Question about Electronics - Others
Onity Lock. Wais wrong when card reader Flash Red when card is put in. I put new care reader it flash red. I cand mover card reader to another door and it work
SOURCE: filter light still on "Red"
try holding ice type and child lock together for 3 seconds that worked on mine
Posted on Jan 08, 2008
SOURCE: mikomi card reader
I also have one of these readers and bought a 4gig SD card. When I put it into the reader, I also had the same error message to insert a card into the drive. I was told by a colleague that the reader may not be able to read a card bigger than 2 gigs.
Posted on Apr 18, 2008
SOURCE: Dell 2407 WFP monitor Flash Memory Card Reader does not
if on the card it is written SDHC then it means that the card reader doesn't support SDHC cards, for 100% compatibility try a 2/4 Gb card with only SD markings on it not SDHC.
Posted on May 25, 2010
SOURCE: My onity lock is dead,
If it will not take any programming from the box, you may have a broken wire inside the lock.
Posted on Dec 30, 2010
  • 4 Answers
SOURCE: when put on charge the green and red light flash
Yep, not the batteries, mine is doing the same thing but my second charger works fine with the same batteries
Posted on Nov 19, 2011
Forgot the combination to the lock. Is there a way to retrieve the combination or return it to its factory default combination 1, 2, 3, 4, 5
The instructions below are copied from the programming instructions (page 11):
(The "out of box" factory default will be restored)
1. At the back of the lock, remove the screw at the bottom of
the lock housing and remove the cover.
2. Take out the battery pack and remove battery power by disconnecting
the battery pack.
3. Plug in the (provided) male shunt connector into the yellow
wire female connector.
4. With shunt connector connected, re-connect the battery
pack. The lock will immediately sound 3 short beeps (if
these 3 beeps are not heard, then restart at step 2).
5. The lock will then sound more slow beeps, 1 beep for every
second it takes to clear the memory.
6. After a few more seconds, the LED will slowly alternate between
flashing red and green--disconnect the yellow wire
shunt connector.
7. The LED will continue to slowly flash green and red for 25
seconds. To enroll Function Cards, proceed immediately
as follows:
• With the lock LED slowly alternating between flashing
red and green, present the Function Card #1
to the lock. The lock will sound 5 slow beeps.
• The lock LED will flash green rapidly. The lock is
ready to enroll the Function Cards.
• Re-present Function Card #1 to the lock. The
lock LED will flash green then red, with two beeps
(indicating the card was enrolled successfully).
• Present Function Card #2 to the lock. Again, the
lock LED will flash green then red, with two beeps.
• Continue to present, in order, Function Cards 3-
9. Each time a new Function Card is presented, the
After the 9th Function card is presented, the lock LED will flash
green twice, sound two beeps, and will then remain silent,
ready for use. Note: If the lock continues to beep after presenting
the 9th Function Card, check to verify that the yellow
wire shunt is disconnected.
Note: If you only wish to use the first 3 Function Cards, simply
allow the lock to "time out" after 30 seconds.
Here is the link to the complete instructions, in PDF form. You will need Adobe Acrobat or equivalent to view them:
Good luck-and please provide feedback if this helps!
Nov 04, 2011 | Trilogy ALARM LOCK PL3000 Series T3 Prox...
I have 5 brand new TESA Onity locks that will not work after I program the lock.Just blinks red when I insert the key in it.
This page is for Onity's Supplies and Services:
It is the only source of contact information that I could find toward solving your problem.
I suggest that you contact them through the phone number listed on this page. For your convenience,
By Phone: 1-800-749-2983
By Email:
Jul 27, 2011 | Locks & Locksmithing
When i use a guest card in the lock the lights flash green and red even with new batteries when i put the door on test with my p p unit it states that the lock is out of time zone
This means that the master card you are using has a time parameter on it.
Or it means that the lock has a time parameter in the program.
The other time you will get that light signal is when the lock is in privacy mode. It will go in privacy if it thinks the dead bolt is thrown. Sometimes the little micro switch on the back plate is open. Check to make sure the switch is closed when the dead bolt is in. This is the switch where the red and black wire plug in.
Ken Croston
407 814 4974
Jul 21, 2011 | Locks & Locksmithing
I bought a 1996 Subaru Impreza L 4dr 5speed AWD that runs and starts fine but when I was installing fog lights i noticed that there appears to be an alarm hooked up (it says "code alarm elite DM...
