Question about True Refrigerators
True T-DD-1 sounds like a rattling/fan hitting noise coming from inside the unit minutes after compressor turns on, and its freezing at the top by the evaporator..but unit is cooling. set at 4-5
  • 552 Answers
Probably low on refrigerant
Posted on Dec 09, 2016
Our prep table is making a loud noise,like its trying to go out but its not that old
What kind of noise? Where is the noise coming from? Inside the unit or where the compressor is?
Mar 25, 2014 | True Refrigerated Sandwich Prep Table 72"...
Coleman RV Rooftop Air Conditioner - cage fan making a noise like it is hitting on something as it goes around. The motor works as it should, low and high fan and cool, the air is cold. The only thing...
Those squirrel cage fans have a habit of coming apart, or getting dirt in them and going out of balance...then they wobble and hit the sides of the fan housing...
Make sure the fan is clean and also move it around a bit to make sure it is not coming apart....
Often the only way to fix them is too replace the sqirrel cage part...
Mar 06, 2011 | Dometic Rooftop RV Air Conditioner
Jenn Air - JCD2389GES Side by Side - Freezer cold, refrigerator not cooling. No real frost buildup in Freezer - took back panel off and no frost on coil... Compressor is very warm. Fan is blowing on...
Sounds like a bad overload/relay . On the compressor , with the refrig unpluged , pry off the box on the side of the compressor with 2 or 3 wires going to it . If you have a meter that beeps on the continuity setting , touch the 3 compressor pins 2 at a time . If no beep , compressor is bad . If a beep from either of the 3 pins to the copper lines connected to the compressor , then the compressor is shorted . If all 3 pins beep , replace the overload/relay pt # 12002784 .
NOTE : if you do not have access to a meter , shake the relay ( black piece ) and listen for rattle noise . If rattles , its bad .
Sep 27, 2010 | Refrigerators
Constant loud noise when frig turns on/comes from bottom
when the compressor is running unplug the ref. and if you hear the noise coming from the compressor then
a ballance spring may be broken inside the compressor.
The compressor will run normally with a broken spring it will just be annoying when it shuts down.
Jan 16, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Hot Point rattle noise after it runs sounds like noise is coming from the back near the top . refrigator model # CTX21GAXSRWW
Hi the sound come from the fan it is locate inside the freezer behind the back wall.
you can open the back wall and check if the fan hit something.. some times it hit ice ..
let me know if you need more help.
Jan 12, 2010 | Refrigerators
I noticed some straining noise coming from my a/c unit today. The fan on top of the condenser runs fine but as soon as the compressor tries to kick on the fan stops for a split second and you get a kind of...
You amy ahave a bvad capacitor on the outside unit. It starts the fan and the compressor. You can change this yourself. Open the outside panel and you will see a silver canister with terminals out the top. Replace this and I think your problem will go away. On the cap. it will say something like 30uf 5uf 370 ot 440 Just get these numbers and get a new one. Russ
Aug 14, 2009 | Goodman CKL24AR24 Air Conditioner
My new Kenmore window unit 76081 makes loud rattle
If it does not make the noise when the fan is ruunin you may ahve abroken sping in the compressor. Make sure you Window unit is level. If not the compressor will knock on the inside. Rusty
Jun 12, 2009 | Kenmore 76081 Wall/Window Air Conditioner
Loud buzzing noise from inside Jenn Air 2389G fridge
i don't know jennair specifically being from england.
however, there is often a fan inside the back panel and the noise you heard was the fan hitting ice. the reason now not heard and fridge not working may be that the ice has built up so much the fan is jammed
Jun 25, 2008 | Jenn-Air JCB2388G Side by Side...
Amana bottom refrigerater
huthy, the fact that it's lasting 15 to 20 seconds leads me to believe that it could be one of the fan blades hitting. The valve springs on the compresser would make more of a clunk-clunk noise and wouldn't last that long. The evaporator fan in the freezer compartment has a grille that will snap on and off, clip on the bottom and tabs on the side. See if you can remove the grill and check to see if there is any ice build up around the evap. fan. The other fan, condensor is in back by the compressor, it could be hitting on the shroud upon start up or shut down. Check these things first and post back...Catriver
Mar 20, 2007 | Amana ABB1927DE Bottom Freezer...
Fridge keeps ticking when not running???
Kevin, I'm going to give you a few scenerios to check out. The evaporator fan, inside the freezer will sometimes come in contact with ice and make this noise. Check your condensor fan, in back and make sure that is not hitting the shroud. If the overload on the compressor is tripping it will make a clicking sound, but it would be about every 4 to 5 minutes. If the unit goes into defrost, the evaportor coils tend to make a clicking sound. If you can be more specific as to where the noise is coming from, we might be able to help you back.
Aug 14, 2006 | Whirlpool ET9FHTXMQ Top Freezer...
Refrigerators Logo
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
