Question about Measuring Tools & Sensors
I put new batteries in Transmitter and never got any temp reading.The unit is less than 2 years old and is not working. Is there anything I can do?
    Top Expert:
  • 44,073 Answers
  • Remove all batteries
  • Install new batteries in transmitter
  • Wait for transmitter to initialize and begin transmitting temperature data
  • Install known-good batteries in receiver
  • Observe outdoor temperature reading
If this doesn't work, the transmitter or receiver or both may be defective. I find in very cold weather the transmitter stops sending the temperature.
Posted on Dec 08, 2016
No outside temp in de display only - - -in thedisplay i see the room temp. No outside temp. I have checked the outside transmitter end i see the red flash.
my unit tells me to insert fresh batteries into the outside sending unit first. then insert new batteries into the inside receiving unit. after the outside temperature shows up, then can reset my inside unit's time, choose F or C and
switch channels. please try changing channels if your
outside temp doesn't show. you can do both units in the house then put one outside after they work properly.
Mar 29, 2018 | Home
I have a model #WS-9037un-it with a model TX29Uremote transmitter. When I removed batteries there was a reading on it when I put in new batteries no temp. waited several hours.
  • Install known-good batteries in the transmitter. Wait for transmitter to initialize and begin sending temperature data
  • At the receiver, install known-good batteries. You should see outdoor temperature displayed
Dec 07, 2016 | Measuring Tools & Sensors
I have eight atomic clocks,none of them have the outside temperature working,all have new batteries???
If your outside temperature is not showing on your clock, that may mean that the clock and the transmitter have lost their connection. To reconnect them you must first take the batteries out of both of the units for 15 minutes. First put the batteries back into the transmitter, and then the clock. Let them sit side by side inside your home. When both the indoor and outdoor temperatures show on your clock with the same reading, or within two degrees of each other, then you may put your transmitter back outside. Remember to keep the transmitter out of the direct sun in a dry place. Also keep it away from metal, which can affect the readings.
Oct 20, 2014 | SkyScan 86742 Digital Atomic Wall Clock
Can't get outside temp on my atomic clock
If you still have the instructions read up on pairing the transmitter to the clock. You'll need to do that every time you change batteries on the outside transmitter. If you don't have those instructions , go to the clock's web page to get the manual for your model of clock.
Sep 23, 2014 | Home
Screen is unreadable after charging battery on M752
take the tablet back to where you got it and get a new one if it has been to long get ahold of tech support for solutions and if there solutions don't solve the issue and you have owned it less than a year they will more than ikely send you a new one in return for the old one.
Nov 11, 2013 | Kocaso M752 Dual Camera Android 4.0 ICS...
I cant get my weber remote thermometer to read the temp.
Note: both the transmitter and receiver unit have a re-set button under the battery compartment lid. If the receiver is not receiving a signal from the transmitter, you will need to disconnect the probe and re-set both units while 'on' before re-connecting the probe.
This is straight off the weber website, and it works coz mine just started reading temp
Jan 08, 2011 | Vacuums
I put new batteries into both units, the indoor unit and outdoor unit, now it is not able to read the outdoor temperature. What needs to be done?
I'm having the same problem and can't find an answer. Seems this also happened with another model we had - planned obsolescence? It was working fine, flashing due to low battery. Now, nothing from outside. Annoying.
Oct 16, 2010 | Acu-Rite AcuRite IndoorOutdoor Wireless...
The outside temp sender won't work. We put new batteries in it, but it does not send a signal. It will not put an outside temp on the clock.
Simple, the instructions state that when changing the batteries on the outside temp. sensor, you must also change the batteries on the main clock unit. I had same problem when I changed the sensor batteries until I pulled the batteries from the clock and it reset fine. ( Sensor batteries first, then clock batteries. ) The clock will reset to atomic time overnight so don't worry if it doesn't read correctly at first.
Aug 18, 2009 | SkyScan 86709 Atomic Wall Clock
I have no outside temp. reading on my clock.
Remove batteries from the clock and the outside temperature transmitter. Put the clock and the transmitter next to each other, then install the batteries in both units. This should fix it. If not, you have a bad tempurature sending unit, or a dead battery in the sending unit.
Jul 06, 2009 | SkyScan 86709 Atomic Wall Clock
Unit cycles,every 5 seconds while hot tap is on.Will fire eventually, but is reading 80 or less on the thermostat in the morning. I unplug unit and try again.Propane unit,530DVP. 2 years old, first season...
you need ot set the temp up higher, the temp it is showing you is what it is set at,, it is not a thermomiter, it is the setting, hold the up button in and the numbers will go up then you will get water at what the reading is
Jun 26, 2009 | Rheem Tankless Hot Water Heater...
Measuring Tools & Sensors Logo
258 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
