Question about Vacuums
I ordered vacumn cleaner bags. Wrong size. How do I send them back I asked for ups to pick up at my house no one has come
    Top Expert:
  • Vacuums Master
  • 49,064 Answers
Firstly you need to contact the seller for return authorization . when they send that they may tell you how to return them
Posted on Dec 08, 2016
Vacumn cleaner does not start green light indicates power goes to the vacumn cleaner
the top part of the cage where the bag goes in has a tiny switch that goes down when the bag is in.Sometimes the cardboard top of the bag does not depress the switch.Check thast first.
Sep 13, 2014 | Electrolux hose 2100 series diplomat
Vacumn motor does not start with the switch. Light indicates the vacumn is on
check the top area of where the bag goes in.There is a tiny switch that get pushed down by the cardboard top of the bag.This is to protect the motor by not allowing the motor to engage without a bag
Sep 13, 2014 | Electrolux electric hose models 2100
My Miele S3141 canister began acting strange this morning. No I took off the hose and checked for blockage, (nothing). Now I can't get the hose back on the canister. It just slips ar
see this causes and fix it. God bless you
Air filter:
If the vacuum cleaner won't pick up dirt and has no suction the air filter might be clogged. Remove the filter and either clean or replace it as needed.
Exhaust Filter If the vacuum cleaner won't pick up and has no suction the exhaust filter might be clogged. Remove and clean the filter, replace it if its torn or damaged.
Vacuum Hose If the vacuum cleaner won't pick up and has no suction the vacuum hose might be clogged. Remove the hose from the vacuum cleaner, stretch it out straight, shine a bright flashlight in one end and try to see light through it. If no light can be seen, use something to run through the hose and free up the obstruction.
Vacuum Bag If the vacuum cleaner won't pick up and has no suction the vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup assembly might not be installed tightly, or it might be cracked or broken. The dust cup must seal tightly in order to produce the right amount of suction. If it is cracked or broken, replace it. Most glues and adhesives will not successfully seal the crack.
Blower Wheel If the vacuum cleaner won't pick up and there is no suction, the blower wheel might be jammed or broken. Check the blower wheel to be certain it turns freely. If it doesn't, check to see if there is anything rubbing against it. If not, but it's hard to turn, the motor is most likely the problem.
Sep 27, 2012 | Vacuums
I have a Kenmore vacuum cleaner 116.35922 and it's making a loud noise and not picking up dirt. I checked the hose for a clog and changed the bag. What else can I do?
Check to see if the brush is spinning when the unit is running. If not, the drive belt may have broken and will need to be replaced. Common sized replacement belts can be purchased at most department stores. Kenmore belts should be available at most Sears stores.
Another possibility is that if a large enough object was picked up, it may be lodged in the impeller, or impeller housing. If so the housing will need to be disassembled to determine if any physical damage was done, and to clear the debris.
Feb 24, 2011 | Vacuums
My vacumn cleaner stinks when in use, but it is not the bag to full?
I only know how to do things in a systematic approach so if I ask to many questions and this response seems to wordy disregard.
First: What type of stink are we talking about? Burned Rubber like a belt being worn out? Or stink like a junk yard?
Second: Do you use through away bags or just empty the bag and and reuse it?
Third: Does it have any air filters (Hepa stuff like that)?
Fourth: If you remove the bag from the cleaner and run the machine do you still have the stink?
These aren't solutions as much as troubleshooting.
Jan 22, 2011 | Kirby G5 Bagged Upright Vacuum
What charge for this service?
Actually there are no hidden screws on your Electrolux Epic model. This is the newer plastic body canister made by Aerus Electrolux. In order to open the vacuum cleaner to inspect the motor, first open the vacuum bag door and remove the vacuum bag. After the vacuum bag has been removed, keep the vacuum bag door open.
The two rubber furniture guards on both sides of the vacuum cleaner are actually what are holding the top housing and the bottom housing together. You'll need to slide both of these rubber furniture guards off in order to open the rest of the vacuum cleaner. They slide forward towards the vacuum bag housing which is why the door needs to be open.
In order to get these slides started, it's sometimes necessary to put a flat head screwdriver in between the back of the furniture guard and the start of the cord reel housing. Right after the rubber starts behind the word Electrolux. Fit a flat head screw driver in this gap, and it's sometimes easier to use a hammer, and hit the screw driver that's on the furniture guard facing the front of the vacuum.
With a little perseverance, you should be able to get the slide started, and when the slide starts to come out past the vacuum bag housing, simply grab the end of it with a pair of pliers, and pull the rest of it out of the vacuum.
Do this on both sides of the vacuum, and you'll be able to separate the two housings, and get access into the motor compartment.
If you have any problems, or would like me to take a few pictures of this being done, I'd be happy to do so. Please just rate my repair as helpful if you found this advice useful. I really do appreciate this.
Thank you,
Chris J.
Apr 07, 2010 | Electrolux Epic 6500 Vacuum
I need vacuum cleaner bags for a WST 1300
call a vacumn or small appliance repair shop most vacumn repair shops will know what bags you need esp if they service your model or may be able to tell you who to call
Dec 18, 2009 | Vacuums
Can you replace the cloth bag in a beam central that is about 20 years old, the vacumn sends a dusty smell though the house
It is not recommended to change that bag. The best thing to do would be to borrow a shop vac from someone and vacuum it off really good. The bags sell for about $60.00 and they are a big pain to change out. The other thing you can do to help the odor is look into exhausting the unit outside. All manufacturers recommend it.
Jun 14, 2009 | Beam Industries 2775 Serenity Plus Central...
My vacumn wont pick up from the bottom but the hose works fine, I have an empty bag and the green light is on.
Either the glide plate at the bottom is blocked or the belt is broken
Please leave feedback
Feb 12, 2009 | Bissell 3522 PowerForce Bagged Upright...
Bissell Healthy Home Vacumn
On the Healthy Homes Vac, did you check the switch for the vac, there are 2 on the handle, and the one could be open. Check the wiring at the motor, could even be the motor itself. If at the motor there is a thermostat, it could be bad, but comes with the motor.
Jan 06, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Vacuums Logo
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
