Question about Jenn-Air JES9800A Electric Kitchen Range
JES9800AAQ beeping and scrolling F1-7 error.
Range works but not the oven. I have turned off the breaker due to annoying beeping. I can push the auto set on the control panel and the beeping will cease and only come on every so often with the error message. I have read some of the solutions but am not sure what to do now.
Donna
  • 146 Answers
SOURCE: oven panel
First try unplugging or turning off the breaker and see what happens. If that fixes it your good to go if not you probably need a control board. Some of the boards have a fuse but no one changes it as it is soldered onto the control board.
Posted on Dec 21, 2007
Oceti
  • 51 Answers
SOURCE: Jenn-Air Gas Range
F1 is a bad power relay board.
F8 is a shorted meat probe alarm (probe jack or the harness to the probe jack)
Posted on Jan 18, 2008
  • 330 Answers
SOURCE: Oven no longer works
Is a gas unit ?
Posted on Jul 06, 2008
SOURCE: Jenn Air slide in range JES9750AAB - Touch Pad
put on tree belt . having the same problems replaced ERC $200.00 now they are telling me touch pad touch pad is $240.00 .the stove cost $1300.00. $1740.00 how much more will i have to put in this stove
Posted on Jan 06, 2009
jumptrout51
  • 3361 Answers
SOURCE: I am getting error message FC on oven control
FC Communication error between boards Wiring harness or power relay board (PRB)
Posted on Oct 28, 2009
My probe beeps when I use my oven, how do I correct this
I'd reset (Turn off and back on) the Oven circuit breaker to see if that fixes. Otherwise, Owner's manual troubleshooting.
No manual? try this: http://www.manualslib.com/
Mar 09, 2015 | General Electric Profile PD900DPBB 30"...
Oven will be off f1 comes up and beeping have to turn it off at breaker to use turn breaker on and have to turn oven on low setting to use range if oven is not on then f1 and beeping oven does not get as...
Hi
Thanks for using FixYa. F1 error indicates that the control board (ERC) has gone bad and the electronic range control (ERC) should be replaced to resolve the issue. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 25, 2010 | Ovens
My ge electric range keeps on beeping f2
The F2 error code means: For an unknown reason, the oven temperature has exceeded a preset threshold.
This is GE's recommendation:
Before Calling Service, you can try the following...
Sometimes shutting off the circuit breaker that the range or oven is connected to for 30 seconds will clear the fault, error or function code, however there are some cases when further service may be required. If you would like to schedule a service appointment, please contact GE Consumer Service at 1-800-432-2737 or schedule a service appointment on-line.
GE does recommend turning the range or oven off at the breaker until you have it serviced. It is okay to cycle the breaker and turn the range or oven back on long enough to use the surface units. Be sure to turn the range or oven off at the breaker again when you have finished.
May 17, 2010 | Kitchen Ranges
Jenn-Air SCE 30600, oven error codes F1 and Probe
An F-1 error code on your model means the element was energized when it should not have been, A shorted interconnect harness or failed power relay board.
A probe indication could be a failed meat probe jack or bad harness in a unit that has one. In a unit without a meat probe, suspect a bad board.
Both conditions would warrant bringing in a tech.
Before you do, turn off the circuit breaker fot 3 miutes and turn it back on. This will reboot the boards. If problem persists, the call a service tech.
Nov 04, 2009 | Jenn-Air SCE30600 Slide-In Electric...
Roper electric range non stop beeping!
I'm thinking a door switch problem and/or maybe an intermittent keypad connection. Failing that, the electronic control may have failed. We repair oven controls at www.fixyourboard.com.
Sep 30, 2009 | Roper FEP320 Electric Kitchen Range
I CAN'T UNLOCK MY OVEN DOOR!
First get rid of the noise by turnining off te breaker.
You will have to pry the lock open.
This is common I use a small screwdriver and coathanger wire,then pull out oven enouhg to replace lock.
Mar 12, 2009 | Ovens
Wont stop beeping
try turning the breaker off for 5 min and reseting it
Nov 29, 2008 | Jenn-Air JES9860 Electric Kitchen Range
Frigidaire Range FEF357BBD error code F9
I had the situation where the oven thinks the door is locked but it was not locked. Setting and holding clear eventually gave a f9 error.
I solved this by turning the circuit breaker off and taping over the oven light switch ( so it thinks it really is locked ) and turning on the breaker. The oven unlocked and appears fine now.
Nov 09, 2008 | Frigidaire PLEF398AC Electric Kitchen...
F2 error
what is solution
Dec 08, 2007 | Ovens
Have a magic chef oven, f1 display after self cleaning, stove top works fine, any thoughts
F-1 is a fault code.
Disconnect the power plug or turn range power off at circuit breaker. Wait a couple of minutes, then plug the range in or flip the range circuit breaker to ON.
Oven control beeps & displays any F  code error (for example
F11) - Electronic control has detected a fault condition. Press
CLEAR/OFF to clear the display & stop beeping. Reprogram
oven. If fault recurs, record fault number. Press CLEAR/OFF
contact an authorized service agent.
Dec 01, 2007 | Magic Chef CER3725AA Electric Kitchen...
Jenn-Air JES9800A Electric Kitchen Range Logo
100 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
