Question about Paragon Hardware & Accessories
Need a programing Manual for a Paragon EC74/192MA 365 Day Multi-Function Electric Time Switch (ELE2621)
I need to program the lights of a building, to turn it off in the afternoon and turn it on in the morning but I do not know how to program this timer. If you could help me with the manual or tell me how to do it, I would be very grateful.
arealplumber
  • 33 Answers
SOURCE: Instruction manual to program HB77R
Here is the instruction manual your looking for:
Intermatic HB77R
Hope this helps and please remember to rate this!
Posted on Dec 10, 2008
SOURCE: user manual digihome dtr80
There are two versions of the digihome dtr80 which are made by Vestel. If you look underneath at the product sticker you will find one of three numbers:
T810 : In this case youve been conned into buying a digihome pvr80. This has very limited functions and cannot series link.
T816 : This does support series link but you need to install new firmware using a computer a a serial extension cable. You can get the firmware from here: http://www.futaura.co.uk/vestel.html You want version 6.8. Bear in mind there areside affects to this program such as recording every episode that comes along on that channel and a very sluggish interface.
T825 : This does support series link by default. You go to the epg, highlight the program you want to record, Press the OK button and a menu will appear. Select series link.
Please be aware series link only stays active for 13 weeks so you will have to redo it halfway though a series.
Posted on Jun 29, 2009
Illeagle
  • 525 Answers
SOURCE: I need programming instructions for a maytag MDE16PDAYW dryer
Try the link below for anything about Maytag commercial laundry.
http://www.maytagcommerciallaundry.com/content.jsp?pageName=CustServ
Posted on Jul 17, 2009
SOURCE: Lost instruction manual. How do I progam my
Link below has Paragon EC7000 series timers and manuals
EC7004/120 is 7-day programmable timer.
Single channel 120Volt SPST NEMA1 indoor timer.
Program up to 16 events per week
http://waterheatertimer.org/Paragon-timers-and-manuals.html
EC7000 series programming manual shows wiring, explains keypad, has steps for setting current time, and shows 24 steps for programming timer. Plus troubleshooting.
It is impractical to write out those steps when they appear in manual.
http://waterheatertimer.org/pdf/Paragon-EC7000-04-05-manual.pdf
EC7000 series Sell sheet with model numbers
http://waterheatertimer.org/pdf/Paragon-EC7000-sell.pdf
Description of model numbers at Uni-line
http://www.uni-line.com/modules/catalog/SearchResults.aspx?catName=19030&pID=19029&mode=categorysearch
Posted on Dec 01, 2010
SOURCE: Utilitech model 0141224 wall switch
As luck would have it I'm 60, and learned how to program your 0141224 wall switch timer.
You can see instructions with big print and pictures on following page.
Press CTRL key on keyboard and use scroll wheel on mouse to make web print bigger.
http://waterheatertimer.org/Program-wire-Utilitec-LW60418.html
Add a comment any time.
You have wired your timer correctly and the lights turn on when you push on-off button.
If lights do not turn on, we need to review the wiring.
Your timer looks like photo below.
I'm going to parrot back the manual with some extra words.
To start, press the reset button and clear any programming
Programing overview:
Each program has ON time ... and OFF time
So you set program1 ON and then set program1 OFF
When you set program1 ON, you choose the Day, hour and minute you want program1 to turn ON.
And then you set program1 OFF, and choose Day, hour and minute for program1 to turn OFF.
Your ON-OFF times for program1 should be on same days.
For example program1 ON for all-days-of-the-week, but program1 OFF is for TU Tuesday, then timer will not work.
IN this case, program1 OFF should also be set for all-days-of-the-week.
Let's start.
Setting the clock:
Press and hold CLOCK button
Keep holding CLOCK button and press DAY button until display shows current day (MO TU WE TH FR SA SU)
Press Hour button until current hour with am pm displays
Press MIN button until current minute displays.
Release clock button and current day and time show on display
At no other part of instructions do you press and hold one button while pressing other button.
Setting programs:
Press PROG button until "1" and 'ON' show on display
This is program1 ON
Press DAY button to choose which days for program1 ON.
