Question about Vivitek Televison & Video
Vivitek lt32pl1-a problem turns off by itself
Turning off then turns back on.
The ballast board that controls the lamp is bad.
Feb 20, 2014 | Vivitek V37655 56" DLP TV
I replaced the lamp im my vivitek 56 inch dlp tv. But it still wont turn on. The light goes from green to red and it makes a sort of high pitch sound then stops
my vivitek RP56HD22A 56" dlp tv has a new lamp and will not turn on. when i push the on button is whines and wont come on
May 24, 2010 | Vivitek V37655 56" DLP TV
I have a vivitek 32 in. lcd hdtv.no picture
Tv have problem in power supply board.Check power board replaced the capacitors parts.Like puff up,burst up.Or replaced the whole power board,tries Shopjimmy.com,Ebay.com.
Jan 18, 2010 | Vivitek V37835 46 in. LCD Television
Looking for the enter code for vivitek tv model # rp51hd41-a a 51" micro display projection tv
your cable or satellite will do just fine. i have a vivitek rp51 and i was told that if i lost my remote i was SOT well i found out that the parent company of vivitek is DELTA and wouldn't you know it i programmed my direct tv remote using the brand delta wich was on the list and it worked... by the way vivitek is not on any list for remote control codes....
Jan 14, 2010 | Vivitek V37655 56" DLP TV
VIVITEK 56"
check your power module output terminals for correct output
Sep 06, 2008 | Vivitek V37835 46 in. LCD Television
How to reset lamp timer
Go to the menu and you'll find lamp timer section.
Aug 27, 2008 | Vivitek V37835 46 in. LCD Television
Vivitek dlp tv
42'dlp vivitek tv color wheel were can i get one
Jan 18, 2008 | Televison & Video
Direct tv recorder and Vivitek V37835 46 in. LCD remote code for controller
IN THE GOOGLE SEARCH ENGINE TYPE VIVITEK V37835 MANUAL. ONCE YOU GET THE MANUAL LOOK IN THE SECTION OF THE MANUAL THAT SAYS SETUP CODES FOR SATTELITE RECEIVERS. FOLLOW THE INSTRUCTIONS FOR PROGRAMMING UR REMOTE. ALSO WANT TO LET YOU KNOW THAT I HAVE DISH SATTELITE AND I USE MY VIVITEK REMOTE NOT THE SATTELITE REMOTE FOR MY PROGRAMMING. MAYBE TRY THIS. IT WORKS FOR ME.
Oct 18, 2007 | Vivitek V37835 46 in. LCD Television
Televison & Video Logo
32 people viewed this question
Top Vivitek Televison & Video Experts
Jim Goldsmith
Jim Goldsmith
matt martin
matt martin
Are you a Vivitek Televison and Video Expert? Answer questions, earn points and help others
