Error code keeps coming up on my washer while i'm washing whats causing that?
The error code comes up along with the beep so I have to constantly restart washer. Please assist
    Top Expert:
  • Washing Mach... Master
  • 8,376 Answers
What is the error code? and make and model please.
Posted on Dec 08, 2016
3 lights and loud beeping
When you start your machine is the water just go stop go stop,
Just wait for the machine to display an error code on the wash progress lights and beeps constantly.
It could be the Rotor Position Sensor, out of balance switch or lid magnetic reed switch.
Your error code will determine this.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
j8paojvh5jrgaaaaabjru5erkjggg==
Dec 12, 2013 | Fisher and Paykel Washing Machines
Problem with a hotpoint wmf760 aquarius + error code h20 coming up
You may have soap & grease in the pipe that leads to the pressure switch. Remove and flush through and/or replace. dry before refitting.
Thus constant high would give pump faults (thinks machine still contains water). Constant low may cause over filling. If you have a plug that suddenly moves, that can cause the above errors.
Jan 02, 2013 | Hotpoint Ultima WF860 Front Load Washer
My washing machine keeps giving me a error 20 code and dosent finish the cycle
E20 is a general error code to get to the real problem try this..
Reading Error Codes2.gif 1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold the START/PAUSE and CANCEL buttons simultaneously. As long as the buttons are held, the failure code will appear in the display as an “E” followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash2.gif. let me know what code come up... hope it helps
Sep 14, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore Oasis Elite Top Loading Washer with an F2 error
The F02 error code indicates keypad/user interface failure. Most of the time, this is caused by a problem in the keypad/user interface. It can sometimes be caused by a failed control board.You could have an intermittent problem such as a stuck key or contact. As long as the F02 is not displayed, the washer should work normally. You can continue to use it when the F02 is not displayed. It is still safe to use the washer.
Sometimes this problem is caused by a loose wiring harness connection between the keypad/user interface control board and the machine control board.
The F2 error code on this washer indicates a stuck button on the user interface control board. The procedure for accessing the control boards on this washer is shown in the image below. I recommend unplugging the washerand checking the wire harness connection from the user interface control board to the machine control board. Try unplugging the connections and then plugging them back in a few times. Make sure that they are plugged in correctly and then reassemble and test the washer. If the F2 is still displayed, then the user interface control board will need to be replaced.
CLICK ON THIS LINK TO GET THE INSTRUCTIONS HOW TO REMOVE CONTROL BOARD:--
http://media.fotki.com/1_p,wfbgkftgqtgssggxgtqsskgwtqkq,vi/gdqwksfbdxggskbksbb/1/1303472/5961857/image8028img-or.gif
You can order a new user interface control board from the Sears PartsDirect website or from----------
www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Jan 12, 2009 | Kenmore Oasis HE 27082 Top Load Washer
My washer constantly beeps three beeps
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 27, 2008 | Kenmore 46462 Front Load Washer
Kenmore oasis electric dryer beeps and displays code F45
We had this error on our machine for about a year before we finally got sick and tired of it. Our dryer was purchased in 2006.
Here is the solution: the code means there is an error on the thermistor. Our thermistor was loose, as were other electrical wires. My husband tightened up all the connections and the thermistor, and we have never had this error again.
However, we will never buy these machines again either, because we have had numerous other errors on the washer and dryer.
Nov 19, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Panel Beeping and F2 error code.
IT SOUNDS LIKE YOU GUYS HAVE A BAD KEYPAD/USER INTERFACE. LOOK IN THE SERVICE MANUAL FOR THIS TOPIC AND FOLLOW THE TEST:
ACTIVATION OF CONSOLE AND INDICATORS
DIAGNOSTIC TEST MODE
BOYNISMO@YAHOO.COM
Aug 05, 2008 | Kenmore Oasis HE 27087
Frigidaire Front Load Washer
It looks like the door switch was not making because the door is defective. Also the switch may just be bad.
Mar 08, 2008 | Frigidaire ATF6000ES Front Load Washer
Error code F11 and orthers
gailo, F11 is a serial communication error. Communication between the central control unit and the motor control unit cannot be sent correctly. Possible solutions: Check the harness between the two boards for loose connection. Driver motor, main board or motor control board may be bad. I have come across a number of these with loose connections and bad main boards. Put it into a test by pressing drain/spin on the left side. Then press the spin speed button on the right until no spin is lit. Then press the pre-wash button on the right 4 times until 00 comes up in the display. You are now in the automatic test mode. Let it do it's thing about 15 minutes and see if the error comes again. Catriver...post back.
Oct 29, 2006 | Kenmore 45981 Washer
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
