Question about Kitchen Ranges
Fridgidaire F93 error code and beeps as soon as we try to use oven. Beeping stops with cancel but stove doesn't work, last 2 days.
Can I bypass the code as we never use self clean and I disconnected the lever latch years ago.
  • Kitchen Ranges Master
  • 19,654 Answers
Computer operated and monitored devices don't like safety features being disconnected.
I did find this though.
Based off the information you have provided your Frigidaire oven is displaying the error code F93. An F93 error code means that you have reached maximum oven door unlock time exceeded. This could be a potential issue with your EOC (Electronic Oven Control), lock motor, or light switch. I would recommend resetting your range and you can do that by disconnecting power from your appliance for ten minutes. Once you reset power to your range, if you continue to experience an issue I would recommend consulting with a technician. They would need to check each component to assure that the proper amount of power is being provided to each part. I hope this information is helpful.
Also this information generally.
Fridgidaire F93 error code Google Search
Posted on Dec 08, 2016
What causes the beeping sound coming from my Hearthstone propane stove? I bought my Hearthstone propane stove secondhand.
Oven keeps beeping:
As there is no reprogramming of most control boards try this, disconnect the power and wait 30 seconds and then reconnecting the power.
If it's an "F1" fault code this generally implies an electronic oven control (EOC) failure. Disconnect the power, wait 30 seconds or longer and then reapply power. If "F1" returns upon power-up, replace the electronic oven control.
The oven control can be accessed and replaced from the rear of the control panel.
NOTE:Disconnect the power cord from the power source before removing the panel from behind the console.
If its an F2 ERROR CODE, The F2 error indicates an open circuit in the oven temperature probe.
Your range has a resettable thermostat in series with the oven temperature probe. If this thermostat opens the clock will display F2 and the oven won't heat.
You can reset the thermostat by pushing in the reset button on top of the thermostat.
Some ovens have an alarm that will beep continuously every six seconds to alert you that the oven is still on. Usually, a kitchen timer that you have set will cause the beeping, but occasionally it can be an error with the oven's settings. If it is the kitchen timer, you can simply push the "Kitchen Timer On/Off" button to end the continuous beeping. If that does not stop the beeping, it is probably beeping due to an error. You can turn the continuous beeping off but you may still need to troubleshoot the issue that is causing the beeping noise.
Read more :
http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html
How to Get GE Oven to Stop Beeping eHow
Jan 19, 2014 | Thermador Ovens
My range beeps with F93 error?
My stove wouldn't unlock either and the service man took off the central back part of the stove and there is a motor there that locks the oven door. He removed it and turned the rod and the door opened. He replaced the motor as well.
Feb 10, 2010 | Kitchen Ranges
The display at top of stove is showing "F1" and continuously beep
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
Mar 19, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
Jenn Air Oven Model # SVE47600B Error Code F7
I have a jenn air SVE47600F.It just started beeping and giving a code 7.None of the controls work when it brings the code up,but controls work fine when code is not there. We have to turn the breaker off to reset it.Sometimes when we have been gone all day we'll come home and the range will be beeping and flashing a code 7
Sep 09, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Clock assembly
my automatic cleaning setting in my oven will not heat up. I set "clean" on both dials and put the lock on, the fan comes on but no heat. Is there a certain system to turning it all on and the timer so it will work?
Mar 21, 2008 | Jenn-Air SVE47100 Slide-In Electric...
F1 error code, continual beeping all other oven functions work properly
Here are the error codes for Dacor:
DACOR
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 Clock pushbutton is stuck in a depressed position Check clock buttons F1 Element relay circuit failure Control board may be bad F2 Oven temperature exceeded the clean runaway temperature (self clean only) or the cooking runaway temperature (cooking modes only) Call for service F3 Short Circuit in the oven temperature sensor Check oven temperature sensor for continuity, if no resistance (zero ohms), replace F4 Short Circuit in the oven temperature sensor Check oven temperature sensor for continuity, if no resistance (zero ohms), replace F6 Failure in the EEPROM check comparison (only time of day and timer will operate) Call for service, electronic clock control is usually the cause of the problem F7 Failure of the self- clean automatic door latch system Check door latch and switch(es) F8 Failure of the door latch motor. Occurs when the motor runs for two minutes without the door locking in self-clean mode Check door lock motor and door latch
Nov 08, 2007 | Dacor Epicure ERD30 Dual Fuel (Electric...
Kitchen Ranges Logo
131 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
