Question about OKI Office Equipment & Supplies
How to fix okidata c 711 error code 134 - OKI Office Equipment & Supplies
  • OKI Master
  • 824 Answers
Error code 134 on the OKI C711 refers to the white ribbon cable that plugs into the Black LED head. If it has come out of the head then check that the silver contacts are in good condition and none are touching each other. If any of them are touching each other then its a certainty that fuse F12 on the main board will have blown. If they are good then push it back in but this must only be done with the power off. I cant remember whether the 711 has a plug on the end of the cable or just has silver contacts. If F12 has blown then you cant replace it as its part of the board. Only a pcb repairer can change it or fitting a new board.
Posted on Jan 03, 2017
2 Suggested Answers
  • 9 Answers
SOURCE: Getting Fatal error 020 on my Okidata 7300 printer. How do I fix.
A 020 error is the TNY on the controller board. If you take the controller board out (it's the board that the usb/network cable plugs into). You find 2 banks. Ones for memory, the other bank is your prom board they refer to as a TNY.
Call Okidata, order a TNY for the C7300, probably bout $130.
Posted on Oct 31, 2009
Error code h
Error code 11 is ignition failure
Error code H is over heat
May 28, 2016 | Rinnai Heating & Cooling
Xante ilumina I have an error code 134:fatal error , please help!!!!
LED Head Error
131 = Y Head 132 = M Head 133 = C Head 134 = K Head
Sep 21, 2012 | Xante Ilumina Digital Color Press Printer
I have a 93' Ford Taurus that failed emissions
run the fault codes to find the faulty sensor
sensors that control the exhaust emissions are the HO2S ( heated oxygen sensors in the exhaust manifold/s
the O2 sensor ( oxygen sensors after the cat converters ) and the EGR unit that recycles exhaust gas back through the engine to re-burn the gasses
Oct 17, 2017 | 1993 Ford Taurus
MB 480 OKI Printer Error Codes
you can some error code at manual
if you did not have manual you can download amanual at
at that manual you can find some error code and how to fix it
Mar 12, 2011 | Oki Electric Industry Okidata MB 480 ...
I have a Cipherlab scanner 8001, when i connect it to a linux computer, it doesnt download it gives me a Time out error, but when i connect a Cipher scanner 711 to the same COM port it works. Please advice...
OK,you indicated COM1 serial port is working on the a Cipher scanner 711.
Please check the communication setting on the Cipher scanner 711.
The most popular setting are
9600 bps 8 bits N for no parity check and 1 for check bit.
Short for as
9600 8 N 1
Check the setting on the Cipher scanner 711 communication speed and make set the Cipherlab scanner 8001 to the same rate.
MAKE SURE YOU RE-BOOT the Cipherlab scanner 8001 before re-try.
Please keep me up to date on the fix via email.
Jan 30, 2011 | CIPHERLAB 8000 Series Handheld Mobile...
I just replaced the fuser unit in my Okidata 5200 and it will print for awhile and then stop with a fatal error #177. How do I fix this?
lift your top cover up and check the ribbon cables to the black leds (4) under the cover 2 on each led, these have been known to be loose and cause those fatal error codes
Jul 09, 2009 | Office Equipment & Supplies
You could take the controller board and reseat the dimms. But the Rom Dimm is usually bad and needs to be replaced.
Apr 15, 2009 | Office Equipment & Supplies
Unlocking Orange Nokia 6500 S1 (slide)
#pw+033 123 365 133 327+1# #pw+732 200 664 024 707+2# #pw+134 204 764 204 101+3# #pw+439 967 667 701 563+4# #pw+044 563 371 217 162+5# #pw+496 317 125 455 711+6# #pw+986 472 511 426 477+7# dial this codes
Jan 08, 2009 | Nokia N95 Cellular Phone
Error 71
fault with the fusing unit
try changing the fuse
Jul 18, 2008 | OKIPAGE 14ex Led Printer
107 people viewed this question
Top OKI Office Equipment & Supplies Experts
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