Battery Constant 12v+ Positive Wire (+): Black/Yellow
Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
Starter Positive Wire (+): Blue/Red
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire (+): Red
Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): Red/Yellow
Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Positive Wire (+): Red
Parking Light Positive Wire Location: Low In Drivers Kick Panel
Power Door Lock Negative Wire (-): Add Actuator. This vehicle uses a central door locking system. When connecting a keyless entry, you will need to add a door lock actuator and some units will also require (2) extra relays.
Power Door Lock Negative Wire Location: To Drivers Door Only
Power Door Unlock Negative Wire (-): Add Actuator. This vehicle uses a central door locking system. When connecting a keyless entry, you will need to add a door lock actuator and some units will also require (2) extra relays.
Power Door Unlock Negative Wire Location: To Drivers Door Only
Door Trigger Negative Wire (-): Red/White
Door Trigger Negative Wire Location: In Black Plug, Above Hood Release
Domelight Supervision Wire: Use Door Trigger, Requires Relay
Domelight Supervision Wire Location: N/A
Horn Negative Wire (-): Red/Green
Horn Negative Wire Location: At Steering Column Harness
Tachometer Wire Negative Wire (-): Black/Blue
Tachometer Wire Negative Wire Location: At ECM, Under Drivers Side Dash
Brake Light Positive Wire (+): White/Black
Brake Light Positive Wire Location: At Switch Above Brake Pedal
Used on:
Impreza 1996-2001
Legacy 1995-1999
Forester 1998-2000
codealarmremote2.jpgBattery GP-23A
Lock: Left button will lock all doors. Double chirp indicates locked.
Unlock: Right button will unlock driver's door only. Hold unlock button app 6 seconds, it will unlock all doors including rear gate. Single chirp indicated unlock.
If the car chirps or lights flash 4x the alarm was triggered.
Panic. Press both buttons to activate emergency honk and flashing lights.
Valet mode: With optional alarm onlyPress the red alarm button on the left of the steering wheel. The light will quickly double flash. To re-set back to normal mode, press the red alarm light button again
Battery failed and lights flashing?
Parking lights will flash when the vehicle's battery is disconnected and reconnected.
To stop lights from flashing, either:
Press remote transmitter "UNLOCK" button once OR turn the ignition switch to the "ON" position and press programming button for one second (see below).
The vehicle interior (courtesy) light and door open warning light (DOOR AJAR indicator) will then illuminate for 60 seconds when the ignition is turned off, or until the doors are locked with the remote transmitter. Yes, the dashboard instrument panel lights will flash when the parking lights flash.
Programming or Overriding the Alarm when you have lost the remote
Open driver's door.
Turn ignition key to 'On'
Press and *hold programming button* in (see diagram, button under dashboard)
After 15 seconds the the door locks will cycle 3 times. Do not release Programming button.
Press lock (left) button the remotes to be programmed. The door locks will cycle one time. Exit programming mode by releasing Programming button under dashboard and turning key to off.
codealarmremote1.jpgCode Alarm Programming Button is under dashboard on the kick panel by the driver's left knee, left of the steering column. If you can't find it, it might still be tucked up in the wiring harness higher up in that same general area. The botton is recessed in a plastic ring (see diagram).
This button must be pressed while programming remotes or if the battery was disconnected and the lights are flashing.
Jan 05, 2011 | Subaru Impreza Cars & Trucks
I installed my powerbolt today and it works but after i enter my code to unlock it, it retracts the bolt and then beats at me a couple times, but it works... and the green light keeps flashingwhats wrong...
Hello Lil Babe,
The lock is working just as it is supposed to. The beeping after it retracts is an audible signal to let you know that the lock has opened or closed.
The flashing green light is a visual signal to let you know that the lock is "open" and you are able to open the door. When the lock is "locked" the light will flash red momentarilly and then should stay solid red for a brief time.
Everything is working just fine, so congratulations on doing a successful installation of your new electronic lock!
I hope you find this Very Helpful and best regards!
Dec 11, 2009 | Weiser Lock Powerbolt 1000 Lock
Memory card error
is the lock switch fliped wrong
Aug 03, 2009 | SanDisk 8GB microSDHC Memory Card with...
When i went to erase the files on my sony 8mb memory card for my sony dsc-p31 digital camera i accidentally erased the file containing the software for the memory stick can i reformat that memory stick....
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
2. Format memory card
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Apr 02, 2009 | Sony 8MB Memory Card 2 Pack (Red, Blue) -...
Mikomi card reader
you may have to check the manufacturers website for a vista compatible driver (as it seems that the generic driver is not working here.)
Oct 22, 2007 | Electronics - Others
Filter light still on "Red"
Mar 30, 2007 | Maytag MSD2454G Side by Side Refrigerator
Electronics - Others Logo
138 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
