Proper log placement on Kozy Heat gas fireplace mode #KH36-TRS
  • Heating & Co... Master
  • 3,183 Answers
Google make and model you should find wed site to down load manual.
Posted on Dec 11, 2016
  • 36 Answers
SOURCE: marco fireplace log placement
To help you out:
you can go to
They will either have it online or refer you to a contact person.
Posted on Apr 26, 2008
SOURCE: Need Instructions to use Fireplace Gas Logs
There should be a set of metal cards attached inside the fireplace.
First you should read everything there.
I know you have to first light the pilot light.
And then there should be a wall switch.
The problem I have currently is that it won't stay lit when the artificial logs are there.
Posted on Nov 23, 2008
SOURCE: I have a Martin ventless gas log fireplace. I
Sometimes when you turn a gas heater off for some time, if the source tank has been turned off, the line will bleed the propane and the line will contain mostly air. This is especially true if the supply line is long. In order to light the pilot, you will have to hold the pilot lighting button down for a while (a full minute or longer, depending on the size and length of the supply line) before pure propane arrives at the pilot light jet. You should keep a lighted lighter at the jet so that when the gas arrives, the lighter will light it. After the pilot lights, you will have to keep the button pressed long enough for the thermocouple to get hot enough to set the pilot to stay on. When it is hot enough, you should be able to release the pressed lighting button and the pilot should stay on. If it does, you should be able to light the heater. If the pilot jet never lights, gas is not getting to the regulator. If the pilot will not stay lit after a period of time waiting for it to heat the thermocouple, the thermocouple or the regulator may be bad and need replacement. :-)
Posted on Jan 03, 2010
  • 3183 Answers
SOURCE: Martin gas heater with logs flames hot but hard to see.
Hi do you the make and model
Posted on Feb 12, 2010
  • 90 Answers
SOURCE: gas fireplace
yes it is important to stack them right but just trying to figure it out by the depressions is not right you need a diagram to show you or just call service agent its better to do right or it will coast you later when it causes your heater to break down i've seen various ways that people try and do logs even following the book my best suggestion is call service agent they should know how to do it correctly
Posted on Nov 18, 2010
Wind blows out the gas logs
I am sorry, but there is insufficient information to give a proper answer. If it is a vented logset, is it in a vented indoor firebox/fireplace or an outdoor fireplace?
Jan 11, 2016 | Majestic Fireplaces Majestic VWF24NMD 24"...
Pilot is on, wall switches for both ignition & fas have been changed out. Still get NO flame when wall switches are turned on.
Heat & Glo ' Install & Owners Manuals
Each fireplace, stove and insert has a rating plate which contains your model number and serial number. Gas and wood burning fireplaces have a rating plate in ...
Resetting Your Heat & Glo® IntelliFire™ Plus Ignition ...
? 2:21
Aug 24, 2012 - Uploaded by HeatandGlo
Resetting Your Heat & Glo® IntelliFire™ Plus Ignition System Video ... Relighting Your Heat & Glo® Standing Pilot FireplaceVideo - Duration: ... How to Install Your New Gas Log Set - The Fire Place - Palm Desert - Duration: ..
Oct 07, 2015 | Heat N Glo 6000 Gas Fireplace Manual
I have mislaid the instructions for my Genesis Miami gas fire, and need to relay the ceramic logs. can anyone please help?
This will depend on whether the fireplace is vented or is vent-free. Vent-free gas fireplaces are sold as a kit with the valve, burner, media (logs, glass, shapes, etc) all designed for a particular placement to work together to reduce dangerous chemicals. A vent-free burner and valve cannot have the logs removed and replaced with some other type of ceramic gas log because the exact placement of the logs is designed around the ports in the burner where the flames rise to minimize carbon created from the flames touching the logs.
If your fireplace is vented then the pull of the flue will remove dangerous fumes created by the same placement so there are no rules about re-arranging or replacing "media". If the fireplace is vented then you could use other log-placement-guides to identify the type of log and where it belongs with little worry because vented logs are designed to be able to have some adjustment anyway.
If vent-free and without a manual, an educated technician should do this for you because the BTU setting on the valve must be compared to the types of burners, port placement, size of ports, amount of ports and flame height. After this examination, someone familiar with the various hidden "tongue-and-groove" etchings in different types of gas logs can figure-out where to place the logs. They may have to test the fireplace burning once or twice to get it exactly correct but once you understand the idea of how a vent-free gas log diminishes the carbon-output of the amount of gas flowing through the burners then it is only a matter of watching the flames to see where the logs could be and comparing the size and layout of the logs to find the best fit.
Feb 02, 2014 | Grilling
Kozy heat fireplace
On shoes? I haven't seen a fan like this, so I do not know what to tell you.
Dec 07, 2013 | Minnetonka Clothing Accessories
Gas fireplace log placement
google make model of fire this should give you makers web site and you can down load a manual with the log positions.
Apr 08, 2017 | Heating & Cooling
I have a black soot on all my walls through the whole house especially the exterior walls. I believe it is caused by my propane fireplace. Im not sure if it is not ventilating properly or what the problem...
Is a Vented or Vent-free gas fireplace? I really suspect it's Vent-free (ventless) as a vented unit, unless the direct vent is clogged exhaust everything, including 85% of the heat out side.
Here are the things that will cause a Vent-free Gas Fireplace to soot.
  • Not having the fireplace cleaned and serviced, at least annually by a qualified technician.
  • Misplaced logs that impinge the main burner flames.
  • Running a ceiling fan at the wrong speed and in the wrong direction while fireplace is burning.
  • Burning scented candles while burning the fireplace.
  • Low Gas Pressure to the burner.
Here are the solutions to the above listed causes:
  • Have the fireplace cleaned and serviced.
  • Check your Owners Manual concerning the proper placement of each log,
  • Run the ceiling fan Counter Clockwise and at the slowest speed. The fan on the side of the switch should be in the UP position for Winter and Down for Summer.
  • Scented candles soot any way. Add the warm moist heat of the Gas Fireplace and they'll soot 50 times worse. The scent is not natural, it has an alcohol base like after shave & cologne. Stop burning scented candles. It has been proven that they greatly contribute to indoor air pollution.
  • Low gas pressure causes incomplete combustion, which causes the burner to soot. Have it checked by your propane provider.
Based on my 15 years in the hearth and home business and having sold and installed hundreds of these appliances, I am will to bet, it's a cleaning and servicing issue or misplaced logs.
Hope this helps you solve your sooting problem. I woud really like to know how it works out for you.
Please let me know at
Thanks ... Rich
Feb 16, 2011 | Heating & Cooling
Heating & Cooling Logo
74 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