You can choose: all-days-of-the-week and MO TU WE TH FR SA SU show on display
Choose individual days and MO or TU etc shows in display
Choose weekdays MO TU WED TH FR
Weekends SA SU show in display
Next step
Press HOUR button to select hour for program1 ON
Press MIN to select minute for program1 ON
Now program1 ON is ready, next, you will set program1 OFF
Press PROG button until "1" and 'OFF' shows on display
This is program1 OFF
Press DAY button to choose which days for program1 OFF.
( Remember, you want same days for ON and OFF)
Press HOUR button to select hour for program1 OFF
Press MIN to select minute for program1 OFF
Now program1 ON and OFF are ready, next, you will set program2 ON by repeating same steps above.
You can set up to 7 programs.
If you don't want to set program2, or any more programs, that's fine.
To exit programming and save your program, press CLOCK.
Now current time shows in display.
Final step: set MODE
Press MODE button until AUTO shows in display. You want AUTO for programming to operate lights. That's it, timer is ready.
If you're going on vacation, press MODE button until RDM shows in display, and then timer turns lights on-off at random
Copy and save these instructions to your computer so you have them next year.
Posted on Dec 05, 2010
Can't program, won't turn lites off
"If you need more programming assistance, request form #158ET9311 " from Intermatic.
http://www.intermatic.com/customer%20service.aspx
Or call Intermatic: 815-675-7000
Manual shows example programming on page 17-18:
http://waterheatertimer.org/pdf/Intermatic-et70415cr.pdf
The instruction manual for this timer does not have step-by-step programming.
There is example programming on page 17-18, but it shows one example.
The timer manual doesn't have step-by-step because the timer prompts the user as the user is programming timer.
As a result, it is difficult to know what step was missed.
It is equally difficult for expert to know what went wrong.
In addition, the timer offers choice of 24 hour or 1-week or 365 day programming.
Also the timer offers choice between 'astro' dawn-dusk' or 'fixed' programming, 'pulse' bell-ringing programming, and 'interval' programming.
And then there are additional programs available for individual days throughout the year if you choose 365 day operation.
Add on top of that, the timer has 4-channel operation where each of the 4 different relay circuits are programmed separately for each of the options mentioned above.
For these reasons, I recommend contacting Intermatic about this timer.
Sep 20, 2011 | Intermatic ET70415CR Energy Controls - ETS...
Need instruction for setting time of day
You posted under Paragon 1015 timer.
Open following link to identify timer and download manual.
http://waterheatertimer.org/Paragon-timers-and-manuals.html#1015
Timers are 24 hour, but some have 7-day capability:
Manual says: to set 7-day grasp large 24 hour dial and rotate either direction until correct day of the week appears below Day Set red dot and 12 noon on large 24 hour dial is below red pointer.
To set 24 hour, grasp large 24 hour dial and rotate either direction until correct time appears below red pointer.
Red pointer is stationary at 6:00 position.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 14, 2011 | Paragon 1015-00RS Indoor Multi Operation...
Lost instruction manual. How do I progam my Paragon Electric timer Model EC7004/120
Dec 01, 2010 | Paragon Amf 7008-00 Timer 7 Day 120 Volt...
How can I program my Leviton timer model 6651-I?
Leviton 6651 Manual.
http://waterheatertimer.org/pdf/Leviton-6651-manual.pdf
Timer requires a battery which should be replaced each 12 to 18 months.
Timer replaces single-pole or 3-way switch, and does not need a separate neutral wire.
Timer is for incandescent lights only.
500 Watt capacity
Push the door for manual override to reverse program that is in effect.
The 14 hour timing period is represented by 24 dip switches.
Each dip switch is positioned for ON or OFF.
Click the dip switch right or left
Start at the bottom
For example: ON for 3 hours, OFF for 4 hours, ON again for 3 hours:
Click dip switches 1 thru 3 to ON position, 4 thru 7 to OFF position, 8 thru 10 to ON position
ON position is to the right.
OFF position is to the left.
At the end of the 14 hour program, the timer turns lights OFF until the original start time is reached after 24 hours.
