Question about OKI Office Equipment & Supplies
Where is the print head of oki data c 711 - OKI Office Equipment & Supplies
  • OKI Master
  • 824 Answers
Open the main cover. Look up inside it and there you will see the long black printhead (A4 wide) hanging down. It will have a white flat cable connecting it to the machine.
Posted on Dec 20, 2016
Please I have an oki printer C831 that's printing only yellow and black on any printing am using it to print please help
I would think you have broken ribbons cables to the cyan and magenta LED print heads. As all the heads are the same I suggest you swop the black and cyan print heads around and see if cyan prints and black does not. That will prove is the print heads are ok. If they are then the ribbon cables need replacing or they are dirty at the heads. It could be just a case of unplugging them, clean them, then plug them back in again.
Oct 21, 2017 | OKI Office Equipment & Supplies
How to fix okidata c 711 error code 134
Error code 134 on the OKI C711 refers to the white ribbon cable that plugs into the Black LED head. If it has come out of the head then check that the silver contacts are in good condition and none are touching each other. If any of them are touching each other then its a certainty that fuse F12 on the main board will have blown. If they are good then push it back in but this must only be done with the power off. I cant remember whether the 711 has a plug on the end of the cable or just has silver contacts. If F12 has blown then you cant replace it as its part of the board. Only a pcb repairer can change it or fitting a new board.
Dec 08, 2016 | OKI Office Equipment & Supplies
Oki 321 turbo,printing goes too far on left side
Not usually, Go through the paper park, where does the head stop when you turn it on. There is a switch in the base of the machine...
Aug 01, 2016 | OKI Office Equipment & Supplies
My Oki C310dn printer prints lines through everything.
You need to do s head clean.
This could take 2 or 3 goes but should fix it you will find head clean in the maintenance settings.
It eats the ink so only do as you need.
let me know how it goes.
Regards Craig
Feb 03, 2018 | OKI C Office Equipment & Supplies
My oki data C5200 in printing a faded picture along the right side of the page only. I have cleaned the print heads and checked the levels in the cartridges. Everything seems to be fine. Can you help?
> OKI C5200n laser printer
Take the toner-cartridge out, and gently tilt it left-and-right
to redistribute the remaining toner in the cartridge.
Reinstall it.
Oct 13, 2010 | OKI C5200n Laser Printer
My oki 320 prints with a gap in each letter how do i solve this
If the missing spot is always the same it sounds like a broken pin in the print head. If this is the case you need to replace the print head.
Feb 18, 2010 | OKI MICROLINE 320 Matrix Printer
When printing all I get is a message saying invalid data (printer B4300)
I had same problem and when I installed OKI B4350 (PCL) driver it started working fine.
Before I had OKI B4350(PS) driver installed and it gave me invalid data error everytime I've pressed print.
I hope this works for you too.
May 22, 2009 | OKI B4350 Laser Printer
I have a OKI Microline 320 printer.
Your printer has a damaged mainboard. Very sorry, for yours is a very good unit. the replacement model is the Oki ML-420, which comes with a 3-year warranty.
Be blessed.
Oct 30, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Hi Charles,
Use the IBM proprinter driver for this printer and select IBM in the menu of the printer.
Hope this helps.
Sep 10, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
you are correct, you need a new print head OR adjust the head gap on the carriage
Sep 13, 2007 | OKI MICROLINE 520 Matrix Printer
Top OKI Office Equipment & Supplies Experts
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
