Question about Star Washing Machines
Chh024cd comfort star plus. Getting an H1 error code on heat. What did this mean?
3 Suggested Answers
Pnutgllry
  • 57 Answers
SOURCE: toyo laser 73 stove
Try trouble shooting at this website....
http://www.rural-energy.com/publications/catalog/category/101
Posted on Oct 19, 2008
SOURCE: Ductless mini split heat pump comfort-aire error codes
E:1 room temp. sensor fault. / indoor unit.
see more pls Air Conditioning Fault Codes
Posted on Jul 06, 2014
What the code h1 means samsung washing machine
H1 on a samsung washer is a heating problem.
You need to check the heater and the control unit and find the fault form there.
If you have a multimeter you can test the heater as it should read about 28 ohms. If faulty then the heater will need to be replaced to cure this.
Check it out and see what you find but the H1 error code is a heating problem.
~~~via just answers
Feb 14, 2016 | Samsung Washing Machines
What does H1 code indicate?
Hello E, I appreciate your post!
I see that your Frigidaire air conditioner is displaying an error code of "H1". I have reviewed the air conditioner and the "H1" error code could be an "HI". The "HI" error code means that the room temperature is above the display range. I would recommend performing a reset on your air conditioner. In order to reset the air conditioner you need to unplug the power cord you can press the reset button and then the test button that should restart your air conditioner. If that does correct your issue I would recommend seeking assistance from a professional technician for proper diagnosis and repair. I hope this information is helpful for you. -Matt
Jan 22, 2016 | Frigidaire FRS12PYS1 12000 BTU Split...
Error code E2
open circuit or out of range indoor temperture sensor. locks out cool and heat.
Aug 09, 2014 | Dometic 3109228.001 Duo Therm Comfort...
How to fix error code 25 for makita HG650C
Error on Makita HG650/651, or Weldy Plus means, that damaged can be: 1 Heating Element, 2 Electronic controller, 3 Switch - or everything.
Aug 02, 2014 | Makita Tools & Hardware - Others
Bosch silence plus 50 dba has error code h01
The statement below can be found at: http://www.ehow.com/list_6978265_bosch-dishwasher-error-codes.html,
The SHU4326 and 4326 models use "Regular Wash" and "Rinse Hold" to begin the test while the other three series in this section use "Scrub Wash" and "Delicate/Econo," but all use the same set of fault codes, shown not as lights but as numbers on the Cycle Countdown display. Here, 1 is an aqua sensor fault, 2 is a heating fault, 4 is a filling fault, 8 is an NTC fault and 0 means that everything is working as it ought. During an actual wash, when you aren't testing, the Cycle Countdown display may show the letter "F," which also signifies a filling fault.
Read more: http://www.ehow.com/list_6978265_bosch-dishwasher-error-codes.html#ixzz33JutQVQR
Apr 05, 2014 | Bosch Evolution 300 DLX SHE43P26UC Full...
My mini split comfort star has an e1 error code, what does it mean
the E1 code is a communication error.First check for proper voltage at your condenser, then check all wire terminations between condenser and air handler. you should have LED's on your main board as well as your PFC board. if they show normal operation then chances are the main board is bad. be sure to check the ground .it must have a proper earth ground.
Jan 18, 2014 | ComfortStar Heating & Cooling
My Heat will not work on my upstairs unit. I am getting an E2 error code on my carrier thermostat. what does that mean?
the e2 code on a carrier comfort zone thermostat is indicitive of the external safety sensors which are located on your units ductwork in the attic. the e2 code are the hpt/ and lat sensor codes. the hpt is the heat pump temperature sensor and the lat is the leaving air temperature sensor. you can pull off the cover of the panel and behind it will actually give you all the fault codes associated with you carrier tsat.each sensor has a certain ohm rating and if its out of the range it will fail. now as to the reasons for failure, the indoor coil could be dirty, filters dirty, refrigerant charge incorrect.
Dec 03, 2008 | Carrier Heating & Cooling
Long distance text message will not send. error code 00107. I would like know what that code number means. bat999@videotron.ca
The caller has caller ID block placed on their acct/ this can interfere with sending sms messages to a phone that does not accept sms or voice calls from a line with caller id block/ I had cust resprond to a text with send new to area code plus 10 digit number/ success/ removed caller id block from service and had cust click *star 67 then area code plus 10 digit number/ if you choose to have your contacts entered with *82 area code plus 10 digit cell number you will get error 00107/ can not receive or respont to blocked calls particularly long distance/resolves iss/ I am a technical suport agent for sprint/ Happy Texting
Jun 06, 2008 | Cell Phones
Washing Machines Logo
Top Star Washing Machines Experts
Are you a Star Washing Machine Expert? Answer questions, earn points and help others
