Question about LG 42LC2D 42 in. LCD HDTV
Turn the tv on sound ok but black screen - LG 42LC2D 42 in. LCD HDTV
Lc-60le835u screen going black,turned off for minute,turn back on okay for 15 minutes then screen goes black again, now screen is always black the sound is ok,need 2 know what it is I need to replace?
I would only guess on this without testing it and having a repair guide, but the PCB that controls the screen display is called the "T-Con" PCB
Nov 04, 2016 | Sharp Lc-60le835u Led Tv
No picture
Sounds like you have a backlight problem. To verify this, turn on the set, dim the lights in the room, and shine a bright flashlight on the screen. If you see a faint picture you have a backlight fault. It could be as simple as a bad capacitor in the power supply, or a faulty inverter board, or in rare cases a bad backlamp.
May 04, 2013 | LG 32LD350 32 in. LCD TV
Screen goes black on toshiba tv how to fix
I would check to see if any capacitors have gone bad or are going bad.
Oct 07, 2012 | Toshiba 32A60 32" TV
Black out
Try turning off the Closed Caption..
Feb 03, 2009 | Polaroid TLA-01511C 15 in. LCD Television
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
How to get rid of a black screen on my tv. sound is ok
If you mean that you get a black box, with a little of the picture visible around the edges, then your closed captions are on and set to TEXT. This puts a black box on the screen about 10 seconds after changing the channel. Go into the menu and turn off the closed captions and the picture will be back to normal.
Jul 07, 2007 | JVC AV-27530 27" TV
TV screen went black, sound OK
check cold solder vertical circuit
Nov 21, 2006 | JVC AV-27530 27" TV
Black screen and have sound
find problem here in threads,
Nov 15, 2006 | Mitsubishi VS-4543 45" TV
LG 42LC2D 42 in. LCD HDTV Logo
156 people viewed this question
Computer Repairing
Computer Repairing
