or that the HDMI 1 hub it plug in is shorted and dead.
Feb 12, 2011 | Mitsubishi WD-57733 57" HDTV
Flickering screen (LC-52SB55u) with HDMI cable input from Sharp Aquos Blue Ray. HDMI working well from other inputs
Do a quick google for this on the AVForums site where you'll find numerous threads covering this problem. First, select the HDMI input before turning on the blu ray player. The handshake over HDMI is the problem. I have the same problem with a Technika blu ray which is fine on my other TVs.
If this doesn't solve it then you ned a firmware update which can be downloaded from Sharp's website and installed using a USB pendrive or by PCMCIA card from Sharp if you have an older model with a rocker on off switch and no USB update port on the back of the TV.
Nov 28, 2010 | Sharp LC52SB55U LCD TV
PS3 hdmi only working on some displays
I have noticed using an HDMI cable that with some of the newer tvs you have to set up the tv also to enable HDMI for a game system. Like you said before internet tv and blueray dvd player work fine. Try adjusting the settings on the tvs themselves. I have a 50in DLP mitsubishi, and had a very troubling time getting my ps3 to work on that particular tv set while it worked flawlessly on other sets. And what I had to do was enter my tv setup menu and then power on my ps3 with both my AV and HDMI cables connected, it would pick up the AV first. Then I would alter the video settings on the PS3 for HDMI, and unplug the AV cable. Exit the tv menu and then reenter it. Then I had to setup my HDMI port from the tv to game in order for it to work, where you can set options ar usually like cable/dvd/sat, and so on. Without my TV being set to game that way it would not work. Try this and see if it helps. Good Luck.
Dec 21, 2009 | Sony Playstation 3 (PS3) Console
Just connected sky via hdmi through denon 3310 and no sound is coming through the tv. Also do i need to have amp on to view sky via hdmi?
ensure that HDMI is selected in your sky settings.
you would not need an amp at all just to view sky, only if you were routing sound to say a surround system.
Are you only getting no sound from the tv? or are you getting sound via the amp but not from the tv?
Nov 22, 2009 | Denon AVR-3805 Receiver
Connecting PS3 to receiver via HDMI
First put the orginal ps3 cable onto ps3 then to tv.set tv to see ps3 and go to ps3 setup,now down to display settings,set to hdmi,picture will go off so now switch tv to hdmi input .Next go to sound settings for ps3 and set to hdmi if your amp can work this way ,if not set sound out to optical.
hope this helps.
CABLE GUY.
Jun 24, 2008 | Onkyo HT-SR800 System
I hae a Magnavox DVD player with remote but I have no instructions how to and what kind of cables to hook up with. Could I get an instruction manual from some one or maybe download it or send it to me....
The cables you ned will depend upon the inputs you have available on the TV you are using. Typically, AV cables are used (Red/White/Yel) to connect to the Video input on a set. Newer sets have both Component connections as well as HDMI. What are you intending to connect to?
Dan
Mar 17, 2008 | Televison & Video
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
