Question about LG Washing Machines
Lg model lds5540 smells, will not clean properly and doesn't seem to have enough water during cycle. also occasionally shows the fe error code. ??? any thoughts?
  • LG Master
  • 5,323 Answers
WATER OVER FLOW ERROR // Water continuing to enter machine
The manufacturer has assigned this error or fault code to indicate that the washer is overfilling due to a defective water inlet valve. The valve is not repairable and will need to be replaced.You can check it with a multimeter to confirm, it should show continuity on both hot and cold pins. try exchanging the how and cold water hoses, cold on hot and hot on cold, see what happens. have u tried running only cold water or hot water wash? as for the smell could be a build up of detergent or frabic softner, try washer running machine with hot water and vinigar to clean out also check inlet valve for dirt build up
lg model lds5540 smells, will not clean properly a - 26391227-bszy215dbxllk1sw2ym4qmfg-4-0.jpg
26391227-bszy215dbxllk1sw2ym4qmfg-4-2.jpg lg model lds5540 smells, will not clean properly a - 26391227-bszy215dbxllk1sw2ym4qmfg-4-5.jpgt/uploads/images/26391227-bszy215dbxllk1sw2ym4qmfg-4-5.jpg" alt="2639122lg model lds5540 smells, will not clean properly a - 26391227-bszy215dbxllk1sw2ym4qmfg-4-9.jpg="h_mi" />
Posted on Dec 08, 2016
Why on an LG Front loader does the FE code come on and not on Rinse & Spin?
Here is the LG site for washing machine error codes, you can scroll down and find the FE code there:
http://www.lg.com/us/support/product-help/CT10000010-20150140270078-other-error-codes
The site shows the following:
The FE error code indicates the washer is overfilling. This is usually the result of a faulty water valve.
1. Close both water taps.
2. In order to drain out any trapped water, power the washer back on and press the Spin Speed button until No Spin is selected and press the Start/Pause button.
3. Once the washer has drained, restart the wash cycle.
Jan 26, 2017 | LG Washing Machines
Was getting a "IE" error during the wash cycle and the machine would shut off. Replaced both inlet valves and now I am getting a "FE" error as the machine is constantly filling with water.
Hello. I need the make/model number to help you accurately. If you have a Samsung washing machine, the IE error code pertains to a defective water level sensor. The "pressure switch" tells the computer how much water is in the tub at any given moment. It will have a tube (plastic or rubber) connecting it to the bottom of the tub. As water collects in the bottom of the tub, air is pushed into this tube and against the sensor. The sensor can fail in 2 directions. Your washer will not fill with water at all because it thinks there is already water in the tub(the tube is clogged)--or disastrously, keep filling until it overflows and floods your house because it constantly thinks there is not enough water. This can happen when the hose is loose on the sensor, a pinhole has developed in the hose and proper pressure won't build up which will give the sensor inaccurate information, or the sensor is just defective.
The FE error code refers to a "frequency error"--something is wrong with the incoming AC power supply--If this is an LG machine, then the error code is the pressure switch again--Sorry for the ambiguity but different makes have different meanings for the error codes--anytime an overfill condition exists, I first suspect the pressure switch, then I check the wiring harness connections, lastly, I suspect the main control board. I hope this helps you!
Nov 07, 2015 | Washing Machines
Getting FE error saw a answer for this model on fixya said to clean the float module where no plastic float on bottom of washer
The FE error or fault code indicates that the washer is overfilling due to a defective water inlet valve. The valve is not repairable and will need to be replaced. If the error persists even after the water inlet valve has been replaced there may be a problem with the main control circuit board
Oct 25, 2015 | LG LDS5540 Semi-Integrated Dishwasher with...
Error code FE
From the manual ,FE means Water level is too high due to a faulty water valve. hence the possible leak
Dec 22, 2009 | LG WM2277H Front Load Washer
Our LG model WM2032HW intermittently show up with th FE code what could be wrong and can it be fixed by us?
FE error code means water is overflowing. The water is over 8 level.When FE is displayed, the drain pump will operate to drain water automatically. Otherwise the pressure switch assembly is malfunctioning. Check and replace if necessary. Part number is 6600FA1704X.
The pressure switch assembly shuts off the water inlet valve when the desired water level is reached. It then activates the drain pump when the water inlet valve is not deactivated.
Oct 18, 2009 | LG 4.0 Cu. Ft. 7-Cycle Front-Load Washer -...
LG washing machine keeps stopping and it says OE
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. Check the exit hose, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Apr 11, 2009 | LG WM2042 Front Load Washer
LG Sense Clean DD error code "FE" front loader washer/dryer combo
my lg senseclean wash mashine shows the sign Cl on the display and the door cannot be open what does it mean?
Jan 03, 2009 | LG 4.0 Cu. Ft. 7-Cycle Front-Load Washer -...
Washing Machines Logo
32 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
