What controls indoor fan speed on ASU12RLQ - Heating & Cooling
  • Heating & Co... Master
  • 1,922 Answers
I believe thats a goodman and it should have 3 speed tap wires coming from motor, normally connecting to a board. 2 are not being used the third is plugged into a relay on that board. Look at wiring diagram to determine what color is for what speed. Swap the wire on the relay for speed change
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Posted on Dec 09, 2016
Mitsubishi timer light 6 times blinking
Indoor unit indicator
RUN lamp = 6 time flash
TIMER lamp = Comes on
Outdoor unit indicator (LED5) = Stays off
Description of trouble = Indoor fan motor error (2)
Cause = Defective fan motor, Connector poor connection
Conditions of flashing = When air conditioner is operating and indoor fan motor is turned ON, indoor fan motor speed of 400 rpm or under continued for more than 30 seconds. (Air conditioner stops.)
May 29, 2016 | Mitsubishi Heating & Cooling
One of my Fujitsu indoor units will run on high speed,is board the problem?
Most likely a faulty indoor controller board but also possibly a faulty fan motor. Call a tech to diagnose.
Feb 16, 2015 | Fujitsu Heating & Cooling
Error message U4
Signal transmission error. Indoor and outdoor PCB's cannot communicate. Usually a faulty controller board in the outdoor unit. If the indoor unit otherwise functions normally (can control fan speed, louvres, beeps in replay to all remote buttons) then it is probably OK so check outdoor controller PCB.
Jul 21, 2014 | Daikin Mini Split Concealed Duct Units
On its own went from low to high speed and can't slow it down
Windings in the motor shorted out or the switch shorted out.
Sep 11, 2012 | Hampton Bay Ceiling Fan. Altura 68 in....
Indoor unit fan is not working on high speed
Check your wiring, make sure you have both the lights and motor power connected to the hot wire and 1 to the ground. Hope this helps
Dec 24, 2011 | Heating & Cooling
Fan noise indoor unit (asu12rlq) fujitsu
A high pitched noise from the fan unit, means a bearing issue from the motor. You must replace the fan motor to get rid of the noise.
Dec 17, 2011 | Fujitsu 24R1 Air Conditioner
8 blinks on unit shutoff,no continuous run
Indoor unit Fan problem. This is caused by the Indoor fan being locked. Check fan motor is plugged in correctly, Electrically & Mechanically sound.
Check the fan motor turns freely, check the AC Voltage supplied to the fan motor, this will vary from 120 V ac at low speed to 170V AC at high speed. If no
Voltage is present the the PCB is faulty, if Voltage is present the fan motor will be Fault.
Helpful?
Jan 19, 2011 | Heating & Cooling
Indoor fan slow to rotate in heat mode and no heat/compressor
The indoor fan will not run at normal fan speed untill the indoor coil reaches 32oC. This is done so that a cold draught is not felt when outdoor unit is not running. Check to make sure the outdoor unit is operating. If the outdoor fan is running but there is no indoor fan after 5 mins then you must likely have a gas issue or a fault compressor circuit.
May 31, 2010 | Fujitsu 24R1 Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
