Question about Photography
The curtain goes down on the 31st, but what comes up on the 22nd.
  • Photography Master
  • 5,412 Answers
Is this a query concerning Trailing Curtain sync ? If so, the technique should be explained in your camera manual, or instructional videos may be available on YouTube.
Posted on Dec 10, 2016
Which Is Better - Curtain Spring Rod or Curtain Spring Wire?
Both are very good alternatives to conventional solutions of hanging curtains, however, both have their share of pros and cons. As far as curtain spring rods are concerned, they can be an absolute bliss in terms of installation, a process that can take no more than 10 seconds. You will also not have to drill any holes through the walls which can be a blessing.
Extendable curtain rods are in very high demand because of their flexibility in terms of area of installation be it shower stalls kitchen windows or any others for that matter. On the flipside, general models will not be able to hold heavy curtains for which you will have to look for conventional solutions.
On the other hand, curtain spring wires / stretch wires are literally unchallenged in terms of neatness and strength. The only thing that can come in the way though, is the installation process which can be a little demanding especially for those that are not experienced in the matter.
Mar 14, 2018 | Home
I am getting a message saying the Curtain Open and I can't get my ice machine to come on?
I didn't think their smaller units had a curtain, but it is referring to the plastic shield that hangs in front of the ice making grid or evaporator. This must be closed for the unit to run and there is a magnetic reed switch located on the bottom right hand corner of the curtain to prove that it is closed. Actually the magnet is in the curtain and the reed switch is snapped into the side of the grid. Make sure the curtain is in place and the magnet has not broken off. If that is in tact look to see if the reed switch is in tight. IF YOU DO NOT HAVE A CURTAIN... some units had a small plastic flapper at the bottom of the grid that was activated whenever ice dropped. Same system though with a magnet and reed switch. The magnets on some of these curtains and flappers were just surface mounted with some kind of adhesive and others have it captured inside of a plastic pocket made into the curtain. So if you don't see a magnet look for a spot where it used to be. If you want to prove this is the problem just get a magnet and hold it up to that spot for about 10 seconds and see if the unit cycles on. You will then have to order a new curtain or flapper or attach a magnet to the broken spot somehow.
Mar 07, 2015 | Manitowoc QY-0214A Self Contained Ice...
Shutter does not operate.
hiwhen you say shutter does not operate, it mean too general to answer. could you provide more detail?I will give how does shutter work. First, you press shutter button, it will activate two switchs (one is focus and meter and the other is release ) Second, mirror goes up and opening shutter curtain move up. Third, closing shutter curtain down and mirror down and picture come out. Of course there is also aperture control unit sequence.
Jun 04, 2011 | Nikon D40x Digital Camera
Manitowoc Ice machine only makes 2/3 bin of Ice and shuts off
The unit shuts off based on the magnetic reed switch in the plastic curtain on the front of the evaporator. If the ice is not falling as one single sheet with about 1/4"-3/8" of a bridge conecting all of the cubes then the ice is too thin. When the ice falls (in a single sheet of ice) if there is enough ice in the bin to hold that ice up and keep the curtain open the unit shuts down. A full bin may only be what appears to be 2/3 or 3/4 of a bin full because the ice sheet is propped up behind the curtain. If the ice sheet is too thin and does not fall as a single sheet more often than not a single cube or a piece of a cube can get caught between the curtain and the evaporator plate. This can shut the unit down for several hours until that piece melts and the curtain closes again.
Dec 19, 2010 | Manitowoc - QD-0212A/115-1
The shutter is stuck...all I see is black
Your second curtain is not releasing the mirror to come down.
This happens with weak 2nd shutter curtain tension.
If the wind lever is stuck and the mirror does not come down then the mirror tension spring came off.
May 12, 2010 | Pentax K1000 35mm SLR Camera
Water leaking to bottom of freezer
ok you have a blocked freezer drain. The best thing to use to clear this is 'curtain wire (the plastic coated wire you use to hold up net curtains). Ok you need to find the drain hole in the "small tray on the back wall inside that fills and freezes and then the water is overflowing at this point to the bottom of freezer" you want to gentley feed the curtain wire down the hole untill the water drains down there. If you can't get the wire down you may need to turn the unit off to defrost as it could be frozen solid with ice. cheers
May 31, 2009 | GE Refrigerators
Nikon 6006 shutter curtain
Shutter Curtain needs to be replaced.
There are 2 of them. Usually one goes out of position and brakes.
Mar 22, 2009 | Nikon N6006 35mm SLR Camera
typically this is a problem with flash photography.
are you using flash?
the speed of exposure, the time that the film is exposed is controlled by two curtains that cover the film and prevent light from striking it. One curtain is across the film at the start, and springs open, then the second which was open, springs shut.
for 'long' exposures the first one opens time passes and then the second closes, but to achieve very short times, the second curtain starts to close before the first one has fully cleared the opening. so the edge of the second curtain can be traveling fractions of a second behind the first.
the result is that NOT ALL OF YOUR FILM is exposed to light at the same instant. If you have a flash go off during a fast exposure, only that portion of film that is exposes when the flash fires will get the proper amount of light, the rest of the film being blocked by a curtain. Most cameras are wired to fire the flash as soon as the first curtain is fully open and before the second starts to close. If you have a faster speed set in your camera by mistake, the second curtain has already started to close when the flash goes off. The black area on the right side is that portion of film that was already covered by that second curtain when the flash fired.
if you have the camera set correctly (typically at 1/60th or 1/100th sec) then maybe you should take the camera to a local camera store, and have the curtains timed...
Feb 20, 2009 | Minolta Maxxum 5 / Dynax 5 35mm SLR Camera
Repated start up requests from the computer
That means Hardware Error. It is a gray iron curtain with a black dialog box. Most likely bad Ram/Memory, but If warranty, call Apple. Otherwise there should be a diagnostics CD or DVD that came with your recovery Disks. It should tell you what's wrong if it can boot before the Iron Curtain comes down again.
You can try swapping ram with a recent age mac or pc laptop and see if it repeats.
Mar 21, 2008 | Apple MacBook Pro Notebook
Photography Logo
234 people viewed this question
Top Photography Experts
Are you a Photography Expert? Answer questions, earn points and help others
