Question about Mr. Heater Heating & Cooling
I use my Mr. Heater 15,000 BTU Propane Heater / Cooker in a hunting shack out in the woods. At least 2 of the four windows of the shack are open when using the heater.
Yesterday right after discharging my 12ga slug gun, the heater caught fire with visible flames coming from and all around the back of the heater. It made a loud "whooshing" sound at the same time. It extinguished itself after a few seconds. I checked it today for dead bugs, cob webs, and gas leaks and none were found. I operated the unit with no problems today. I can only assume that the muzzle blast of the shotgun (5 feet away) caused the problem. My question is: is this normal with this type of heater? Have you had any complaints of the same thing happening to other hunters? I will really appreciate any thoughts or comments!
  • 21,014 Answers
Well first thing is don't discharge a 12 gauge indoors! Having said that, good job this time because it has identified a propane leak! Check all the joints for leaks using soapy water and look for bubbles. The flamey explosion will have got rids of the bugs and cobwebs. :>)
Invest in a Carbon Monoxide Monitor as well.
Posted on Dec 08, 2016
Cannot get it too light
PDF]operating instructions and owner's manual - Rural King
www.ruralking.com/.../MH9BX_Portable_Propane_Heater_Manual.pdf
light, adjust or operate the heater. PORTABLE PROPANE HEATER FOR RECREATIONAL AND COMMERCIAL USE. MH9BX. Model #. 02/09 32030. MR.HEATER, INC., 4560 W. 160TH ST., ... Get fresh air at once! Have heater serviced. speciFicatiOns. MODEL NO. .... Some people cannot smell well. .... Buddy series hose.
Mr. Heater Portable Buddy Propane Heater - Bass Pro Shops
www.basspro.com/...Heater-Portable-Buddy-Propane-Hea...
Bass Pro Shops
Feb 03, 2016 | Mr Heater Base Camp Portable Buddy Propane...
Pilot will not stay lit on my mr. heater buddy. where do i get a thermocouple for this buddy model no. MH9BX
First follow this trouble shooting guide to make sure you need one-http://www.mrheater.com/product/faqs/little-buddy-troubleshooting/ Then Amazon http://www.amazon.com/Mr-Heater-Pilot-Assembly-Portable/dp/B008DBRB8W Make sure it's the right one for your model heater.0810snp
If you need further help, I’m available over the phone at https://www.6ya.com/expert/oscar_403cc49e0f00cda7
Feb 24, 2015 | Mr Heater Base Camp Portable Buddy Propane...
What size propane tank do i need with a Mr. Heater 45,000?
Rule of thumb is that you have 100,000 btu's per gallon of propane. This only translates into the length of time you have available in a tank of gas. The problem arises when you consume too much too fast. The gas can't produce enough vapor to continuously run and becomes dormant which is commonly known as "freezing up". You can use a typical (20 lb.)5 gallon propane tank (barbacue size), but it will more than likely freeze up in 2 - 3 hours of continous use. I'd suggest going to the next larger size a 30 lb. or 7.5 gallon size. The best way to work this system is to have two 5 gal. tanks so you can switch one out when it freezes and let it thaw while your using the spare.
Oct 04, 2010 | Mr. Heater Natural Gas Garage Heater -...
Pilot will not stay on
replace your regulater,which almost cost as much a a new heater.I have own 4 or 5 and finally got a good one,I have in the past cleaned out the regulator that was plugged with oil from the propane,they put oil in the propane for leak detection,I hope this helps you
Dec 02, 2009 | Mr. Heater (F274825)
Can't get an outdoor propane heater to light.
turn off propan and heater. Undo the connector hose. then rehook hosewith heater valve off, Turn on propane valve real slow. Propane bottle valves have a safety that senses rapid escape, like in a wide open dump. This should reset it.Then light the pilot . should work.
Jun 08, 2009 | Mr. Heater Propane Outdoor Heater/Cooker
Heating & Cooling Logo
55 people viewed this question
Top Mr. Heater Heating & Cooling Experts
Paul Carew
Mack Baxter
vance jones
Are you a Mr. Heater Heating and Cooling Expert? Answer questions, earn points and help others