Timer will operate like this while in AUTO mode, until function switch is moved from AUTO to MAN or OFF modes.
Function switch is located at very bottom of timer door.
To activate program (on first day), function switch is set to OFF position for 2 seconds, and then move function switch to AUTO mode, and programming cycle begins.
Nov 11, 2010 | Solar Leviton 6651 Decora Programmable...
I have a EC4000 electronic digital timer. The problem is when the timer hits a preset time to turn the boiler on , the boiler will not turn on, but when I hit the manual override button on the timer the...
Paragon EC4000series are programmable timers
EC4000/120 for 120V
EC4000/277 for 208-277V
Is this a new installation?
Or was timer working fine until recently?
1) With digital programmable timers like EC4000, if there is conflict in programming, or missed program, then timer might skip the program.
For example if program1 says ON at 7 and OFF at 8, and program2 says the opposite.
2) If wiring is reversed, then the manual override will work but clock will not operate, and the timer will not function.
a) for 120V timer:
-120V black wire from breaker goes to terminal2
-120V white wire from breaker to terminal1
-jumper wire from terminal2 to terminal3
-Load black wire to terminal4
-Load white wire to terminal1
b) for 240V timer
-240V Hots from breaker go to terminal1 and 2
-Load wires connect to terminal4 and terminal1
Below is link to EC4000 instruction manual
http://waterheatertimer.org/pdf/Paragon-EC4000-program.pdf
Troubleshooting steps say to review set-points.
Solutions:
Checking wiring as described above
Check programming.
Reset timer and re-program set times.
If you need more help, add a comment at bottom
Oct 26, 2010 | Paragon 4001-00 24-hr Timer Control 120v...
I need to program the timer
http://waterheatertimer.org/Paragon-EC4000-program.pdf
4 Buttons RUN MODE Arrow ENTER
Programming steps are long but straightforward
16 set points
Selectable clock format - 12 hour/ 24 hour
Day skipper
Manual has troubleshoot section, so expect the usual trouble
Wiring diagram at bottom shows 5 poles for 120V timer.
Hot and Neutral connect to poles 1 and 2
Jumper from Hot to pole 3
NC normally closed pole 5
NO normally open pole 4
Black from load connects to pole 4 or 5
White from load connects to Neutral at pole 1 or 2
Sep 28, 2010 | Paragon 4001-00 24-hr Timer Control 120v...
Need a programing Manual for a Paragon electronic timer, used for bells.
Paragon 4000 is a mechanical dial-type timer
You probably have Paragon EC4000 digital timer:
Single channel, NO, NC contacts, SPST with 5 poles or SPDT with 8 poles.
To identify your timer: Paragon 4000-7000 series
If you have EC4000, the following pdf files are helpful
EC4000 Sale sheet
EC4000 Programming
Sep 09, 2010 | Paragon 4001-00 24-hr Timer Control 120v...
Need assistance on how to program the timer for my cuisanart 12 cup coffee maker
1. Set the desired Brew-Start time.
a. Turn the FUNCTION KNOB to “Prog”.
b. Set the time you want coffee to begin
brewing by using the minute and hour
push-buttons. Follow the same instructions
you used to set the time of day, in
the To set the time section above.
2. Turn the FUNCTION knob to the “Auto On”
position. LCD will display the current time.
3. Lift and release the FLIP SWITCH. The
green indicator light will come on to remind
you that the programming function is in use.
At the programmed time, the red light will
come on as well, indicating that the brew
cycle is starting. Both lights will go off when
keep warm cycle ends.
NOTE: To reactivate the auto-on feature to
start brew cycle at the same time another day,
simply lift and release the FLIP SWITCH. The
green “auto-on” light will illuminate.
The manual can be found here:
http://www.cuisinart.com/share/man/25_man.pdf
Mar 24, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
Hardware & Accessories Logo
105 people viewed this question
Top Paragon Hardware & Accessories Experts
Gene Haynes
Steve
jdthefixer
Are you a Paragon Hardware and Accessory Expert? Answer questions, earn points and help others
