Question about Rainbow Vacuums
How do I get at the carbon brushes in my Rainbow D3 vaccuumm to change them?
4 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: Problem with E series rainbow, motor starts then slows down to a halt and smells.
From what you describe, you will probably have to replace the motor. But you could take it apart and see if it just needs carbon brushes.
Posted on Mar 25, 2008
advacak
  • 125 Answers
SOURCE: where can i get 2 carbon brushes c90 for my e series rainbow vacu
get them at any vac repair shop for about $4
Posted on Dec 16, 2008
  • 35 Answers
SOURCE: Motor carbon brushes
hi try potts in derby babbington lane ,very help full
Posted on Apr 09, 2013
Rainbow power head works but canister dont model d4
Chances are the motor died or went bad.
You would have to get a new motor.
You can find one here:
Rainbow D4 SE motor 120V
Or a more cost effective refurbished D4 motor unit here:
Rainbow D3 D4 SE motor unit
GoodVac.com
800-775-6586
Jul 04, 2014 | Rainbow E series Canister Wet/Dry Vacuum
RAINBOW E SERIES REPAIR MANUAL
Hi. I found it on amazon, here: Amazon com rainbow vacuum manual. I hope I have helped. cheers
Mar 31, 2010 | Rainbow E series Canister Wet/Dry Vacuum
How to install carbon brush
You have to open the case. First remove the transparent plastic on the side then you will see screws on the bottom part of the transparent plastic. Unscrew them and from there you will open the machine. Remove the rexair cover and unscrew the screw that attaches to the 2 carbon brush. When you remove the carbon brush you will see a spring and the copper wire at the end of the brush. remove it and put the new copper wire from the new carbon brush to the contact passing thru the middle of the spring. Then screw it back tightly.
Jan 30, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E series
The belt looses it tensile strength (tightness) over time. But it's the part about funny sounds and shutting down that concerns me. If it smells like a tire fire then it's the belt if it smells like plastic and burned hair then the motor has a bad field or armature. Probably one of the carbon brushes got hung up and burned a segment in the armature.
Oct 02, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow e2 series
Does the separator turn easily by hand? If it does, may be there is a problem with the carbon brushes. If this model is one that has the computor board mounted on top of the motor, there may be a problem with it.
Apr 20, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Burning Smell
Check the carbon motor brushes, there might be arcing on the armature. New brushes may help if the armature is ok.
Mar 29, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Mar 25, 2008 | Vacuums
A problem.
Sounds like the carbon brushes. If they are sparkng, then either they are bad or the armature is bad, possibly both.
Feb 25, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Remove suction motor on rainbow vacuum
Take off the water tank, remove the screw, should be four, that will separate the 2 pieces, remove the rubber seal, remove the screws, 8 If I remember, disconnect the wires to the motor, it should pull out. Replace motor, hook up the wires, screw it back together, glue the water seal back on.
Jan 04, 2008 | Vacuums
Vacuums Logo
Top Rainbow Vacuums Experts
Jim Parker
Jim Parker
Chris Nomland
Chris Nomland
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
